Page 2353 of 2762 FirstFirst ... 1353185322532303234323512352235323542355236324032453 ... LastLast
Results 35,281 to 35,295 of 41426
  1. #35281
    4th September 2017 - 10:39
    Daelim besbi 2008
    España
    2 STROKE LUBRICATION
    Currently there are 4 commonly known methods of achieving this:
    1. Oil in fuel
    2. ECU controlled electronic pump, eg Mikuni.
    3. Yamaha Autolube / Suzuki Posiforce mechanical pumps
    4. OMC VRO
    5. Any more?
    Another passive way might be the use of the Marvel Inverse Oiler. As its name implies, it relies on vacuum to draw a flow of oil into the inlet manifold, the flow rate increasing as the vacuum diminishes, ie going to a higher load.
    Any thoughts on whether it has ever been used (successfully) on a 2 stroke?
    Attachment 348764Attachment 348765Attachment 348766
    https://patents.google.com/patent/US...orto+S.P.A.%22
  2. #35282
    28th August 2015 - 00:01
    1975 Hodaka Wombat
    Eugene, Oregon, USA
    Walbro Spiral Diaphragm
    Has anyone tried this?
    https://www.youtube.com/watch?v=xiI_g08H5RY&t=284s
    Lohring Miller
  3. #35283
    Ready to test.
  4. #35284
    It goes under its own power, ripping around the yard.
    All good until the chain came off, forgot to put the clip on. Couldn't find the pliers in my haste, I'll do it later I thought, I didnt.
    Superficial damage only thankfully. But it runs and reasonably well.
  5. #35285
    It goes under its own power, ripping around the yard.....it runs and reasonably well.
    ...Very Impressed ................it lives.........
  6. #35286
    Haha. Inspirational genius foiled by human distraction and impatience. Glad it's not only me. Minus the genius part of course.
  7. #35287
  8. #35288
    28th March 2013 - 04:29
    98 Honda NS1, others...
    Leiria, Portugal
    Hello
    Long time, no posting.
    Been doing my exhaust's, mostly stainless 304, 1mm
    Does anybody have any hacks or tools for getting joint's more acurate without just hamering them? Or even to make the headers round in any other way then a regular hammer?
    Arm and moslty Elbow starting to complain seriously... not strong armed :/
    I think I already explored my hammer technic wheel and its only with about 450g hammer's but still...
    Maybe I should create an electric hammer to beat the header welds or just train the left harm ?!
    Really looking into improving efficiency.
    Cheers
  9. #35289
    Hello
    Cheers
    Have you tried making the headers by hydroforming?
    Avoids multiple welds with potential notches and unplanned section changes.
  10. #35290
    I have to ask , why are you using 1mm - I have tested this twice now on completely different engines.
    0.8 makes better power.
    1mm in SS would be a nightmare to hammer , as you have found.
    But if the cuts are shallow enough , and with well purged welds you dont need to hammer them - in this case , no power lost.
    Edit - added a un hamered pipe pic
  11. #35291
    Where it starts ........
  12. #35292
  13. #35293
  14. #35294
  15. #35295
    Hello
    Cheers
    Hi Romeu, for header section easiest way to use stainless steel 1 mm thick elbows, just cut out them at inside radius, similar to triangle shape, deform, weld and you get conical elbow.
    Like Wob said, long time ago racers discovered that for diffuser, belly and baffle sections, thicker than 0.75 mm and power started to drop.
    https://www.ebay.co.uk/itm/2-5-63mm-...t/112750423829
There are currently 149 users browsing this thread. (0 members and 149 guests)
