Page 2212 of 2776 FirstFirst ... 12121712211221622202221022112212221322142222226223122712 ... LastLast
Results 33,166 to 33,180 of 41629
  1. #33166
    13th December 2018 - 18:06
    youtube andreas länström
    sweden
    these albums
    No , page suggests to mind my business.
  2. #33167
    3rd May 2017 - 04:03
    1997 Yamaha rd 350
    Russia
    My ECU progress
    Almost ready ECU. Missed on-board MAP sensor (delivery delay)
  3. #33168
    8th July 2013 - 11:01
    2001, Aprilia, RS250
    Oz
    these albums
    If I click the links in your post, I can see the albums. But if I click the same links in Frits' quoted reply, then they don't work.
  4. #33169
  5. #33170
    sweden
  6. #33171
    these should work.
    They do!
    Right there is 100 odd albums in there
    https://www.kiwibiker.co.nz/forums/album.php?u=28036
    As Frits suggested i will be putting them likely into a cloud based file
    But keep them on your own hard disk as well. Remember:
  7. #33172
    They do!
    I had them and heaps more on an external drive that failed.
    So i can see what you are saying.
  8. #33173
    7th December 2013 - 00:25
    Yamaha's
    Hellas
    Hi,
    It has probably been discused here before,but I can't help my self from asking,so here it is.
    What's the effect of a steeper angle in header?
    Lets assume that we have an engine,and 2 almost identical exhaust pipes,2 headers at 32% as wobbly said,but one header has 3* angle and the second one has 3.5 or 4*,who is it going to affect power and power curve?
    Question number 2:
    Lets again assume we have 2 exhaust pipes,same header,same TL,same belly dia,but different diffuser angles,lets say in first pipe all 3 angles are close,but in the second one they are more "spread",with the first been the more shallow and the final diff been the steepest,how each one is going to perform?Who will the 2 differend diffusers spread the power?
    Here's an example,because I don't know if I made my point clear(english language is not my strongest point )
    PS:I know that probably it's been discused before,somewhere in these 2200+ pages,but I dont seem to find it,no matter what.So if someone has the link that I miss,share it ,if not I would really like to hear some opinions,especially from wob or frits!
  9. #33174
    Engines respond differently to diffuser and header angles , but a few points for you to note.
    If you have a 75% nozzle on the cylinder exit ( you haven't ) try dividing the header in 1/2 and running 3.2/5.2*.
    Having a longer and steeper last diffuser leading up to the belly adds power on the front side approaching peak. A steeper 1st diffuser adds power after peak.
    These designs are based on the old Honda published A kit info , they need a fatter belly diameter ( 125 at least ) and a steeper rear cone to go with that.
    The good thing is you can try all this easily in EngMod and rely on the results as long as the rest of the project inputs are real.
  10. #33175
    Quote Originally Posted by Lef16 View Post
    Hi Lef16 I used this search:-
    header cone angles site:https://www.kiwibiker.co.nz/forums/s...s-engine-tuner
    just copy and paste that line into Google to find a lot of references to pipe and header cone angles.
Name:	Screenshot (171).png
    The Google "site:" term before the KiwiBiker ESE threads web address is the way to find what you are looking for.
    Wobbly and Frits have posted so much info about pipe design on the ESE thread that it is now a total gold mine of expert info on pipes.
  11. #33176
    sweden
    Hi,
    Question number 2:
    Diffuser "horn coefficient" is the word you're looking for.
  12. #33177
    sweden
    I read a few places about the negative effects of fitting large diffusers to old style transfer design, it resulting in 'over scavenging' assuming charge is drawn to far or contamineted to be pushed back. And the villain should be poor tr duct design and not enough backward angling -but suction wave should not create any directed flow from the ducts, perhaps more eddying at most? The reason is rather the crank volume being to small to feed the greater wave?
  13. #33178
    28th August 2015 - 00:01
    1975 Hodaka Wombat
    Eugene, Oregon, USA
    With the few pipes I've built, I found that a relatively low horn coefficient (1.2) gave the best peak power. A little higher horn coefficient (1.4) worked better on a stock, piston ported engine with a relatively restricted intake port and transfers. Modifications to the intake and transfer width and timing eliminated this advantage.
    Lohring Miller
  14. #33179
    sweden
    I agree with that, makes me think advancing the diffuser might be a possibility.
  15. #33180
    You can move the diffuser forward to increase the negative pressure ratio sooner around BDC.
    This helps overev power - offset by the increase in front side by the steep last diffuser angle.
    Here is the new homologation R1 pipe for TM done in EngMod.
    Edited - wrong final pipe design
There are currently 172 users browsing this thread. (0 members and 172 guests)
