Page 2185 of 2773 FirstFirst ... 11851685208521352175218321842185218621872195223522852685 ... LastLast
Results 32,761 to 32,775 of 41591
  1. #32761
    23rd December 2018 - 22:33
    KR1S, KX500, gamma500, tomos
    Island of Korcula
    Nope, for modifying transfers , which became brownish (ie exhaust gases backflow) after approx. 15 hours of racing no any issue. Even 3450 for iron/steel parts was tested on CZ175 exhaust pipe header and aux exhaust port (but from outside of cylinder)
    For conversion from reed to piston port cylinder by filling intake and reed flange with broken cooling fins and loctite mixture with grey iron dust..
    No issues again, loctite gotta have some good heat transfer/conductivity
  2. #32762
    17th September 2013 - 01:07
    SWE
    Great information as modifying transfers with 3479 is one of my future plan’s to try.
  3. #32763
    I've had no problems with DevCon in transfer ports.
  4. #32764
    Devcon JB-Weld and Belzona are all good ones.
    I just have been using what´s on my shelf from porting 4stroke heads, And Loctite 9497 has been free for me.
    I cant say how good it is with alcohol fuel thou.
    I did a test and it worked fine when bathing in methanol, but as soon as i tested with oilmixture things altered colour, never used in real life with alcohol.
    9497 is quite expensive as i can see here in sweden.
  5. #32765
    Jan has mentioned another one they used at Aprilia it was green and it even survived the cylinders being replated.
    its mentioned on either the first of the second edition of the pitlane thread.
  6. #32766
    Island of Korcula
    Devcon steel putty was first to try and worked excellent, belzona 1111 same thing . Loctite is easiest to get around here
  7. #32767
    Jan has mentioned another one they used at Aprilia it was green and it even survived the cylinders being replated. It's mentioned on either the first of the second edition of the pitlane thread.
    The stuff was called Stucca Verde (green grout) but I don't know if that really was the product name, or just the description used in the racing department. In any case it was quite expensive and if I remember correctly, it had a limited shelf life.
  8. #32768
    Cheers Frits. I am not sutre about europe but those words make sense even here.
    We have stucco rendered houses and walls over here, plus the corrosion patina that gives aged copper its pretty colours is known as verdigris here, so those Latin types might be onto something with their words.
  9. #32769
    18th March 2013 - 04:44
    75 RD250b, 76 250C , 78 250E
    Poland
    Isn't it Army Painter ARM05007? It's 2 piece stuff turns green when mixed...
  10. #32770
    24th April 2016 - 19:07
    2001 zx9
    bop
    Ecobond (104?) used on alloy / magnesium castings on jet engines ... haven't seen it for years but i recall it being practically indestructable once its set. something like 4 or 5 hours at 200 degrees cure time. it was green. any current aircraft engineers on here?
  11. #32771
    For adjusting the roof angle of transfer ports, I always use Devcon Plastic Steel Liquid (B) 110210 because it flows enough to self-level.
    I set the cylinder upside down and tilt it so that the top of the port is at the angle I want, then drop the Devcon in and it (slowly) settles to a level surface.
    If I got the setup angle right, the roof is now at the correct angle to the horizontal.
    I don't know if any of the other steel putties have a "liquid" version.
  12. #32772
    Hysol ECCOBOND 104, short term up to 280C
    http://media.oem.se/Archive/FilesArchive/106826.pdf
  13. #32773
    pyro putty
    Pyro-Putty 2400 is a ceramic and stainless steel filled, high temperature, thermally conductive paste used to bond, seal and repair defects up to 3/8" in cross-section in cast iron, steel and stainless steel components and structures used in automotive, truck, marine, and industrial applications to 2000°F (1093°C).
    http://www.graphitestore.com/pyro-putty-2400-paste
  14. #32774
    If I had to choose between several kinds of epoxy, I'd select the one with a thermal expansion closest to aluminium and the lowest specific weight. The piston expands quite fast in contrast to more usual areas of application like for example crankcases.
  15. #32775
    First up, sorry for it being sooo long since my last post.
    My YouTube channel kinda blew up and I'm having a hard time keeping up with just the mails, messages etc.
    I know there's a few pm's I haven't gotten to here also.
    With my limited experience in diy plating most epoxies, suitable for cylinder work or not, would survive a strip+replate pretty well.
    Anyways.
    Currently at the airport in Denver Colorado, on my way back from my first attempt at racing at Bonneville Speedway(event got canceled, rain)
    We had a great time regardless, and now I have time to build a proper engine with my 100% width exhaust port cylinder on it.
    Going to run on nitromethanol, efi, throttle slide part of the rotary valve cover.
    Variator transmission electronically controlled.
    Need to read up on the do's and don'ts with fuel injection.
    Two strokes & rum!
There are currently 48 users browsing this thread. (2 members and 46 guests)
  1. jonny quest,
  2. Wos
