Page 2324 of 2773 FirstFirst ... 1324182422242274231423222323232423252326233423742424 ... LastLast
Results 34,846 to 34,860 of 41591
  1. #34846
    Quote Originally Posted by nitro2tfx View Post
    ... the thumbnails show high speed RECORDED pressure data (cylinder, intake, exhaust)
    Thanks Nitro, I love TFX recordings. But yours make me wonder about the high exhaust pressure spike around TDC. Connecting exhaust pipe and crankcase at TDC via a shortened piston skirt would be a bad idea with such a pressure profile. It would also annihilate exhaust wave superposition at EO. For comparison I dug up a 12-year old TFX recording of a 125 cc kart engine at 12775 rpm.
    Its exhaust pressure profile is not ideal either, but it shows quite a difference with yours. What exhaust timing did you use?
Name:	TFX Banshee exhaust port and back pressure.png
ID:	348136 Click image for larger version.
Name:	Oosting TFX exhaust + case pressures @ 12775 rpm-k.jpg
  2. #34847
    12th August 2015 - 03:31
    GSXR600
    Canada
    Just to be clear this is not an optimized exhaust, nor optimized engine in any way. We haven't physically done anything to the engine yet other than spruced up the fuel and timing a bit, and added the sensors. What you are looking at is a recording of what things look like inside the engine "as received" (plus ignition timing/fuel) at one engine speed.
    All of the traces are from a stock Banshee engine that has a few typical aftermarket Banshee bolt ons added on, the exhaust is a stock Toomey T6 exhaust (broad powerband pipe), V-Force reeds, 33mm PWK carbs (no Power Jets), Cool Heads, all common as mud Banshee aftermarket bolt-ons lol. Other than that just the ignition timing bumped up and the fuel spruced up.
    Initially we will make some more fuel changes and maybe an intake revision, before doing any porting or exhaust changes. At some power level blowdown will limit things and porting will have to be done before continuing on, but we are over 100 IHP and haven't touched the ports.
    I might add that the recorded data was taken onboard the Banshee on the fly, it was not done on a dyno. Gearing was changed from 14/41 to 19/38. Fast trail riding.
    I will post some more info, different engine speed etc.
  3. #34848
    The recorded pressure diagrams have one issue that needs addressing.
    Where is the Exhaust sensor in relation to the piston.
    If the distance /time factor is not taken into account by the software , then that spike that is shown at tdc , wont be anywhere near tdc.
    If the sensor is 150mm from the piston , then that spike , a snapshot in time ,will have taken a significant number of degrees of crank rotation to arrive at that point.
    A function of the wave speed , and rpm.
    This is why Neels code has a fixed wave snapshot at the port face , then a second wave showing whats happening at a set distance from the port.
    In this case the pressure diagram is meaningless , but other metrics such as wave Mach can be observed.
    Many highly reputable SAE papers on engine simulation Vs real data , including those of Blair and Fleck et al from Queens , have been presented showing wave forms where this time smear is completely ignored.
    And if one wants to get really pedantic , the pressure traces , should also be labelled as rightward or leftward propogated ie is the pressure rise coming from the port , or the reflected returning pulse.
  4. #34849
    Portiming124 - Bonjour mon ami . OK so if you are well versed in removing the chrome , and welding the ports or dividers , then that cylinder could easily be fixed.
    If thats the case , then get rid of the A port step , lift the bottom outer corner of the Aux port , and as you say get rid of the second ring and move the top pin over the boost port.
    Then epoxy up the duct roofs to get modern axial angles.
    Depending upon the end use , it would be much easyer to implement reverse stagger , leave the A port low and lift the B , C port 4* of duration higher , like the Aprilia scavenging pattern.
    And please dont put any solder in the cylinder except to check the squish.
  5. #34850
    GSXR600
    Canada
    No issue, the sensor is a little over 2 inches from the piston. 6 inches would be WAY too far for the reasons you mentioned, and too close to the piston is also not good as you get localized effects.
    This is just a Toomey T6 pipe, bone stock, not a TFX pipe nor customer pipe, and so far I have only posted at one engine speed, naturally things are different at different engine speeds.
    There are several things wrong with this pipe (easy to see on the trace) if one's goal was max power/torque, the T6 is a decent broad powerband pipe. At some point we may record pressures for a higher power type pipe, just for interest's sake and comparison sake. I can post that too, then we can see how much is left on the table beyond that. There's plenty of power to be made yet before getting into another pipe though.
