Page 2194 of 2773 FirstFirst ... 11941694209421442184219221932194219521962204224422942694 ... LastLast
Results 32,896 to 32,910 of 41592
  1. #32896
    13th December 2018 - 18:06
    youtube andreas länström
    sweden
    I appreciate that Muciek.
  2. #32897
    21st March 2014 - 22:00
    Hanau, Germany
    Boysen Ports
    for anyone thats cut in boyesen ports on the yami twin. do you bother welding on any reinforcement to the rear outboard cyl ear to prevent cracking ? or its not a concearn ? maybe i should have reinforced that ear when doing all the other welding but i over looked it. now the final machining is done on the top and bottom decks, gasket thickness and cyl height position is sorted out. . even with bolting the cyl to a heat sink im not confident i could weld any reinforcement and not end up with alittle bottom deck distortion. part of me says go for it and it will be fine
    I only added some JB weld were I came through the wall, but no welding and it holds since years now...
Name:	Überarbeitete Zylinder 003.jpg
ID:	343472Click image for larger version.
Name:	Überarbeitete Zylinder 008.jpg
  3. #32898
    4th September 2017 - 10:39
    Daelim besbi 2008
    España
    PhD Thesis (Valencia)
    Is there an english version, too?
    I have no knowledge of whether it is in English.
    Google translate translate pdf
  4. #32899
    Daelim besbi 2008
    España
    Yes, GasGas are next.
    The enduro model will be the same as Husqvarna.
    The trial model how will it be?
  5. #32900
    17th September 2013 - 01:07
    SWE
    KTM buys 60% of GasGas.
    All ideas of why surfs the www at the moment.
    Wonder what effect it will have in the end?
    GasGas, with only 2 strokes in their lineup , seems to offer quite a descent bike with a really good suspension as stock.
    Don’t expect GG to keep the KYB if owned by KTM/WP.
  6. #32901
    19th June 2011 - 00:29
    Frits, here in your FOS data it says the squish angle in the RSA head is 8.17°
    if I draw that in solidworks, that's the angle of the tangent line to the piston radius. but wasn't the squish paralel to the piston crown radius ?
    and shouldn't the squish radius be 190.7 mm ?
ID:	343477   Click image for larger version.
Name:	sqiush angle.png
  7. #32902
    im sure it would be ok. i filled in the void with weld so it doesnt break through but i overlooked any type of reinforcement . i suppose maybe it isnt needed
  8. #32903
    has you guys seen this engine before ? says its aussie invention but i never heard of it
    https://motorbikewriter.com/aussie-t...oke-invention/
  9. #32904
    its posted in the odballs thread its been on this one too i think.
    https://www.kiwibiker.co.nz/forums/s...and-prototypes
  10. #32905
    Jan Theil, Frits Overmars, Wobbly.
    A question, as i got spaceproblems, is it a big loss shaping a pipe somewhat oval?
    I need clearance so i can have some suspensiontravel left.
  11. #32906
    14th April 2011 - 23:44
    2008 Yamaha fino
    Bangkok
    MZ once used them, but they cracked....
  12. #32907
    28th November 2013 - 21:58
    Dawes Jaguar
    UK
    Or you could simply open the injector, and run it at 100% duty cycle, at the same time as the inlet and have the fuel flow controlled by an adjustable rising rate fuel pressure regulator. In other words the injector would be an on/off tap and the adjustable fuel pressure used to control fuel flow.
    This bloke has hacked a pressure regulator to give a larger range of adjustment for alternative fuels.
    It is one of those weird engines with unported cylinder liners, sorry...
    https://courseware.ee.calpoly.edu/~a...nolMotorcycle/
ID:	343481   Click image for larger version.
ID:	343482   Click image for larger version.
ID:	343483   Click image for larger version.
  13. #32908
    http://www.pit-lane.biz/t6246p550-gp...vermars-part-5
    Go to the bottom of page 23. You'll have to login to see the images
  14. #32909
    He could also see what happened with the std ovalised TZ750 pipes.
  15. #32910
    8th November 2015 - 17:28
    1991 MZ 301
    Denmark
    Iam wondering why exhaust pipes are round or sligthly oval.
    The exhust jet during blowdown is some kind of rectangular and it will not be more difficult to edge weld four funny looking strips(methinks)?
