Page 2237 of 2776 FirstFirst ... 12371737213721872227223522362237223822392247228723372737 ... LastLast
Results 33,541 to 33,555 of 41632
  1. #33541
    24th January 2014 - 08:12
    1988, Yamaha RD350 YPVS
    The best way to look at a turbo is to consider it a device that increases atmospheric pressure. Then all the requirements at 1 atmosphere are still there at higher atmospheres.
    Thank you Neels :-)
    A question I always had: Will supercharging a rotary inlet 2 stroke work? I was always sceptical in terms of rotary valve wear.
    But since the turbocharger is shifting the median pressure everywhere inside the engine, the pressure difference crankhouse to intake manifold might remain the same?!
    A friend tried it with a VW smoke pump roots on a 100cc kart engine - that did not work with a short manifold due the pulsation of the roots compressor. Has anyone tried this with a decent volume between supercharging device and rotary plate? Flettner by chance?
  2. #33542
    Here you go. Original 26hp Sporty 125cc two stroke turbocharged complete with expansion chamber.
    Basically they just doubled the hp by adding a Turbo. They got 53hp at 11,000 rpm with 1 bar boost.
    Guess who at Team ESE wants to turbo his 2T ...... ... me me me.
  3. #33543
    This is a good look at their 50cc version.
    19.6 hp at 11,931 rpm, low boost. As 15,000 rpm is easily possible and higher boost there looks to be plenty of potential.
    The particular racing class that Team ESE are involved in allows for turbocharged 70cc water cooled two strokes.
  4. #33544
    28th August 2015 - 00:01
    1975 Hodaka Wombat
    Eugene, Oregon, USA
    And then there's a really serious turbo engine with maybe 800 hp on nitrous:
    Lohring Miller
  5. #33545
    4th December 2011 - 22:52
    Yamaha XJ750 1982
    South Africa
    Lohring Miller
    Lohring, I have a number of photos of that sled but no info on it running. Do you know more?
    Neels
  6. #33546
    Lohring Miller
    How do they not melt the pistons?
  7. #33547
    25th August 2010 - 04:40
    RD350 YPVS F2
    Europe
  8. #33548
    18th March 2013 - 04:44
    75 RD250b, 76 250C , 78 250E
    Poland
  9. #33549
    How do they side step physics, all that extra thermal load. Aluminium pistons would surely have long vaporized within seconds.
  10. #33550
    21st June 2012 - 14:20
    1974 Yamaha RD250
    Camden, S.C. USA
    Perhaps lots of extra fuel and water injection like the Reno Air Racers have used forever?
  11. #33551
    Methanol I guess and as you say lots of it. Hardly practical for an off road enduro bike. Or does this mean we need to use really small engines.
    Never the less, impressive performance, I'd like that next time I come up a 450 in a drag race out of a corner. 😆
  12. #33552
    now just to join the drive shaft.
    Drive shaft sized to handle turbo charged twostrokes in the future.😆
  13. #33553
    And not to forget the picture.
    Looks like I might have to raid the backup scrap heap.
  14. #33554
    Running on Nitrous simply increases the combustion pressure , as its effectively air and fuel mixed together.
    The combustion temperature could essentially be exactly the same - thus no reason to melt anything.
    And as we have talked about before the mechanical forces on the crank and piston increase as the square of rotational velocity and are several orders of magnitude greater than combustion forces
    pushing down on the piston.
    So as I have been saying for years , you could double the power of most any engine and if its not reved any harder its inherent reliability isnt affected ( apart from ring pressure on the bore ).
  15. #33555
    Now we mean business.
