Page 229 of 2776 FirstFirst ... 1291792192272282292302312392793297291229 ... LastLast
Results 3,421 to 3,435 of 41630
  1. #3421
    Oh yeah, does anyone have a spare KE125 barrel?
    Just get your CNC guy to start with a bigger block of Aluminium !
  2. #3422
    Screw the barrel, you want the whole motor - sweeet gearbox and the rest can be fixed.
  3. #3423
    21st August 2008 - 21:52
    suzuki RM125S 1975
    auckland
    Rgv 100
    Wobbly has sent me drawings for the RGV H2O 100 in Reed and Rotary Valve configurations.
    I am planning on using what I have about the place, so it’s a TF100 bottom end for the case reed motor and a GP100 for the rotary valver.
    But I am tempted to ask Wobbly to put some details together for a 125 aircooled rotary valve version based on the old GP125 instead as the GP’s have been such good friends and I rather like them.
    why not just make a head and weld a water jacket on a GP100 cylinder,or use a RG400 cylinder,you may end up with the same problems ND has with his RGV100 on the fast tracks,you would need a sleeve around 5-6mm thick to stop the bridge getting to hot.the RGV150 cylinders have a hole in the alloy part of the bridge for water to pass through for better cooling
  4. #3424
    I dont know what you heard about my gear box, malicious lies Id say.
    But seriously I do need another barrel, must be a few left over from all those RG conversions?
  5. #3425
    The things that turn up at work.
Name:	A1 Afterburner.jpg
    Afterburner, a 16 foot long drag bike .......
Name:	A2 Afterburner.jpg
    680+ rwhp, and we are busting our arses looking for 30 .........
  6. #3426
    The GP and RG400 cylinders with their single exhaust port don't allow enough blowdown time area to make decent power. But I could sleeve an aircooled GP125 cylinder and add a T or tripple exhaust port, but thats not so easy to do with a RG400 cylinder as there is not much meat around the exhaust port area on one of those.
    I am not sure what the cause of ND's problems was, or what the sleeve he used was made of, or if he fitted an iron sleeve within the original steel sleeve and had a bad thermal path. I just don't know much about how he went about things but I have heard he made a new sleeve and has pretty much got on top of the long track reliability issues now.
ID:	230183 Click image for larger version.
ID:	230184 Click image for larger version.
    My plan is to use a large diameter, thick walled, plated alloy sleeve and bore the cylinder out as much as possible to maximize the heat transfer area between sleeve and alloy cylinder jacket. And of course it will be put together with CPU heat transfer paste.
    you would need a sleeve around 5-6mm thick to stop the bridge getting to hot, the RGV150 cylinders have a hole in the alloy part of the bridge for water to pass through for better cooling
    I like your idea of using an RG150 cylinder as that would allow a thick sleeve like you suggest and possible a water gallery through the sleeves exhaust bridge too.
    Wobbly has been planning everything for me around sleeved down RGV250 cylinders, but I like the idea of a larger sweeping bend up to the transfer port.
ID:	230180 http://www.2stroke-tuning.nl/media/pdfjes/porting.pdf
    Yamaha in their SAE paper said that the number one thing that affected power delivery was the angle of the port entering the cylinder and number two was the radius of the transfer duct, then the upswept angle of the port roof.
    I will get Wobblys opinion on the shape and suitability of the RG150's port ducts which look a little different to the RGV's.
  7. #3427
    Some Links I've been reading that may be useful regarding handling etc..
    http://www.motorcycle.com/how-to/cha...sics-3444.html
    http://www.fatbaq.com/mainpage.phtml?topic=sag
    Current Model 125 Specs Straight from the maker:
    http://world.honda.com/HRC/products/...e/rs125r/spec/
  8. #3428
  9. #3429
    The 1st RGV conversion I did 4 years ago odd was a 150 based cylinder with a steel liner.
    That made over 28 RWHp at only 11500 even with the std reed in place.
    But its so long ago I cant remember what the actual duct differences are with the 125 cylinder.
    Need to have them side by side to see - but with the bigger bore the PV positioning will be different, not an issue as this setup needs to be remade for the 50 bore anyways.
  10. #3430
    http://cgi.ebay.com/ebaymotors/Kawas...item588c1c6d79
    Kel mate only $250US When you buy it, have it send it to me and I will forward it to you for a 'small' charge...
  11. #3431
    Ok it might be a Honda 50 and 4-Stroke but you still have to be impressed with 320 BHP/l
    Scraped from the net............ 1966 50cc twin 4 Valves a cylinder GP Racer.
    But Honda was always about the engines, and they reached their pinnacle in the 1960's with the RC116
    Bore = 35.5 mm
    Stroke = 24.14 mm
    16.5 BHP @ 21,500 RPM...Redline at 22,500 RPM
    And that is 320 BHP/Liter
    Yes...that's a dry clutch
    Yes...those are flat-slide semi-downdraft carbs (And, yes, they are Keihins. Just 40 years older than the FCR model they sell today)
    And yes...it is mostly magnesium (except, obviously, the cylinder head)
    And just because the cylinders were little didn't mean Honda was going to go all cheap-ass and crude.
    It is still a four valve per cylinder design...they just happen to be very small valves (13mm In / 11.5 mm Ex...3.5 mm stems)
  12. #3432
  13. #3433
    So you can have multi cylinder rotary valves.
    A decent piece of CNC work.
    Note the water jacket around the crank cases.
    Making your own carb is possible.
    Looks like the carb has been made to match a rotary valve port.
    I have one or two ideas for my own special 24mm class legal carb.
  14. #3434
    Check the size of the rotary valve ports
    My GP will have an inlet port that looks like this soon .......
    And I have an idea how I could make a variable port where the closing point can be changed, much like a blade power valve.
ID:	230301   Click image for larger version.
ID:	230302   Click image for larger version.
ID:	230303   Click image for larger version.
ID:	230304   Click image for larger version.
  15. #3435
    suzuki RM125S 1975
    auckland
    D bore card
    So you can have multi cylinder ratary valves.
    shape looks the same as the D bore carb i got from FW in the UK for my 1991 RS125 in 1996,with other parts made 43HP,carb made 1 HP from 8500-13000 over STD carb
There are currently 146 users browsing this thread. (0 members and 146 guests)
