Page 2358 of 2774 FirstFirst ... 1358185822582308234823562357235823592360236824082458 ... LastLast
Results 35,356 to 35,370 of 41608
  1. #35356
    14th April 2011 - 23:44
    2008 Yamaha fino
    Bangkok
    Widening the Aux ports to bore center does two things , increases Blowdown STA and increases port linking to the A Transfer.
    You can reduce the effect of linking by making the Aux duct very shallow in depth at its rear wall next to bore center , and also grinding the port shape with alot of taper upwards from front to back.
    This gives alot of area just as the port opens , with the max pressure differential , but reduces the linking time.
    With capped pins the duct can have much less of a tangential exit angle on the rear , top , corner wall , with a nice sweeping pocket that improves flow and power.
    Be carefull with using Frits idea of using Torlon inserts , that effectively blanks off the pin bore in the piston.
    In the TM kart engines this reduced the access of lubrication from transfer flow into the piston bearing surface , and the pin ends turned blue.
    Jan said that the Aprilia did the same , but I never wanted to find out if the pin bore became unreliable.
    Making tophat CNC steel plugs and having them laser welded into stock pins is cheap , and relaible and just as effective power wise.
    Maybe drilling a hole upward in the bottom of the piston pin boss would fix the issue , again I wasnt keen on destroying a motor if this was unreliable.
    The pin ENDS turned blue, but the pin itself not...
    There NEVER was a lubrication problem!!!
  2. #35357
    Thailand, Drag Racing Motorcycles. 150cc 9 sec pass's on Nitrous and the Motorcycle enthusiasts who come to watch.
  3. #35358
    Where do they get those helmets?!.
  4. #35359
    It looks like a car helmet to me. These have a lower visor opening than motorcycle helmets because the driver leans back.
  5. #35360
    You learn something new every day.
  6. #35361
    3rd February 2004 - 08:11
    Wallaceville, Upper hutt
    I have a Bell Star 120 like that from about 40 years ago. Was made in response to the complaint that a regular Bell Star was limited peripheral vision, so this one has 120 degrees peripheral
    (PostalDave on ADVrider)
  7. #35362
    Here is a pic of the small end pin after around 10 dyno sessions in the TM engine with full cover Torlon caps.
    I was way too scared of destroying a customers engine to go any further with that setup.
    Now I can get enough caps CNC'd and have them laser welded into 5 pins for under $200NZD , cheap for the performance gain , and reliable.
ID:	348893   Click image for larger version.
  8. #35363
    15th May 2017 - 14:26
    2002 Aprlia RS125
    Who can do the laser welding in NZ?
  9. #35364
    2nd August 2011 - 11:11
    Connecticut, USA
    Torlon caps
    We have made torlon caps in the same shape as your welded end cap. We see similar signs of heat at the ends of the wrist pin but have not had any failures. Why does the welded cap not show the same signs of heat as a similarly shaped Torlon cap?
  10. #35365
    Foul stroke Ex valves have sodium? Filled hollow stems in some applications for heat dissipation.
    May be a good wristpin solution?
  11. #35366
    DT , the torlon caps I made ( Kentastic actually ) were held in by the clip and covered the pin hole completely.
    But yours colour up , and dont fail ?
    The tophat welded pins allow lube into the piston pin bearing surface - and show no heat issues at all , plus identical power.
    No other difference , so I can only assume for some reason the TM Vertex piston does not have sufficient rear lube entry ( sounds rude , sorry ).
    As I said I aborted the Torlon tests as destroying a customer engine isnt really an option - giant blouse I know.
  12. #35367
    Fly - Laser Welding NZ Ltd in Auckland , not hard to remember.
  13. #35368
    20th June 2020 - 07:10
    ETEC 800
    Minnesota, USA
    I have a few photos saved of what appears to be a pin failure possibly propagated by the plugs. Also an interesting method to secure them. Looks almost like a pin holding them in.
ID:	348896   Click image for larger version.
  14. #35369
    I was thinking about torlon, but had an 'way out there' thought.
    In modern brakecalipers in often american cars, the pistons are made from some sort of plastic material
    Wouldn´t it be able to take the heat as wristpin plugs?
  15. #35370
    I was thinking about torlon, but had an 'way out there' thought. In modern brakecalipers in often american cars, the pistons are made from some sort of plastic material. Wouldn´t it be able to take the heat as wristpin plugs?
    I suppose brake caliper pistons will get hotter than piston pins, so they should be able to take the heat, but taking the heat is no problem for Torlon either;
    the problem seems to be with the pins themselves, and using a different synthetic plug material won't change that.
