Page 2322 of 2773 FirstFirst ... 1322182222222272231223202321232223232324233223722422 ... LastLast
Results 34,816 to 34,830 of 41593
  1. #34816
    23rd July 2017 - 21:59
    n/a
    canada
    very good idea
    I will do it in 7 port today and I will get back to you with the STA
  2. #34817
    6th February 2012 - 08:54
    1988 cagiva freccia
    france
    Any idea which resin to use for mould intake rubber?
  3. #34818
    n/a
    canada
    here is the result with 7 port with the true height !the blowndown is now insufficient
ID:	348065   Click image for larger version.
  4. #34819
    1988 cagiva freccia
    france
    porttiming124 use "print screen" and past to Paint
  5. #34820
    Quote Originally Posted by porttiming124 View Post
    Good morning all !
    this forum is fantastic! thank you for sharing your expertise in 2-stroke engines!
    sorry I did not copy the correct link!
    Hello !
    here is a snowmobile cylinder!
    look at the big radius in a corner of: B: port!
    it is a 2 ring piston with ring gap between the b and c port!
    I also removed the radius!
    Regarding the A port with two steps(2.8mm) in engmod I averaged the 2 heights to have the right area in my opinion!
    on the other hand by doing this I am aware that I do not have the right blowdown!
    Portiming124, are you aware that you used 12 exclamation marks in 6 days on this forum alone?
    You are in danger of exceeding your allocated amount of exclamation marks before the end of the month.
    But do not fear, there is solution: in this forum it is permissible to end a sentence with a plain and simple period.
    Sorry, I couldn't help myself . During my stay in Germany I seem to have developed an allergy to exclamation marks and prohibition signs Name:  Verboten-2.png
  6. #34821
    n/a
    canada
    Sorry frits I will be careful.
  7. #34822
    n/a
    canada
    thank you philou
ID:	348070   Click image for larger version.
Name:	transfer port data.jpg
ID:	348071   Click image for larger version.
Name:	transfer window.jpg
  8. #34823
    13th December 2018 - 18:06
    youtube andreas länström
    sweden
    Haha, Porttiming your lack of b-d area is very common. It seems there is room to widen the auxillaries quite a bit, maybe even raise them a little relative to the main but there is a thin line before ex pulse get compromised. Remaining after that is only to raise all of them, this has a y- pipe? I think they work well with long ex-durations btw, but the Engmod can probably tell you all this.
  9. #34824
    Achtung - not only are these Dutchmen bloody clever 2T tuners, they have a better grasp of propa English than many of us natives.
    But re the 7 port ski engine , now that is a seriously wierd scavenging regime.
    More especially as the B port is lower than the C , that are now C and D.
    But , I have a feeling the axials are going to be wierd as well - post the transfer layout page .
    I use Gadwin Printscreen , free and way more user friedly at copy/pasting any part , or all the screen to any file or printer.
    I would lift the C ports about 1/2 way between the A and D , this will give more transfer STA again.
    Then mod the Aux to get the Blowdown STA back in line , looks like the front top corner could go closer to the main Ex as well.
    And get rid of those horrible port chamfers , completely unecessary.
  10. #34825
    3rd August 2012 - 02:39
    yzf 250
    holland
    In plain english How the hell you get those numbers in real live engine
  11. #34826
    God save us - the axials are a nightmare 8-17-9-50.
    How people ( I wouldnt be kind and call them engineers ) actually got paid to produce this complete rubbish is beyond me.
    No other two stroke in the world has ever had such a complete mess , looks to me like its not even possible to "fix " by dropping the cylinder and regrinding everything.
    Maybe if the Aux floor is lifted , you could start again - as the Aux roof is 6.2mm lower than the main - wtf , gets weirder every time I look.
  12. #34827
    n/a
    canada
    look at the port layout (I put the cylinder upside down so that you can see the roof of the 'a' port) and also I removed the radius in the upper corner of the 'B' port as wobbly to recommend thank.
  13. #34828
    n/a
    canada
    wobbly I checked with the piston to widen the auxiliary port exaust towards the center of the cylinder as you have drawn in red and I am at 1-2 mm from the pin of the piston
    so yes I can go there a little on this side but not much, I will also go there on the side of the main port,
    if I put the auxiliary ports 6 degrees lower than the main port, is that correct?
    thank you
  14. #34829
    That's odd. Looks like a very nice casting though. Transfer the aux further out to the ex union. Transfers look pretty shallow from a sweeping inner point of view.
  15. #34830
    The Aux are at 181* Duration now , Vs the 201* of the main port - I would go up to 191* but the transfer axial angles are the biggest issue.
    How you fix them to be something normal like 25* 15* 55* I really dont know.
