Page 2318 of 2776 FirstFirst ... 1318181822182268230823162317231823192320232823682418 ... LastLast
Results 34,756 to 34,770 of 41633
  1. #34756
    OK - great, we have a proven data point for a 50cc race engine on petrol making 28.2 CHp im guessing as the dyno video didnt show it @ 16500 rpm.
    Thats a bmep of 15.3 Bar , just what I would expect , especially from a couple of Dutchmen in a shed.
    Now compare that to what is supposed to be the " best " 30.5cc petrol engine on the market from Quickdraw - makes 8.75 Hp CHp at 16250 = 6.9 Bar = joke.
    So now I know what can be done by a Dutchman in a shed = perfectly normal technically achievable performance.
    Good , lets see what a Kiwi can do with Laser Sintering , CNC cases , Ti pipes and EngMod , all from the comfort of an office chair.
  2. #34757
    Suzuki 50-twin continued
Name:	07 RK67-4.jpg
ID:	347998 Click image for larger version.
Name:	08 RK67 14-speed gearbox-1.jpg
ID:	347997 Click image for larger version.
Name:	09 Suzuki RK67 piston.jpg
ID:	347996 Click image for larger version.
Name:	10 RK66 data.jpg
Name:	11 RK67 data.png
ID:	348000   Click image for larger version.
Name:	12 Suzuki specs.jpg
  3. #34758
Name:	Suzuki RK66-02.jpg
ID:	348007Attachment 348001Click image for larger version.
Name:	15 Suzuki RK67-12.jpg
ID:	348004 Click image for larger version.
Name:	14 Suzuki RK67-15.jpg
    The left-hand picture, by Kawai Mitsuo, is marked 'RK67', but in fact it shows the RK66, which had a much shorter connecting rod than its successor, the RK67.
    The Kawai Mitsuo-picture also shows the third transfer port being fed through the piston, whilst the picture of my RK67 cylinder (center) shows that one year later the third transfer was directly connected to the crankcase.
  4. #34759
    28th August 2015 - 00:01
    1975 Hodaka Wombat
    Eugene, Oregon, USA
    Are there some model aircraft/boat classes where both spark ignited and glow engines compete?
    The 2.5 and 6.5ccm engines have a ringless pistons and that can help produce as much power as they do
    Has it ever been tried to modify a weedhacker engine with glow ignition and ringless pistons?
    We did an evening of dyno runs on a 26 cc Quickdraw converted to glow ignition with a simplified WYK 33 carb. We couldn't get glow plugs to work. They either blew out the center or wouldn't light the glow fuel. The engine ran fine on the stock ignition on 15% nitro glow fuel, but burned the electrodes off the plug on 40% nitro fuel. We probably could have played with head volume and more glow plugs, but we had no incentive since we were after gasoline records.
    Again, our experience with the CMB ringless piston design was poor. We weren't in the business of building complete engines; we went with the best available at the time. My friend, the late Jim Allen, claims he got 10 hp from a 26 cc Quickdraw by chroming the cylinder, running a higher compression toroidal head button, using his custom tuned pipe, and adding a custom 20 mm bore carb. I would love to see what a serious, modern 30 cc design could do.
    Lohring Miller
  5. #34760
    8th November 2015 - 17:28
    1991 MZ 301
    Denmark
    Thank You for some lovely 50ccm pornographs.Do You also have some of the final triple animal?
    The picture here:
    https://www.kiwibiker.co.nz/forums/a...7&d=1520911705
    shows that electric transmission is worth a thought
  6. #34761
    Yes Niels, I do have pictures of the 50cc triple and a lot of other Suzuki racers, about 200 in total. But it is rather impractical for me to post them one by one.
    I would gladly ZIP the whole lot but I forgot how to upload zipfiles to Kiwibiker. Anybody?
  7. #34762
    Quote Originally Posted by Mental Trousers View Post
    You looking for another one?
    While we are waiting here is the one Hugh Anderson had here and sold to I think the Netherlands.
    https://www.kiwibiker.co.nz/forums/s...post1130374843
    https://www.kiwibiker.co.nz/forums/s...post1130616443
    https://www.kiwibiker.co.nz/forums/a...2&d=1380532376
    https://www.kiwibiker.co.nz/forums/s...post1130618964
  8. #34763
    So beautiful little engines, thank you Frits.
