Page 2350 of 2774 FirstFirst ... 1350185022502300234023482349235023512352236024002450 ... LastLast
Results 35,236 to 35,250 of 41608
  1. #35236
    Disco is dead Neil.
    Oh sorry. Not those Gibbs.
  2. #35237
    What should I say! Something that is affected by length but not by surface. I guess Isaac did not leave the building based on how you write. the only thing I can think of is sound but have a hard time applying it to something meaningful (could be something about Isaccs third). You have me by the balls on this one! What is the point of doing something if you do not understand why. Thanks for the thought exercise Frits.
    Muhr, I have the utmost respect for the work of Sir Isaac Newton and I certainly do not deny the existance of friction, but inertia is a different animal and my point was that it may be easier to understand its effects if you leave friction out of the equasion for now.
  3. #35238
    Teriks has also tried to make me understand this by pm, but the token has not fallen down yet.
    That we have a mass to accelerate it is obvious.
    That we have an area on the intake that the air must enter through that I also understand.
    But that if we extend it 50mm with a piece of pipe and hence get a higher inertia in that acceleration without friction being the factor there, you have lost me.
    In my head I think that atmospheric pressure does not care that it only has one way in or longer, as long as it is not exposed to an area change.
    Thanks for trying!
  4. #35239
    28th October 2018 - 06:30
    Tomos D6, Cagiva Mito
    Idrija, Slovenia
    Thank you all for nice lesson
    Best way will be to install rotodisc and try some variations on dyno.
    Flettner, I can't make Gibbs now as I have allready made engine casings. (actually my friend with his CNC skills). Here are some pics.
    Frits, I am using 175° now with my pistonported Tomos D6, with 2 transfers and butterfly exhaust. It is making 14HP on back wheel and 142km/h at Rijeka-Grobnik racetrack.
    Wobbly, as I have 2 outputs on my Zeeltronic for solenoid powerjet, I want to install one anyway. Some advice, where can I get appropriate-decent one? Thanks.
ID:	348736   Click image for larger version.
ID:	348735   Click image for larger version.
ID:	348737   Click image for larger version.
  5. #35240
    13th December 2018 - 18:06
    youtube andreas länström
    sweden
    Now we don't leave a man behind. It is obvious that there is a mass, and the mass gets greater the longer the duct. Also the pressure difference is the same, then Newton just say: delta p= force/area, and acceleration=force/mass.
  6. #35241
    I fully agree, Adreas; I'm just writing it down step by step.
    Duct volume V = cross flow area A * duct length L
    The mass m in our duct is proportional to the duct volume V
    m ≈ V
    m = A * L
    The pressure differential p over this duct exerts a force F= p * A upon mass m
    acceleration a is force / mass ;
    a = F / m
    a = (p * A) / (A * L)
    a = p / L
    In English: the acceleration of a mass in a duct is proportional to (pressure / length) . If you double the length, the rate of acceleration will be halved, and vice versa.
    While we are at it, let us take a look at the amount of mass that is moved through the duct in a given amount of time.
    First, let's make some assumptions in order to keep things simple (my hobbyhorse, as y'all may have noticed).
    1: The pressure differential over our duct is constant (in reality it would drop because of mass moving from the high-pressure side to the low-pressure side of the duct).
    2: The duct ends in a port which is fully opened during t seconds, after which it is suddenly closed.
    The length of the gas column that passes through the port, is ½ * (acceleration a) * (time t)²
    Now if we compare a duct with length L to a duct with a length 2L the acceleration in duct L will be twice as high as the acceleration in duct 2L, as we have seen above.
    This means that with the same pressure differential and the same amount of open port time, the long duct will fill the cylinder only half as well as the short duct. It's a great reason for using a short inlet duct which allows us to use a short opening time.
  7. #35242
    Thumbs up
    m ≈ V
    m = A * L
    a = F / m
    a = p / L
    Thanks Frits now I understand where we went in different directions in this.
    You write:
    As I understand the equation above, the air in the intake is a mass that is moved with the atmosphere outside. And if you move it twice the distance or need to do it half the time, double the force / time will be required.
    This is what I have in my head when I think about it and calculate.
    I see the air in the intake as part of the atmosphere with its restrictions that escalate with velosity to the maximum allowable flow is reached. which in this case unfortunately will not be linear
    I reason like it's the same atmosphere in the box as outside until you put on a lid.
    I have always thought like this:
    R = ½ρCAv2
    So I calculate with a velocity (v), the density (ρ) of air and area (A) on the intake and a coefficient of drag (C) (in this case friction)
    Last edited by Muhr; 19th March 2021 at 04:51. Reason: Realize that I am as vague as usual
  8. #35243
    Quote Originally Posted by Peljhan View Post
    The sliding Gibs live in the valve cover, not the engine casing. Can be retro fitted to any rotary valve twostroke, just need the appropriate valve cover.
    Nice machined case set by the way.
  9. #35244
    The solenoid used on the later Dellorto magnesium race carbs was , I believe , a standard part used as an idle air bypass valve on a small Fiat Carburettor ( Weber )
    The same thing turned up on Keihin carbs for MX bikes and aslo Honda RS125 98+ Keihin SPJ.
    I have also used the Mikuni solenoid kit sold by Allensperformace .uk - very expensive.
  10. #35245
    More from the genius of the Two Stroke Stuffing workshop.
  11. #35246
    sweden
    If someone like a lower intermediate battle, I usually stay up late on Lichess.org as Lansandreas.
  12. #35247
    28th August 2015 - 00:01
    1975 Hodaka Wombat
    Eugene, Oregon, USA
    While we're on the topic of small, high power glow ignition engines, some of you may be interested in a series I wrote about the development and construction of high power model engines. It's an attempt to preserve the heritage of a dying breed. Glow plugs, a disposable item, are costing $15+ US dollars these days. I still have memories from the late 1950s of screaming control line speed engines fueled with shoe polish smelling nitrobenzene in exotic mixtures with names like Missile Mist. I hope there is enough information in these articles for an ambitious person to design and build these engines. Unfortunately, I doubt that they live in English speaking countries. I owe a lot of my understanding to several of the members of this forum. Thanks.
    Links are below:
    namba.com/content/library/propwash/2018/october/14/ History
    namba.com/content/library/propwash/2019/april/24/ Modern Piston & Liner Construction
    namba.com/content/library/propwash/2019/october/4 Cylinder Head Design
    namba.com/content/library/propwash/2020/april/4/ Tuned Pipe Design
    namba.com/content/library/propwash/2020/October/4/ Port Design & Scavenging
    namba.com/content/library/propwash/2021/march/16/ Mechanical Design
    Lohring Miller
  13. #35248
    Links are below:
    Thank you for this comprehensive overview Lohring.
    It was a pleasant (and flattering) surprise to encounter the methanol-burning MB40 engine, although it's not even a boat engine .
  14. #35249
    If one was to be looking at a 24 / 7 intake system, 125, what length would the intake tube need to be???
  15. #35250
    sweden
    I've written down a note from Wobbly, it says 125 mm including end correction, to the reeds approximated opening point, is in tune at 12000 rpm. Probably there is more science to it for a 24/7.
    So, I forgot How many Reflections/inversions that is, and then the Helmholtz? Basically I ain't got a clue.