  6. #34851
    15th May 2017 - 14:26
    2002 Aprlia RS125
    Any idea which resin to use for mould intake rubber?
    Philou.
    Did you get a response from anyone or work it out. I am interested also
  7. #34852
    Philou.
    Do not know if I know any good resin, but 3d printing might be an option
    I think intakes are often made of PF rubber
    https://m.youtube.com/watch?v=d9FAEArjMms
  8. #34853
    Pretty sure n the site or one of the videos he covers what the rubber was for the RD ones have posted them before he does a very nice job.
    https://precisiontradingsystems.com/inlet_rubbers.htm
    https://precisiontradingsystems.com/inlet_videos.htm
    Also a guy on the KR1 site was making 35mm intakes, BDK were/are selling them.
    http://www.kr-1s.co.uk/forum/viewtopic.php?t=5197
  9. #34854
    that reminds me i just did another set the other day. tough little buggers trying not to blow the corner edge off and you only got one shot to get it right. proffesional machinist in oregon united states fucked up my yami cylinders and punched them to 68mm instead of 66 but to make matters worse the left cyl bore vertical centerline didnt intersect the comb chamber center. no choice but to drop in sleeves and start over . the only good news is im back at 64mm
ID:	348142   Click image for larger version.
  10. #34855
    6th February 2012 - 08:54
    1988 cagiva freccia
    france
    Thanks you reply,
    In 3d printing what is the duration over time?
    How much is the shore hardness?
  11. #34856
    And if one wants to get really pedantic, the pressure traces should also be labelled as rightward or leftward propogated ie is the pressure rise coming from the port, or the reflected returning pulse.
    Call me pedantic.Putting two sensors some distance apart, say a distance equivalent to 20 crankshaft-degrees at rpm of max.torque, would give me all the info I need.
    Portiming124 - Bonjour mon ami.... Please dont put any solder in the cylinder except to check the squish.
    Pauvre ami, he has to live with a language in which the word souder can mean weld, solder and braze .
  12. #34857
    28th October 2018 - 06:30
    Tomos D6, Cagiva Mito
    Idrija, Slovenia
    Hello.
    To introduce myself first. I am Kristjan from Slovenia and I race with Tomos 50cc at Grobnik circuit at classic 50 event. Did also some 60cc kart racing as a kid.
    I built Tomos D6 replica and now building Tomos GP77 replica with some freetech50 stuff developed (I must find 50cc thread here to post some more).
    I am reading this thread for long time now (still trying to catch up at page 1500.. ). It is awesome to read from you guys and thanks for sharing all your experience.
    To add a little of my own. I 3D printed intake manifold for my Cagiva Mito for Dellorto 38 carb. First out of plastic (black part) with rubber (white part). You can see how I joined them together. Plastic cracked after few dyno pulls. Than I printed it completly from rubber and when I bolted it down, it made a little opening on sides. I quick fixed that because I needed bike for riding to work. I also printed matching insert.
    Further development would be to print first few layers, insert laser cut alu or steel sheet plate and print the rest. Plate would distribute pressure evenly on cylinder for nice seal. Unfortunately development was stopped as I crashed with my Mito and broke my back, dislocated hip etc. Now I came from rehab after 6 months, so I have some free time to further read this forum and maybe contribute
ID:	348146   Click image for larger version.
ID:	348147   Click image for larger version.
ID:	348148   Click image for larger version.
  13. #34858
    13th December 2018 - 18:06
    youtube andreas länström
    sweden
    Very nice.
  14. #34859
    You are dead right Frits ,two sensors would give exactly what is needed , but with the processing power in my phone its way easyer to track the crank rotation and the wave amplitude against time.
    The whole return wave is displaced in time, thus can be calculated to be shown graphically with the correct relationship to the crank sensor.
    Still cant believe the intellectual Hp that completely missed that basic physics.
    And in the spirit of learning something every day , the Mito reed stuffer as shown would be easily the worst shape I have tested on the flow bench , and dyno.
    The shape should be convex on the sides , not tapering inwards to nothing.
    Worst shape , to best , we are talking nearly 2 Hp in 50.
    The worst bastardization of so called English is done by the Yanks - they invented the word " soder " that no one else in the world can even remotely understand.
    Simply as they are too lazy to include the L in solder.
  15. #34860
    Idrija, Slovenia
    As I said, I was in a hurry to get on the road, so I modeled first shape that I imagined
    Thanks for that. Would be interesting to try it on a dyno when I repair the bike.
There are currently 22 users browsing this thread. (2 members and 20 guests)
  1. JanBros,
  2. lohring
