Page 2234 of 2773 FirstFirst ... 12341734213421842224223222332234223522362244228423342734 ... LastLast
Results 33,496 to 33,510 of 41594
  1. #33496
    I did not know Honda also had seals with coated lips. I thought it was just a Yamaha thing as my Kawasaki and Suzuki's did not have them.
    One of the issues I found with Yamaha coated seals was that they would curl up in the presence of Acetone. So when I ran my 50/50 mixtures of Acetone and Methanol I had to run Suzuki crank seals.
    It would probably be a good idea to soak the seals overnight in a jar of whatever fuel mix you are going to use, just to check the seals compatibility.
    Should be OK. Being a good law-abiding bucket racer, I only use 98 pump gas. Don't think there's any acetone therein.
  2. #33497
    Team ESE use fresh Av gas in their 2T Buckets because it is reliably consistent and so I have no real experience with 98. But I would be very suspicious about what sort of concoction is in it to achieve that 98 rating because it smells very nasty. I would definitely soak test the coated seals myself. Test is always best.
  3. #33498
    Pretty sure there is a good % of toluol/toluene. A very good solvent.
  4. #33499
    35%. that's why you can smell paint thinners when you first fire it up in the morning. It's only REALLY toxic so should be avoided if possible.
  5. #33500
    Top tip: run some oil in there too. It helps lubricate the piston and the various crank bearings.
    Don't mention it.
  6. #33501
    Don't mention it.
    I think there's some oil in the gearbox. Does that count?
  7. #33502
    If you nick the seal it might be like autolube.
  8. #33503
    The crank flapping around in the seal acts like an oil pump and will pump oil from the gear box. Its a problem with our GP's. Not sure if its poor crank alignment, the GP crank flexing at 12,000 rpm or the C3 bearings allowing the crank to hop up and down. But it will shift most of the gear box oil in a days racing.
  9. #33504
    I'm pretty sure the Viton slipped seals are primarily used for lower friction benefits.
    TZ350, didn't I see a post of yours years ago where you did some seal friction experiments?
    RS125 bulletin even mentions removing one of the seal clips for less friction I seem to recall
  10. #33505
    AFAIK Vitron is used as its one of the more durable rubbers in contact with fuel and solvents and wear. Its used on fuel needle tips as well
    Teflon is a low friction seal.
  11. #33506
    Wow. Never seen that on my Hondas. Must be a Suzuki thing...
  12. #33507
    6th February 2012 - 08:54
    1988 cagiva freccia
    france
    the material of the seal must be adapted to the linear speed of the shaft.
    nbr is not suitable for high rotational speeds. the lips are burnt.
  13. #33508
    Ready to start, at last. Just got to sort through this LINK, so different to what Im used to, way more complicated than the Atom.
ID:	345097   Click image for larger version.
  14. #33509
    3rd May 2017 - 04:03
    1997 Yamaha rd 350
    Russia
    Need top end bearing advice. Wgat is better for performance and longevity
    Hello All
    I have pistons with 15mm crank pin and Suzuki AX con rods with d=18mm 18mm wide upper hole
    https://www.royalrods.com.tw/suzuki-...d/RS-3012.html
    Engine revs up to 8500 and have 15hp
    What is better
    - just put in gap 34 of 1.5mm needles as on outboards (gap about 0.024 needle to needle)
    - use 15x18x22 bearing cutting inside piston from 19 to 22.5 mm to fit it
    - make custom separator
  15. #33510
    10th February 2005 - 20:25
    1944 RE 1
    Auckland, New Zealand.
    Getting there! - You are going to overtake John Britten soon with your artistic exhaust efforts !
    Strokers Galore!
