Page 2323 of 2774 FirstFirst ... 1323182322232273231323212322232323242325233323732423 ... LastLast
Results 34,831 to 34,845 of 41608
  1. #34831
    23rd July 2017 - 21:59
    n/a
    canada
    ok perfect .
    in general on an engine which is well designed, what should be the height of the bottom of the auxiliary exaust port?
  2. #34832
    If its done properly the Aux can be below the A port timing edge.
    Here is a TM homologation diagram - with a small mod I make that puts the top corner over the small end pin.
    But as the exit angle is very shallow , there is minimal effect from port linking so it makes more power.
Name:	TM Ports.JPG
  3. #34833
    13th December 2018 - 18:06
    youtube andreas länström
    sweden
    Maybe it's an acquired taste but I don't hesitate to use epoxy in the transfer ducts. Better have the glassfiber kind, that way chunks won't fall out and you can arrange so that it is mechanically locked.
  4. #34834
    6th February 2012 - 08:54
    1988 cagiva freccia
    france
    In Facebook
    Translate in English :
    Hello, after making the modification to cool the exhaust duct on a cagiva mito cylinder.
    I have the problem of having the exhaust gases too cold. From the usual 550 degrees I only have 440 degrees.
    The carburetion is perfect. Do I have to change the ignition advance?
  5. #34835
    sweden
    I think you have to question whether he actually tested this, bacause how would it circulate, and how would it not leak.
  6. #34836
    1988 cagiva freccia
    france
    A part closes the conduits for sealing
ID:	348095Click image for larger version.
ID:	348096Click image for larger version.
  7. #34837
    Not only does the implementation look highly suspect - just about impossible for it not to leak , but how can the carburation be " perfect " at 550* or 440*.
    Neither number are even close , on track or a dyno.
    My original test was on a B homologation cylinder , unwelded at the time to reduce the exit area , and it would leak vey easily until I discovered Loctite Master Gasket in a syringe.
    The later cylinders had much more vertical area for the slots and had no issues.
Name:	KZ10 Cooling.JPG
  8. #34838
    12th August 2015 - 03:31
    GSXR600
    Canada
    Need to Upload Pics
    I haven't been on here in a long time, what's the trick to getting a jpg to show directly in a post (not as an attached thumbnail).
    I have the jpgs loaded on Dropbox but adding the Dropbox links to the post doesn't seem to do anything according to the preview.
    Thanks.
    Anyway the thumbnails show high speed RECORDED pressure data (cylinder, intake, exhaust) that I promised ages and ages ago. I planned to have crankcase pressure too but will have to do that another time. Yamaha Banshee with some mods, details to follow.
Name:	Banshee Combustion Pressure Trace.jpg
ID:	348117   Click image for larger version.
Name:	Banshee Energy Release Trace.jpg
ID:	348118   Click image for larger version.
Name:	Banshee Exhaust Port and Back Pressure Trace.jpg
ID:	348119   Click image for larger version.
Name:	Banshee Exhaust Port and Intake ( Inside Reed Cage) Pressure Trace.jpg
  9. #34839
    n/a
    canada
    thanks wobbly.
    I took the tm digram and converted it (roughly) to my bore and stroke to be able to insert it into my cylinder to give me a visual idea of ​​the difference.
    woow quite a difference.
    ports A and B are larger, port C is similar.
    my biggest problem if i want to try to get close to your diagram is the divider between port a and port b.
    either I remove it and remake one and I weld it in the right place (very difficult)
    the other option would be to widen port A as much as possible towards port B while keeping the current divider (easier)
    for the auxiliary exaust port I can reshuffle it with solder.
    for port A I can rebuild the exaust side as well as the top also with solder.
    to widen the B port I will have to convert or modify my piston 2 ring to a single ring with the ring gap in the center (something I never did) of the C port.
    it's a big project but i'm looking at all the options. thank you
ID:	348130   Click image for larger version.
ID:	348131   Click image for larger version.
ID:	348132   Click image for larger version.
  10. #34840
    sweden
    Looks like a different cylinder-And that yellow stuff is trying to tell you something.
    Exactly.
    Quote Originally Posted by porttiming124 View Post
    thanks wobbly.
    I realize you're thanking Wobbly. Just what sort of solder are you reffering to? as you mention welding also.
  11. #34841
    n/a
    canada
    Hello Andreas.
    i thanked wobbly for providing me with the tm certification diagram to help me understand the port layout.
    for welding I am talking about tig welding.
    a friend of mine is a welder for prototype helicopter projects, he has very small, pencil-sized welding tools. for example some time after having stroked a cranshaft I had too much transfer port duration so to lower the port he reshuffled the edge.
    then I had the nickasil redone and finally I filled it with jb weld epoxy.
Name:	weld transfer.png
  12. #34842
    n/a
    canada
    Just a little parenthesis to tell you that I speak French.
    I understand English fairly well but for the spoken word I work hard with my friend (google translate) to correct myself and allow me to communicate with you.
    if you see incorrect verb tenses or anything else that is not perfect it is not intentional.
    thank you.
  13. #34843
    sweden
    Hello Andreas.
    Ok, solder here is for elctrical component thats why I asked. You work fast.
  14. #34844
    19th June 2011 - 00:29
    anybody recognises these exhaust ?
    these had the white label with "KR1" attached to them but they seem to need a long flange on the cylinder to slide them over to fit, and the tailpipe comes out way too low for KR1's
    I can't remember where I got these, but they don't fit a KR1. the support on the belly is all wrong.
    both are after market and very low on weight
  15. #34845
    sweden
    I understand you speak French, I also understand what you are saying (probably).