    From spec chart, impressive air cooled twin RV62 250cc 42hp at 11000rpm.
    Add few schemes of 1972 spec rotary valve racing outboard Veterok-70 350cc and Veterok-100 500cc (Konig copy). Interesting 350 cc power graphs with different
    intake duration and different closing angle after TDC /fixed rpm. Both engines with same bottom, 54 mm stroke, just on 350cc cylinders with 45.3 mm bore.
ID:	348015   Click image for larger version.
ID:	348016   Click image for larger version.
ID:	348017   Click image for larger version.
  9. #34764
    10th April 2013 - 09:59
    Honda NSR 50
    Netherlands
    Just to clear, that 50cc engine is not mine, nor did I have anything to do with it. I wish I was that good
    I’m sure that Frits knows the Van Rossem brothers. Jan Thiel helped them a lot on a Dutch forum. As far as I know, this is the most powerful Dutch 50cc in pump fuel.
    Verzonden vanaf mijn iPhone met Tapatalk
  10. #34765
    8th December 2014 - 14:39
    1980 Suzuki Gs1100E
    SWPA
    I have 2 questions. Why did ( not just Suzuki but a number of companies) lower the bottom of the ports below the BDC line? I know not much flow happens at BDC but it has to mess with the flow somehow. Also in the pic that Frits posted of the piston from the RK66 engine has grooves below the ring land. Were these used as a type of labyrinth seal. I notice some of the new 4-stroke pistons have the one above the ring. But I haven't seen them very often below the ring. One other question, how do I install this in a simulation program?
  11. #34766
    jfn2 - Sorry to ruin your delusion buddy , but most all the flow occurs around BDC , via the large pressure delta across the Exhaust port created by correctly timed diffuser action.
    At lower rpm the biggest depression occurs BBDC , it then advances thru BDC to ABDC as the fixed pipe length affects the arrival of the diffusers peak amplitude at the Exhaust port.
    When the transfers first open there is more residual blowdown pressure in the cylinder , than pressure in the duct created by the piston descending - this is the sole reason for port stagger , the first transfer
    to open , flows last.
    The best pipes can suck the chrome off a towball for the greatest dwell time around BDC - thus the latest tuning trend is to increase the A port front wall angle right back toward the boost port
    helping to reduce direct short circuiting created by very efficient diffusers.
    Best example of this would be a stock TZ350 that simply refuses to make more power with a pipe bigger than 110 belly diameter.
    As for having the transfer inner radius ending below BDC , maybe this was found to give a " better " flow regime when using elevator shaft ( love that term ) type ducts , as it attached the
    flow to the piston early.
    For sure in modern teecup ducts even small discrepancies in height, above or below , wreak the scavenging flow exit from the port.
    And my guess re the groove below the ring was to lighten the piston , as it was probably derived from a die designed for two rings and had alot of unecessary skirt material between the top
    of the small end and the top ring groove.
  12. #34767
    23rd July 2017 - 21:59
    n/a
    canada
    Quote Originally Posted by JdG View Post
    https://youtu.be/oJcnaM-hB8Q
    Zundapp crankcase, std. Derbi cilinder modified. Build in a Dutch shed by 2 brothers.
    Lots of hours spend though...
    Good morning all !
    this forum is fantastic! thank you for sharing your expertise in 2-stroke engines!
    in this video at 20 seconds for example have heard a pop?
    what does that? thanks
  13. #34768
    Im sure as h.. looking forward to follow this
  14. #34769
    Yes it will be interesting to follow!
    I myself spends Saturday night trying to master magic of super polish ...
    And borrowed a 3d printer for carbon fiber / nylon. has managed to print the first part to the 50cc engine
    Has also managed to cut some parts yesterday for manufacturing a connecting rod for the engine
ID:	348019   Click image for larger version.
ID:	348020   Click image for larger version.
  15. #34770
    n/a
    canada
    Quote Originally Posted by porttiming124 View Post
    Good morning all !
    sorry I did not copy the correct link! here is the good link to look at 20 seconds thank you
    https://www.youtube.com/watch?v=6NwDSwxGpwM
