Page 2261 of 2776 FirstFirst ... 12611761216122112251225922602261226222632271231123612761 ... LastLast
Results 33,901 to 33,915 of 41626
  1. #33901
    But wait. A new Ryger 4 stroke. They removed the valves and are turning the camshaft at double speed to invoke the mixture in. It's pretty hush hush but send money to. . .
  2. #33902
    10th February 2005 - 20:25
    1944 RE 1
    Auckland, New Zealand.
    I think many of us would have liked to see something sensational happen with the Ryger, but I don't think that many people actually believed it would happen at the time, most of all, some people like Jan who had already developed successful engines! - (and I took notice of that), but at the same time didn't like to see someone's dreams shattered - however that's life I guess!
    From the look of things, this guy has approached it from a different angle and gone on and done it all first and is now talking!
    As Frits says, nothing really new or sensational, so whether it will go anywhere or not, is the question!
    I feel that all the sensational breakthroughs were made in the 20th century and all that's left now is to decide whether full on development is going to keep the two stroke alive - or let it die and surrender to electricity! ...... it's all in the balance at the moment!
    Strokers Galore!
  3. #33903
    4th December 2011 - 22:52
    Yamaha XJ750 1982
    South Africa
    Here is his idea, just with the "mushroom" piston the other way round and loop scavenging in place of Uniflow scavenging:
    http://www.ac-aero.com/technologies/
  4. #33904
    it apparently runs on small balls.
    Dunlet piston and engine pre ww2
ID:	346127Click image for larger version.
ID:	346128Click image for larger version.
ID:	346129Click image for larger version.
    pre loop scavenged of course
  5. #33905
    28th August 2015 - 00:01
    1975 Hodaka Wombat
    Eugene, Oregon, USA
    As noted, stepped pistons have been around a long time. It really comes down to what is the most efficient pump in the size range we are talking about. In small engines it's hard to beat the crankcase pump/tuned pipe combination. It gives starting flow with some supercharge and good piston cooling. Piston pumps are most efficient in small sizes where clearances make other pumps leak. Screw compressors are good in moderate sizes where lower friction and wear makes them superior to piston pumps. it's hard to beat centrifugal and axial compressors in large sizes for the same reasons as well as compactness.
    However, none of these pumps can add serious power without a system to recover energy, apply back pressure and cool the piston. Scroll expanders may be suitable in small sizes, but turbines are proven in large sizes. Piston cooling is usually done with oil flow to the piston under side in large engines.
    Lohring Miller
  6. #33906
    Yamaha XJ750 1982
    South Africa
    The difference between the traditional stepped piston and the new generation versions is that they no longer use the crankcase but the "scavenging" chamber between the piston and the seal to the crankcase.
  7. #33907
    Interesting solution for oil supply to crank big end main on Honda test NR 125 engine.
Name:	NR 125 test engine.jpg
  8. #33908
    i was trying to find a pic of the gm non supercharged engine i thought they had but i found out ,Detroit and GM consider the Detroit series supercharged diesel to be normally aspirated as it only uses the roots blower to scavenge.
    only the turbo are considered blown.
    Sorry Vannik i wasn't trying to suggest they were the same, only the stepped pistons were nothing novel.
    I suspect none of the older designs up until the late 60's-early 70's were that worried about emissions other then an impolite smokey haze that concerned the flash harry rather portly cigar smoking Daimlers driving 55 year old marketing executive.
ID:	346132Click image for larger version.
  9. #33909
  10. #33910
    Hi Katinas
    That fact of not exceeding 5000 rpm is what attracted me
    Last attempt with 4 type variation. This time, with opened under exhaust space to add trans volume. Results is the same, zero torque from 5000 to 8000 rpm.
  11. #33911
ID:	346137 Flettner 2013 https://youtu.be/hOGZ5llowoU
    Yes, its hard to patent something that has already been done.
ID:	346138 KTM 2017 https://youtu.be/e8LgPoCQVCk
    KTM tried to pinch Flettners idea. Their patent application was declined .....
  12. #33912
    3rd February 2004 - 08:11
    Wallaceville, Upper hutt
    If that arrow is pointing to some sort of "scoop" on the end of the pin to pickup oil thrown from the main bearings, that's pretty common among two strokes. My 72 F9 Kawasaki bighorn had a ring on the side of the flywheel that did the same thing
    (PostalDave on ADVrider)
  13. #33913
    Thanks, never noticed this before.
ID:	346139   Click image for larger version.
  14. #33914
    [QUOTE =KTM tried to pinch Flettners idea. Their patent application was declined ..... [/QUOTE]
    Lots of good stuff happening out there and it's not always the big companies....
  15. #33915
    4th September 2017 - 10:39
    Daelim besbi 2008
    Espaρa
    Excellent work done, I hope it helps to develop new more efficient engines
