Page 2252 of 2774 FirstFirst ... 12521752215222022242225022512252225322542262230223522752 ... LastLast
Results 33,766 to 33,780 of 41608
  1. #33766
    3rd August 2012 - 02:39
    yzf 250
    holland
    Nearly all the ktm's have that issue (2 stroke )
  2. #33767
    23rd March 2015 - 21:24
    Conti RX356 V3
    did you do any changes besides ignition and exhaust to get to ~29 hp? friend of mine has a standard 85SX and dynoed it at ~20 rwhp (which was quite disappointing) but ran out of time to jet it down...
  3. #33768
    22nd September 2012 - 16:31
    1995 kx 125
    I've been modifying these sense 2010. 0r 09
    I changed just about everything mentioned in these 2500pages. Pipe and ign will get you little over 24hp.
    If you didnt have time to lean it. 21hp is normal. Evertime i.put one on the dyno I tried to improve over the last one
  4. #33769
    piston ring, what would one make it from, nitrided P20?
    Or high speed steel, hard chrome wear surface. Or would just 4140 be suitable? Nitrided.
  5. #33770
    11th November 2011 - 12:15
    93 kx500
    Aus
    What dimensions do you need?
    Going by past history i'm guessing this isn't going to be a conventional ring..
    Can you modify an existing ring?
  6. #33771
    77mm larger dia. I see I've made the ring groove 2mm wide, not sure what I was thinking here. Could be I was thinking two 1mm rings side by side. Although It doesn't get the same acceleration / deceleration as a normal ring, mass not so important so probably a single ring will fit the bill.
  7. #33772
    93 kx500
    Aus
    Some of the foulstroke 250 mx bikes are 77mm, but have a 0.8mm ring. KXF, RMZ and YZF.
    Honda has 78mm and 79mm but i assume also 0.8mm.
  8. #33773
    93 kx500
    Aus
    After a quick google there is other options:
    Honda GX270 is 77mm and 2mm.
    also a VW engine is 77mm.
  9. #33774
    what are they made of? Cast iron I'd assume.
  10. #33775
    old mitzi colts are 76.9mm and 2 mill
    citreon as well
    fiat 1500
    Honda 76.9
    mazda 1500 "323 1490 i think"
    some mercs have 2.5mm
    https://www.hastingspistonrings.com/...log_master.pdf
    http://www.mingyang-group.2u.com.tw/pdf/CAPT-Piston.pdf
  11. #33776
    No matter what I use Im going to have to re manufacture it anyway, so why no start fresh. Surface has to be curved / spherical and it needs to be hard, like a nitrided surface. So I'd guess steel, not cast iron. It will run against a cast iron 'sleeve' as it were. Nitride surface is in the order of 70R surface hardness and slippery but only microns deep.
  12. #33777
    yzf 250
    holland
    Working on the tunnel on stock cil.
ID:	345855   Click image for larger version.
  13. #33778
    1995 kx 125
    how much blowdown sta did you start with? stock amount?
  14. #33779
    1995 kx 125
    work the subs, theres more cfm there, not much, but some
  15. #33780
    yzf 250
    holland
    Copy and scale the bidalot 50 cc exh. tunnel
    Later 193 deg exh.duration ( Green on the dyno grafiek )
