Page 2253 of 2776 FirstFirst ... 12531753215322032243225122522253225422552263230323532753 ... LastLast
Results 33,781 to 33,795 of 41632
  1. #33781
    did you guys see this? supposedly a sucessful way to weld 7075. now where the hell do i buy the filler rods
    https://www.repairerdrivennews.com/2...7075-aluminum/
  2. #33782
    How things change with time.
    Central spark plugs....gone.
    Tight squish....gone
  3. #33783
    23rd March 2015 - 21:24
    Conti RX356 V3
    Copy and scale the bidalot 50 cc exh. tunnel
    Later 193 deg exh.duration ( Green on the dyno grafiek )
    the Bidalot does a lot of things right...great cylinder out of the box.
  4. #33784
    3rd August 2012 - 02:39
    yzf 250
    holland
    Got that cil.from 19 hp to 22.7 hp changing exh.tunnel and new pipe
  5. #33785
    Ok, there is a bit missing.
  6. #33786
    22nd September 2012 - 16:31
    1995 kx 125
    i figured results be different with a stock cylinder.
    19 to 22.7 ? i thought you started at 23.3 or something.
  7. #33787
    Conti RX356 V3
    he's likely talking about the Bidalot 50cc cylinder (at least that one has ~19 HP stock).
  8. #33788
    yzf 250
    holland
    tdc211 ( Got that cil.from 19 hp to 22.7 hp changing exh.tunnel and new pipe )
    Last post is from Bidalot 50cc cil.
  9. #33789
    10th February 2005 - 20:25
    1944 RE 1
    Auckland, New Zealand.
    Yes Ken, some info missing!
    Strokers Galore!
  10. #33790
    1995 kx 125
    22.7 out of a 50? At what rpm?
  11. #33791
    Conti RX356 V3
    Standard (incl. their exhaust) they make ~18-19 HP peak at ~13.500 1/min.
    I'll start dynoing mine on Saturday, also testing a much shorter exhaust since I think the layout must have massive reserves reg power if it makes 19 HP at such "low" revs.
  12. #33792
    yzf 250
    holland
    Kreidler Rotary
Name:	will 24-3-20 uitl.jpg
  13. #33793
    1995 kx 125
    Kreidler Rotary
    i see, that is some power
  14. #33794
    And some revs. Sheesh, I spent so much time with clearly a false rev ceiling based on RG50 in the 90s much past 12,000 killing cranks. I thought 13-14 was getting up there.
  15. #33795
    Conti RX356 V3
    The modern cranks will last 40-50h on a 50cc with roughly 18 HP with overrev up to 14.000 1/min under racing condition...
    We won that race with a 20h old crank 😁 https://youtu.be/KR-R6G76_i4
    @dutchpower: care to share the changes in detail (exhaust channel and exhaust measurements)?
