Page 2250 of 2773 FirstFirst ... 12501750215022002240224822492250225122522260230023502750 ... LastLast
Results 33,736 to 33,750 of 41594
  1. #33736
    3rd May 2017 - 04:03
    1997 Yamaha rd 350
    Russia
    lightweight liquid cooled cylinders
    Hello guys
    Could you recommend 70...125cc very light cylinders capable produce 13...17 hp for a long time permanently.
    Says for 30 minutes+
    I want to make 2-cylinder 25hp + engine which should weight no more than 7,5 kg complete with radiator end exhaust
  2. #33737
    23rd March 2015 - 21:24
    Conti RX356 V3
    Did you check the Airsal range for Derbi Euro 2 or 3 engines? Plenty of options reg bore/stroke and everything above 70cc should be able to produce the power you are looking for...plus they are cheap and readily available.
  3. #33738
    21st March 2014 - 22:00
    Hanau, Germany
    How far should I go?
    Can someone help me with that problem: I'm preparing RZ cylinders to get aux ex ports in to increase the blow down. The currently mounted Woessner piston has cutouts to reduce the weight. So how far shall I go with the aux ex port? Going to approx. the middle of the bore I would gain more blow down than going only until were the cutout starts… So will the higher blow down eaten up by the short circuting with the Transfers?
ID:	345803 Click image for larger version.
ID:	345804 Click image for larger version.
  4. #33739
    The blowdown will be fine Jürgen. But before the exhaust ports even start to open, there will be a massive short-circuit between the transfers and the auxiliary exhaust ports. So forget about using those pistons in combination with aux ex ports.
  5. #33740
    Interested to know how you were going to get around the cotton reel powervalve? Also the aux port looks as high as the main which for much of the time will be lowered by the pv. On a steel bore you will need a thicker bridge than you would get away with with plated.
  6. #33741
    What they said before me - except to add that having the Aux at the same height as the main is never a good plan.
  7. #33742
    Hanau, Germany
    The cylinder in the left picture with the wide aux port was a trail on an damaged one to see how to do the porting. The cylinder in the middle pic is the one I work on currently. I'm aware to have the aux ports lower, I have them approx. 2mm lower than the main.
    So Frits would you think the samller aux ports (which do not go into the cutout) would be a problem? Of course depending on the budget of my finacial minister I will get some new pistons somewhen…
    @Dave: I have attached some pics how the porting looks like currently incl. the modified / (rough) cutted bushing of the inner side. This is not the final version, I will modify the bushing (with the "nose" as the mounting point) to get the "channel" done. The bridge between the aux and the main port is approx. 5mm thick.
ID:	345814 Click image for larger version.
ID:	345815 Click image for larger version.
ID:	345816 Click image for larger version.
  8. #33743
    1997 Yamaha rd 350
    Russia
    Thanks. Still estimating. One friend suggest me
    to use a 50cc cylinder "bigbored" to 95cc or 100cc (52mm) with 44mm stroke
    Are there are racing scooter engine called Malossi C-One / RC-One, it use "flange" style cylinders like racing motorbikes.
    the 95cc cylinders are 24-26hp peak power, the lightest seems the Stage6:
    it seems very small cylinder to be a 95cc
    https://www.motoscoot.net/cilindro-m...ulon-14mm.html
    I want as well try Vespa 125 cylinders cutting of some metal to make it light
    Are there another brands like 2fast
    https://www.scootfast.net/2fast-cyli...crankcase.html
  9. #33744
    I can't see a problem with that, except that you will be very limited in the width of those ports. Maybe you can enlarge them afterwards, when your financial minister approves the purchase of decent pistons.
  10. #33745
    Hanau, Germany
    That's the plan...
    Would you go up to approx. the middle of the bore even with that "large" 66 mm bore? Of Course that will increase the blow down dramatically on the engine, I need also to check and balance the transfer TA's as also a bit limited in the width… Neels software will help.
  11. #33746
    if your just wanting a common 64mm yami banshee style piston then you could use wossner 8075da. theres no pin cutouts at all. but its a bit heavy so you might want to machine off some material from the underside.
  12. #33747
    I'm surprised there was room there. Might be a little soggy in the middle but so what. Be interesting what effect it has. I've added auxiliary to my MB100 race bikes on a few cylinders.
  13. #33748
    That's the plan...
    Is a 66 mm bore large? Wärtsilä mechanics will disagree, and I would say large is a rather undefined term. If you have sufficient material in the right places, and good quality piston rings, extending the auxiliary exhaust ports to the middle of the bore shouldn't be a problem.
ID:	345820 Click image for larger version.
Name:	Wärtsilä-Sulzer RTA96-C.png
    Most of a piston's mass is concentrated between crown and piston pin holes, so if you want light pistons, try to find pistons with their pin holes close to the crown.
    Maybe Yamaha TZ750-pistons could be an option. They have a 66,4 mm bore, so if you have a big enough hammer, they should fit
  14. #33749
    Hanau, Germany
    Jeep, you are right that are really big engines, our company will supply the catalysts in future, that will be a nice business. Maybe we will sell only for 2 or 3 ships per year, but the volume….
    I will talk with Woesser what they have, I need the piston for the 115 mm rod either, so let's see. And material for the wide aux ports is there, so let's see.
  15. #33750
    22nd September 2012 - 16:31
    1995 kx 125
    Blowdown
    Been a while since I been on here.
    I still fiddle around with 2 strokes time to time.
    This last time I really wanted up my power on the newer ktm 85. No small feet. I was already at 29ish hp. Up from 23. So I flowed the cylinder on my flowbench and redid the exhaust tunnel with clay to find the optimum shape.then welded it and it is pretty much right on size to eng mods rules in sim and I found the cfm as well on the bench. But yet no more power with close to my usual port timings. Of course I tried many things. Had adj ign box as well . Of course next time I will probably do the tunnel 1st. Before grinding to my usual timings. And I am guessing results will be different. What do u think wob?
There are currently 216 users browsing this thread. (0 members and 216 guests)
