Page 2295 of 2773 FirstFirst ... 1295179521952245228522932294229522962297230523452395 ... LastLast
Results 34,411 to 34,425 of 41592
  1. #34411
    Why do you think you need a balance shaft.
    On an engine dyno , or sitting on a kart chassis warming up - the difference in perceptible vibration between say a late model RS125 with one , and a CR125 based one , or a KZ 125 is nil , that I can feel.
    The small single cylinder 125 engines balanced to around 58% do not need a balance shaft , a 50cc should be even better with way less peak amplitude forces to deal with.
  2. #34412
    Thanks Wob
    Yes, of course, it would do just fine without a balance shaft. this project is my little sudoku and lacks a bit of a purpose. The engine will most likely be started once in an engine dyno and then placed on the shelf.
    The journey is the goal
  3. #34413
    When i added a balanceshaft on my 212cc kawasaki i used balanceshaft and gears from 'tecate250' ,dunno exact name.
    But it made it fairly simple as the gears and the splines were correct,
    It made a world of difference, but on a small 50cc the vibrations will never have the same amplitude as i had(as wobbly wrote).
    I revved my 66.4bore 61mm stroke to 13200rpm
    But it is fun to learn as one travels forward with a project =)
  4. #34414
    Whilst balancing can make things smoother for the rider/driver, in the case of a bike or kart respectively, is there an effective power increase or decrease?
    If, in the case of using a balance shaft, we add weight til we cancel out the vertical reciprocating mass. However this produces much higher 90 deg forces which we cancel out with a balance shaft. The balance shaft bearings essentially experience the same increased force as the crankshaft bearings, both leading to more friction, however small.
    So, a question can be, does the extra bearing and drive friction offset the possibly parasitic power loss of shaking the frame and rider/drivers balls ?
  5. #34415
    WOW , 61mm stroke/13200 rpm = 27M/s .That is EXTREME.
    The tradeoff between parasitic oil drag ,bearing friction ,and added inertia Vs smoothness of operation would depend I believe on how clever the balancing was done initially.
    If the wheels of the crank had been lightened , then Tungsten mass added toward the outer edge ( as was done at Aprilia ) then the added inertia of the balancing shaft could easily reduce the acceleration rate
    by a % greater than the power released by having most of the final resultant forces cancel.
  6. #34416
    14th April 2011 - 23:44
    2008 Yamaha fino
    Bangkok
    I made the first 125 GP engine with a balancer shaft.
    Some people said I was crazy..... it would cause additional friction.....
    When I removed the balancer the engine lost 1,8HP
    Later ALL 125 GP engines had balancers!!!!
  7. #34417
    The classic assumption has been that inclusion of a balance shaft should enable a lighter chassis structure - which should enhance acceleration.
    But - if there is a class minimum weight which is easily achievable, a case can be made for deleting a balance shaft...
    In an ideal world with no minimum weight limits, IMO the case is strong for a balance shaft - but it's an interesting question anyway.
  8. #34418
    Odd aside from not having a heavier chassis to soak up the vibes ALA NS/RS500 Honda .
    i always assumed that the cases could be made lighter with a balance shaft design as they could be thinner as it's exposed to less vibes.
    The NSR500 was given a balancer in the big bang period it was left in on the Screamer, Only as it was faster around the circuit with it in.
    Likely because in a single crank set up it made it easier to turn as it cancelled out gyro.
    But Doohan never cared why, only if it was faster.
    I think i recall something also from Wob about CNC cases losing power quicker than Cast or something? Sealing????
  9. #34419
    18th March 2004 - 17:38
    1971 suzuki T350R
    the best island
    Do you think the vibrations were affecting the carburator?
    . . . That shit's Nasty.
  10. #34420
    Jan, cheers for that. Hard to argue against an extra 1.8 hp in 53.2. A useful gain for sure.
  11. #34421
    yes,, tell me about it,, =)
    And it produced power also, almost 70rwhp
    But wristpin and piston lifespan was very short, dunno why
    I later reduced the top rpm to 11000 and it produced 64rwhp with ordinary pumpfuel
    This engine will be further developed and tested this winter, i´m about to build disc inlet and with a different cylinder(TM racing)
    I promise you, it is a experiance to hear that much volume in a single cylinder rev that much, like a ktm65cc but with volumeknob turned to 25(if max were 10) and still had a silencer =)
  12. #34422
    2nd August 2011 - 11:11
    Connecticut, USA
    balance shaft
    This is an interesting result. Do you have a theory as to why the HP increased with balance shaft? A free 1.8HP is surely nice to have.....
  13. #34423
    Fear is beeing pushed away, i needed more numbers on a sheet, so what the heck, just klick up one gear.
    So, these pulls are on 5th gear, did some small adjusts before, i took away some advance and actually added some more oil to the fuel, now 6%
    I also set the plug gaps to 1mm from 0.5 i had when i was looking for misfires.
    And as expected, the number went up, but i didn´t expect this much
    The jerky pull was from cold engine, it stuttered when i was twisting the throttle.
    82.4rwhp and 90,8 crank hp together with 60,8Nm
  14. #34424
    I'm convinced that Yamaha's factory team
    had been ecstatic over 82.4hp at 10492 in the 90s
  15. #34425
    Thumbs up Alcohol!
    Ever tried alcohol fuel?
    I dynoed 74.9hp yesterday on 4th gear and before adjusted ignition
    And E85 can add about 7-10% power if properly setup, 82.4X0.9= 74.16hp
    Methanol can add even more, ive seen up to 22% on an aircooled engine.
    So 10% power my blend could probably add onto 74hp, i see no dramatic way off numbers there
