Page 2367 of 2775 FirstFirst ... 1367186722672317235723652366236723682369237724172467 ... LastLast
Results 35,491 to 35,505 of 41617
  1. #35491
    4th December 2011 - 22:52
    Yamaha XJ750 1982
    South Africa
    Is he deliberately running a very lean mixture? That would not make the piston of a turbocharged engine very happy. Have you got information beyond the paper, Neels?
    No extra info, sorry.
  2. #35492
    13th December 2018 - 18:06
    youtube andreas länström
    sweden
    Fuel need not be a problem; one can inject as much fuel in the exhaust system as one likes. But what about oxygen?
    In his paper ( https://www.kiwibiker.co.nz/forums/s...post1131186140 ) Lennarth Zander only states that the exhaust gases contain air; there is no explanation how this air could pass through the combustion engine without all of its oxygen being consumed.
    "The afterburnerassistedturbocharger system makes it possibleto ”over scavenge” the engineto lowerthe exhaustport temperaturewhilethe pre turbinetemperaturecanbe maintainedat a decent800 degCtemperature. Not bad for an engineputting outaround50 [kW]."
    Frits, maybe this is what he means. Copy paste didnt work so well, but it's to be found further down in the text.
  3. #35493
    All work no play makes Patrick a dull boy
    It pops and bangs a little before it´s cleaned up, then it pops and bangs when it hits the revlimiter.(13000rpm)
    I sat down in seat and had only about 12psi in rear tire to get some traction on 4th gear(i actually tested a thing)
    The smoke laid thick in the house for a couple of hours, but burnt rubber is a good smell
    I tested new carb jetting as i had a HUGE hole in fuel delivery just before it hit the pipes, now it seems good.
    Special grinded the metering rods and changed the emulsionpipes.
  4. #35494
    24th February 2013 - 08:12
    1993, suzuki rgv250
    I think that he in this particular set up is using an afterburner and "port injection" (not TPI) or carburator (in actual test). Then he states that an oxidation catlyst can be used to increase exhaust temperature before turbine if the exhaust/short circuit is lean/air. I am thinking that if a DI system is used, the short cut will be mostly air.
    On the set up picture from the Charlmers presentation it looks as if they are using one intercooler and then a water cooled charge air section. I can imagine it is important to keep the inlet temp down. The quite large compressor to carburetor intake tract on the test set up must also affect pressure build up. Should be quite easy to optimize by using one charge air cooler (small) and a low temperature radiator circuit with a dedicated pump (of course all about where the engine is to be used)
    Interesting concept and of course still room for much optimization.
  5. #35495
    If I understand you correctly, the engine runs on a normal air-fuel mixture (Lambda somewhere between 0,8 and 0,9) and the air that makes it to the afterburner was blown straight through the engine before exhaust port closure. That sounds plausible and simple .
    It reminds me of a proposal by Keith Duckworth (or was it Colin Chapman?) back in the day when two-strokes were not yet forbidden in Formula 1. He envisaged a two-stroke engine with an extremely high exhaust timing, feeding a turbocharger that was geared to the crankshaft. Whether the crankshaft was going to drive the turbo or the other way around did not matter; what mattered was the power generated by this compound layout. I don't know why Duckworth did not take the idea further. Maybe it was the specific fuel consumption that put him off, or maybe he got the rulebook thrown at him.
  6. #35496
    I guess it's not a regular catalyst we'm talking about? To me, a catalyst is just a lump of stainless steel with honeycomb structure dipped in palladium or something similar. Wondering if he is thinking of something similar below.
    https://patentimages.storage.googlea.../US3220179.pdf
    https://www.researchgate.net/publica...ication_detail
  7. #35497
    sweden
    Colin Chapman it seems. Was it a uniflow? I found random discussion here: https://www.f1technical.net/forum/vi...10966&start=15
  8. #35498
    As i understand, it is just regular ones, but small cores.
  9. #35499
    Yamaha XJ750 1982
    South Africa
    A "normal" catalytic converter as on gasoline fueled passenger cars are "three way" catalytic converters requiring stochiometric AFR.
    The oxidation catalytic converter is a different type that operates in an excess level of oxygen, typically found on diesel engines.
  10. #35500
    21st March 2014 - 22:00
    Hanau, Germany
    And the trick is how to use the washcoat to get the fine precious metal particles distributed and "in place" during the catalysts life time...
  11. #35501
    A prick of a thing to start.
    Technique, exhaust port just open, then boot it, Left boot.
    Two from two today, two attempts, two successes. E85, smells nice.
    No turbochargers here.
ID:	349118   Click image for larger version.
  12. #35502
    So the question is what is your stinger temp...
    https://liu.diva-portal.org/smash/ge...FULLTEXT01.pdf
  13. #35503
    Could it not be that he is referring to something like this: https://emis.vito.be/en/bat/tools-ov...ytic-oxidation
    He also chooses to use the term EBK which in Swedish is the abbreviation for after burn chamber
  14. #35504
    High enough
    Video below prooves that often people overthink things, it´s a normal cat with a small 3hp engine running way rich (colder exhausts) and it lights up quite easily when rich.
    And,, people running lean to light them up......
    Some info:
    https://www.open.edu/openlearn/scien...-section-1.5.2
  15. #35505
    13th August 2020 - 20:54
    Derbi DRD pro
    Finland
    I’d like to share my dyno result (Derbi D50B0) with new head insert even though it’s not pure back to back test as 1. old head had leak and 2. I changed squish from 0,5 to 0,4mm.
    Peak was moved 400 rpm lower and some over rev power was lost. Dashed line is new one:
    More than half of over rev power was gained back and little for peak with ignition adjustment. 1 degree more advance on peak power and 1 degree later timing for over rev. Dashed line is with new advance curve:
    I made also some testing with different reeds. Test was done with 10mm spacer between block and crankcase and with no changes to ignition or jetting. I had been running with CR85 reed block and boyesen fiberglass 0,49mm petals. Malossi VL18 0,32mm carbon fiber (dashed line) was only better at over rev and worse in before.
    Original Honda 0,41mm petals (dotted line) had also better over rev compared to boyesen with slightly reduced top:
    Honda petals looks bit different than normal fiberglass, they look like fiber reinforced plastic.
