Page 2231 of 2776 FirstFirst ... 12311731213121812221222922302231223222332241228123312731 ... LastLast
Results 33,451 to 33,465 of 41626
  1. #33451
    The answer is in previous post about SwePatrick new project TZR 250cc 56/50 bore stroke engine.
    "As my classrules says max 212cc i´m thinking about put thicker liners in them and run 50/50 bore/stroke and get ~196cc and a lot of material to bore if needed." until max 51.9mm bore for 212cc rules if liner wears out or damaged.
    got it, thanks!
  2. #33452
    My take SwePatrick would be to go square as you are planning - gives real rev potential with the already short stroke ,plus easy optimum STA values , but then fit alloy liners that are easy to port.
    Weld them in at the top and bottom ( easy ) then Nicasil them.
    Much better heat transfer and no wear issues with resulting overbores.
  3. #33453
    Corking crankshafts. Need to “stuff” a crankshaft. 4 holes at Ø24. Champagne corks seem to be the go as the size is ok and it’s not even a problem getting them. It’s a low speed mundane application.
    So after the heating them up in hot water so they’re soft and then pressing them in, there is a question. Should they be treated in any way (eg a sealant) to prevent fuel/oil attacking the cork?
  4. #33454
    Soak em in alcohol for a year...........
  5. #33455
    TM MX cranks use cork and a thin layer of two pot epoxy is used to seal over the exposed surface.
  6. #33456
    Happy New Year to everyone!
    Anyone else going to attend the two-stroke engine conference in Paris mid February?
    2-stroke engine conference
    Edit: you can also download the 2018 presentations here
    The presentations of this year's event are available for download now - click this text.
  7. #33457
    26th April 2013 - 21:55
    BMW R1200R 2009
    Thank you for the link. The presentation in session 3 about the opposed piston engine (Turner and Vorraro) whas very interesting !
  8. #33458
    8th November 2015 - 17:28
    1991 MZ 301
    Denmark
    Thank You for link.
    The paper from Brunel university about opposed piston two stroke mentions a lapsed 2013 patent from lotus about having a generator on each crankshaft and no mechanical connection.
    I made and ran such a system in ca1994.
    There is a gentleman from Austria Graz who find that a side-exhaust-valved two stroke can be awfull good for range extension of electric cars.
    I described it around may 2014.
    It proves that being an inventor is not getting You fame and fortune but it is a nice feeling anyway.
  9. #33459
    Thank You for link.
    T.
    I am confused by the mention of the lotus engine
    As magnetuic drives have been around for years, my aquarium had one in the 90's.
    Was it done somehow differently?
  10. #33460
    Uniflow, so last century.
    Three main issues as I see it.
    scavenging system
    combustion chamber
    exhaust piston thermal loading.
    Uniflow scavenge, who would have thought.
  11. #33461
    Thanks for winter without the snow, for the first time, it is possible to test many things on the road.
    With direct to transfer intake scheme on Honda NS engine some very interesting engine reactions to some changes. Too many tests with different combination and it is very complicated transform all things in words, so I just put main things in graphs, but maybe it looks even more complicated.
    Exhaust pipe and cylinder head is the same for all main tests.
    In general, the biggest surprises was Type 2 mid range torque from 6000 rpm . with the exhaust pipe that mainly works from 9000 to 13000 rpm. Never feel that power at lower revs with this engine before, feels like with exhaust power valve. But Type1 with side reed petals always strongest at higher revs, especially in range from 12500 to 13000rpm. Thicker side reed petals works without any damage (0.5 mm)
    From other engine reactions, looks like for midrange torque, it is very important at witch point intake tunnels is connected to transfers ports, as pressure fluctuation accumulated pressure at both transfer port ends. Maybe this explains very low Rygeriser type torque at midrange (not only because of reduced intake capacity as I think before).
    Tested with two different cylinders and three different pistons.
    Cylinders
    1. The same as previous posted with bronze liner and side reed petals
    2. Original with nicasil plating, just intake windows are fully blocked with Loctite EA3479A ( add photo), all intake flow through enlarged side boyesens tunnels. Additional carbon plate, with reed petals on it, between cylinder and crankcase, as very complicated to add side reed petals on std cylinder because of lower side cuts.
    Pistons
    1. Special with deep side cuts and wide exhaust side skirt for two or three exhaust windows
    2. Special with deep side cuts and narrow exhaust side skirt for one exhaust window
    3. Normal piston ( from CR 125 2006 big bore 57mm)
ID:	344910   Click image for larger version.
ID:	344905   Click image for larger version.
ID:	344906   Click image for larger version.
ID:	344907   Click image for larger version.
ID:	344908   Click image for larger version.
  12. #33462
    With additional intake widows under main A,B it is possible to use normal piston, so no needed spec custom piston with side pockets. With these widows it is possible to use wide, two or three exhaust ports.
Name:	Compensation intake window under A to work with wide exhaust side skirt spec piston usable for w.jpg
ID:	344919   Click image for larger version.
Name:	Wide intake window under A  for working with std normal piston.jpg
ID:	344920   Click image for larger version.
ID:	344921   Click image for larger version.
  13. #33463
    24th February 2013 - 08:12
    1993, suzuki rgv250
    Very interesting. Maybe combination carb diameter, inlet length and total volume in the transfer channels are very important in your concept. Too big transfer channel volume will not create enough suction and inlet air speed to allow piston to compress air at the same time as flow continues through inlet. Too small transfer channel volume, too big carb diameter, will not keep air speed up into transfer channels when piston moving down to compress, giving less total air in. At higher rpm relatively small transfer channel volume holds back the exhaust from entering too deep into transfer channels but the exhaust pressure compresses the fresh air there. While some exhaust is occupied with compressing the transfer channels the rest is going out through exhaust port and most of the fresh air hold back and will later not have time to escape out. A three windowed exhaust port should maybe be a bit lower then? Just a thought..
  14. #33464
    Thanks for the interstign insights, katinas!
    It would be really really cool - and I guess pretty helpful for your research too - if you had a dyno!
    In case you need assistance building one yourself, let me know.
    You can also use a road dyno, which gives pretty accurate results if you use the same part of the road for all of your tests (numbers will be relative, but the shape and if it's better than before is what counts anyways).
    click here for a link to a free road dyno, description below:
    GSF Dynamometer software in combination with a commercial sound-recorder allows for making power/torque curves of a motorcycle (or car). Dyno runs are done (recorded) on the street and analysed on the PC at home. Dyno runs are essential for tuning and correct jetting of the carb. Here you found the minimum-cost dynamometer. All you need is to download the dyno software, a sound recording system and I suggest to build the voltage divider as described below.
  15. #33465
    ... It would be really really cool - and I guess pretty helpful for your research too - if you had a dyno! ....You can also use a road dyno, which gives pretty accurate results if you use the same part of the road for all of your tests.... click here for a link to a free road dyno, description below:
    I fully agree
