Thanks for the the advice!
I might try to make/modify something arduino based to suit my needs.
My constant load transmission should make for a really simple AlphaN map.
There's a few reasons I want to go EFI.
- As you stated it will self adjust to elevation/temp changes.
- I won't need a carb body hanging off the side of the engine - slide valve in the rotary valve cover.
- No vibration induced fuel foaming at higher rpm(float carbs)
- "ram air" should be possible/easier to do.
Yeah, I remember when I was experimenting with 30% nitro RC fuel.
On gas I ran a 110 main and 55 pilot, on RC fuel I ran 2.5mm main, 1.5mm pilot, drille out the pilot circuit, and a 1mm powerjet fully open.
Unburnt fuel was dripping out the exhaust at peak power.
Consumed about 1l in two dyno pulls.
I really like this solution but can't get pure nitro in Norway.
Fractional distillation of RC fuel is a possibility, but probably quite hard as the boiling point of nitro is very close to methanol.
Also Norwegian authorities wouldn't be too happy about it...
My break at work is over, I'll be back
Two strokes & rum!
Two strokes & rum!
Just thinking out loud here.
I might go no-intake-valve with this engine.
It's ment to run at a very narrow rpm range, should be possible to tune the intake duct to suit. Probably needs to be quite long - a good thing. Isolating the carburetor from vibration would be easy with a long softish rubber spigot.
Intake could be typical reed style behind the Cport pointing forward.(upside down engine)
Maybe I won't have to dive into Efi after all.
Could use a super simple flat reed block that pulls out of the way when on the pipe. Like a flat slide with reeds.
I would have room for a magneto ignition once again, something fierce that can cope with the alcohol/nitro, wouldn't have to be programmable either.
Like that one speed no intake old engine, going forward by going backwards...
Have to get this modeled up and see what intake length would work.
Two strokes & rum!
or run vairable rotary valve housing on one side of the crank case, and just a butterfly valve ditect into the other side, only opens at full throttle. A straight in hole, when the butterfly valve is open. Both sides of the crankcase get feed.
Yeah!
Only problem is it would make for a wider engine than with the "central" intake.
How about a small reed intake on the exaust side + a huge slide valve on the opposite side?
Would require injection or two carbs, but actually less complicated than the sliding reed thing. The big carb could be without a slide, no throttle control.
The small carb could be fed gasoline to get things going, then the big carb/injection would switch over to nitromethanol at wot.
Maybe not so good for cooling... Would make purging a breeze.
Two strokes & rum!
Respect Adegnes,, you sure pick a lot of fights to fight.
Almost that i wonder if you have a fetish to get beaten again and again. =)
With my one rpm constant load engine and a small carb taking care of of everything except WOT, efi could be REALLY simple couldn't it?
Just one injector in the intake duct, duty cycle controlled by temperature and air density.
No timing or anything.
Two strokes & rum!
Two strokes & rum!
Good idea Adegnes, I like it.
The carb could be a small but suitable size to get the engine up to speed and at the right RPM and WOT you could open a 24/7 inlet and have an injector squirt a predetermined amount of extra fuel. At 15,000 rpm the fuel might have to be delivered over two crank cycles to give the injector enough time to open, deliver a measured amount of fuel and close again.
The injector could be running a different fuel (say 30% nitro/methanol) to the carb which could be running plain Av gas.
A simple Arduino Nano could easily be trained to watch the rpm and throttle and open a 24/7 inlet at the right time and squirt a fixed amount of extra fuel.
I am building a F5 50cc road race engine that is just begging for a down draft resonant tuned length 24/7 inlet.
You have got me thinking about how I could apply your idea to my bike ........ it would solve a few EFI problems and with a tuned inlet length, add a bunch of power.
Two strokes & rum!
Or you could simply open the injector, and run it at 100% duty cycle, at the same time as the inlet and have the fuel flow controlled by an adjustable rising rate fuel pressure regulator. In other words the injector would be an on/off tap and the adjustable fuel pressure used to control fuel flow.
Or create a pool of petrol and resting in it a wick you could raise or lower in the airstream.
Whoops, wrong century.
There are currently 198 users browsing this thread. (0 members and 198 guests)
