This look very good I think.
Making a bit of progress with the Kawasaki F81M inspired racer. Drilled and plugged the cylinder stud holes and relocated them to suit the Suzuki cylinder. The spacer plates will be screwed and glued to the cases and the cylinder studs will be threaded through them as well as the cases. If a KTM250 can make 48 rwhp then with methanol/acetone blend I am hoping to do much the same.
katinas.
This image is from the draft of the answer about the information they gave about a YZM, you will see that it is from 2005 and what I put in was:
"The only YZM of 2t that I know of aluminum are, those of Frenchman Jachy Vimond and Kurt Ljunqvist, who played the 500 World Cup of '87, the chassis was not deltabox but simple cradle unfolded at the height of the cylinder and lacked all those technological advances that count.
It is strange that because they steal the prototypes they lose all the technology, because I thought that this was reflected before on paper, which accounts have not applied anything "
They didn't put pictures like you and when you don't see things you don't believe them
Ceci,
Photos is from RACERS vol. 53. https://www.ebay.co.uk/itm/RACERS-Vo...UAAOSw4O9dxGrX
On 1991 YZM 250 they use Al frame more familiar to XXI century frames , but in 1993 they revert to steel on YZM 250.
Brilliant magazine, so much interesting small details in photos and Japanese language, with translator, gives even more interest. All issues with 2t racers very informative. Latest 54 vol. is first part about NR 500.
https://www.ebay.co.uk/itm/NEW-RACER...QAAOSw9-RdneEb
This is more about street 2t
https://www.neko.co.jp/magazine/2%E3...E3%80%80vol-19
In this image there is a sleeve that is connected to the crankcase.
TZ350: engine it has a similar one, but it is for the MAP
And plugged holes under B on Aoyama s 2009 Honda RSW 250 engine.
Wiring complete.
Now to program some computers, 1x ignitech, 1x Link.
Best its going to get
i thought i read the yzm 500 was only used two years on works bikes. sounds like only eight were ever made
https://motocrossactionmag.com/amp/1...inum-was-cool/
There are currently 82 users browsing this thread. (0 members and 82 guests)
