Page 2260 of 2775 FirstFirst ... 12601760216022102250225822592260226122622270231023602760 ... LastLast
Results 33,886 to 33,900 of 41611
  1. #33886
    There are two answers , the first is if hollow dowels are used to locate the head or cylinder.
    In this case having the thread bottom , and "lockup " is fine.
    Without dowels , many companies use the unthreaded portion that locks in the top of the thread , to also locate the sliding component.
    In my book a pair of hollow dowels is mandatory good practice.
    Honda have used an extra pair of small solid dowels as well , but I believe in KISS like Frits.
  2. #33887
    RIP Auckland track. Just read on Stuff the appeal failed in court.
    Axe has fallen.
    Sorry to hear you Auckland guys.
  3. #33888
    28th August 2015 - 00:01
    1975 Hodaka Wombat
    Eugene, Oregon, USA
    I don't know about engines, but I often used shoulder bolts to locate components in tooling. The precision shoulder portion locates the components. It's a lot quicker and easier than separate holes for dowels.
    Lohring Miller
  4. #33889
    7th May 2016 - 04:34
    1980 Peugeot 103
    Colorado Springs, CO, USA
    Not sure if this has been shared yet, but figured it might be interesting to some of you guys... I've been on the Megasquirt forums lately, and someone there has been working on EFI for his 2-stroke converted EX500. He couldn't share details until he applied for a patent (patents?), but he recently submitted the application(s), so he is now free to share some details.
    He just released this video that shows things pretty clearly:
  5. #33890
    Quote Originally Posted by mantonakakis View Post
    ...He couldn't share details until he applied for a patent (patents?), but he recently submitted the application(s), so he is now free to share some details.
    I wonder what he hopes to patent. In the video I haven't seen anything that has not been done before.
  6. #33891
    24th February 2013 - 08:12
    1993, suzuki rgv250
    It will take about 18 months until the application is public to see what of the engine that he claims. Respect to all of the work and thought put into it. I wonder if it is (yet) sort of "balanced" from the inlet to outlet to be a really high performer?
    BTW, KTM is still working on to have their patent applications on the TPI granted. Not always so easy..
  7. #33892
    Yes, its hard to patent something that has already been done.
  8. #33893
    1980 Peugeot 103
    I currently work in the freight railroad industry, but not with locomotives. I work at a large test track, so I although I don't work with those big diesel engines directly, I've seen enough components laying around the place to see quite a few similarities... although the cylinder liners I see at the test center are the size of my torso!
    EDIT: Here's the thread on the Megasquirt forums, there's a little bit of discussion/description going on later in the thread:
    https://www.msextra.com/forums/viewt...?f=101&t=72623
  9. #33894
ID:	346124 Click image for larger version.
    Kawasaki EX500 55 RWHP @ 9500 RPM in 4T trim. I am not sure why you would want to convert it to a modest performance 2T.
    Great bit of work though, impressive devotion to the mission. It is exciting to see these new engines and I would love to know more about any real advantages the constructor has found with his prototype.
  10. #33895
    Have to agree Frits, lots of design features seen elsewhere, even one starting with an R. Mind he put in a great effort, both in the detail design, manufacture and recording. Quite complex compared to either a 4 or 2 stroke. Interesting the primary header lengths are different from front to back.
    The thing runs & idles, sounds smooth. However, it did have the characteristic failing: 4 stroking at low speeds = unburnt fuel = unburnt HCs = emissions = sadness. Still, this could be a simple mapping thing.
  11. #33896
    i had a quick look and the valve timing is also (from what was in one post before i got distracted by work)different front to back.
    i noticed that as well the the 4 stroking (too rich on the pilot electronics)different note though 4 stroke then and falling to a two stoke down low or on overrun with the normal off idle woollynesss
  12. #33897
    4th December 2011 - 22:52
    Yamaha XJ750 1982
    South Africa
    I asked him what is different from the Ryger concept but did not get a real answer.
  13. #33898
    4th September 2017 - 10:39
    Daelim besbi 2008
    Espaρa
    What is missing
  14. #33899
    funny, sounds exactly like what answers we got from Ryger and his sidekick luc fornicathimself.
    Does the rev counter go to 30,000 rpm and make 70hp .
    but seriously his HP figures seam to be realistic.
    dDd you ever map out the potential of the other engine if it actually defied physics and managed to hold together to 30,000rpm
  15. #33900
    Yamaha XJ750 1982
    South Africa
    Yes, from the homologation papers it seems that its pumping chamber has only 55% of the engine displacement, so unless they discovered a way to more than double the suction of the pipe it was only good for mid 30s hp. Which seems to correspond to dyno figures Jan has heard. I think we will not hear any more from the Ryger crowd.
