Page 2245 of 2773 FirstFirst ... 12451745214521952235224322442245224622472255229523452745 ... LastLast
Results 33,661 to 33,675 of 41590
  1. #33661
    Personaly I'll go back to the bucket foundry, probably where I should be I guess, there is a lot of pattern and foundry stuff comming up anyway.
    Pity about the weather.
  2. #33662
    10th February 2005 - 20:25
    1944 RE 1
    Auckland, New Zealand.
    Yes Folke,
    I agree with Frits and can't see why you are in the bad books?? - I don't think there were any laws - it was just me talking about the other threads which were petering out and I have been trying to keep them going for a while now - nothing more than that - no laws or even any restrictions involved! - Kiwi biker is sort of self moderated with only the occasional input by moderators! - I'm not a moderator or anything else but just like to keep things going!
    We have been enjoying your contributions so don't go away! This thread has done everything 'two stroke' for yonks, it has survived many ups and downs and will no doubt do so again! - At the moment this is THE two stroke thread so we're all here - the other two threads have ground to a halt - but who knows what will happen after the "virus" has settled down - just keep going! - don't need to be sensitive - look at me, I have managed to talk all sorts of crap, for years - (Frits, Flettner and Ken etc. think so) yet I still have the gall to stay here! ..... and you were doing so well - I thought!
    Strokers Galore!
  3. #33663
    1944 RE 1
    Who would have thought it! ..... but the future of the two stroke may be huddling under that tarp - can't wait for the unveiling!
    Strokers Galore!
  4. #33664
    It is all Ok by me. I only get to play with 2T Bucket stuff because that is what we have.
    But others are playing with other 2T stuff because that is what they have.
    In the end its the playing with 2T stuff and showing it to all of us that I think is interesting ..... .
    And between us, by some miracle we may even resurrect 2T's.
  5. #33665
    1944 RE 1
    Yep, good to hear that - Oldies need to survive the virus to resurrect the Two Stroke! - otherwise it will be totally forgotten! (not that I think you're old Rob!).
    Strokers Galore!
  6. #33666
    Well, with all this talk about turbo 2T's the other day, I got over exited and brought a small RHB31 turbo.
    Then I discovered on Wikipedia talk about compound turbo engines where the exhaust turbine is directly connected to the crankshaft instead of a compressor impeller.
    "" (From Wiki) A turbo-compound engine is a reciprocating engine that employs a turbine to recover energy from the exhaust gases. Instead of using that energy to drive a turbocharger as found in many high-power aircraft engines, the energy is instead sent to the output shaft to increase the total power delivered by the engine. The turbine is usually mechanically connected to the crankshaft, ""
    Now that has got me thinking. I have a spare turbo turbine. And with a one way clutch and reduction I could attach it to a 2T engine. It could be geared onto the clutches big primary gear. I wonder what our F4 race rules say about it. Not much by the looks.
    Hmmmmm a grey area I might be able to exploit .......
  7. #33667
    All this has re ignited my interest in a turbo charged Crecy two stroke sleeve valve engine for Bucket racing.
    https://ww2aircraft.net/forum/thread...e-crecy.50534/
  8. #33668
    here is one, open ended sleeve like Crecy
    https://youtu.be/bwsu5td6nko
    https://youtu.be/6keqpL3rmwk
    https://youtu.be/TmXFkbD3s5g
ID:	345452   Click image for larger version.
  9. #33669
    Some more work in progress photos of Flettners Crecy sleeve valve engine.
ID:	345455Click image for larger version.
ID:	345456Click image for larger version.
ID:	345459Click image for larger version.
    I am not sure if these two casting pictures are Crecey but they show Flettners foundry handywork.
ID:	345458Click image for larger version.
  10. #33670
    4th September 2017 - 10:39
    Daelim besbi 2008
    España
    Hi Folke
    Your experiment is of great interest to me, since you published the photos I have not stopped analyzing them and trying to understand the mechanism (for now with more mistake than success).
    The last conjecture on how it works and tried to capture it in these drawings:
    In drawing 1 we have a cone that corresponds to the back pressure pulse focused towards the exhaust port.
    In drawing 2 we have the cone and the exhaust nozzle.
    In drawing 3 in this we see the part of the back pressure cone that is added to the exhaust outlet nozzle.
Name:	cono del pulso.jpg
ID:	345461   Click image for larger version.
Name:	cono pulso  y tobera escape.jpg
ID:	345462   Click image for larger version.
Name:	cono pulso sin tobera escape.jpg
  11. #33671
    UHV 1
    For some time I have had the idea that one could feed the cylinder in a supplementary or totally different manner than using the side transfer ports. So, without going thru the piston (Frits April 1st) the only other way is via the head.
    No camshafts or any of that 4 stroke stuff. Gotta be passive. However, the old 100 year old sprung loaded poppet valves don’t seem appropriate. So, it is a reed valve. Where to put it or them? Seeing reeds wouldn’t like non flat surfaces, the only logical position would be is the in a flat squish area. Something like this:
    More to come
  12. #33672
    23rd December 2018 - 22:33
    KR1S, KX500, gamma500, tomos
    Island of Korcula
    Ken, this would be backwards-uniflow scavenging?
  13. #33673
    Anyone seen or plotted the ignition curve for a late model KTM125.
  14. #33674
    Daelim besbi 2008
    España
    UHV 1
    More to come
    Hi Ken
    Let me remind you that there are always two limitations in any project: 1º those of the prototype's architecture or geometry. 2º the appropriate materials.
    In the project you are showing I believe that the limitations are of the 2nd, because what material supports temperatures and also maintains elasticity (I tried to look for it since, as you can see, I also thought this solution).
    His approach is excellent
Name:	laminas escape  horizontal.jpg
ID:	345469   Click image for larger version.
Name:	laminas escape inclinada.jpg
  15. #33675
    I guess pulse jets bathe their reeds directly against the fire.
There are currently 18 users browsing this thread. (1 members and 17 guests)
