Page 238 of 2773 FirstFirst ... 1381882282362372382392402482883387381238 ... LastLast
Results 3,556 to 3,570 of 41590
  1. #3556
    5th June 2008 - 17:46
    I get the slight feeling you may be a rotary valve fan TZ? Spotted a pic of these outboard reed valves and was amazed, I forget bikes aren't the only things using these engines, and that some of the other applications are on a much larger scale than the tiny things we are playing with.
    Will you use an external reed block on your new RGV/TF engine?
Name:	monster reeds.jpg
  2. #3557
    Yeah that's the same type of reedblocks I'm using on the MB, but I'll have to use at least two braces of them.[Tui add]
    Funny talking about R/A grinders. I was just thinking last night that I wish Dremel had made a mini RA flexidrive doofah. Well I went to replace my Dremel yesterday (I have a large Bosch grinder & two size air grinders which are nice, but sometimes for a quick job the Dremel is easy), anyway my old one is rattley after 20 years of hard work, so I buy a new 400 & notice they have a RA tool for 50 note.
    Hmm, pretty big, oh & then the bits have to go in. So I'm holding it wondering if I could strip it down & spot weld a bit right close to the bevel part. Ahh sounds like a drama, must go see my mate with the dentist tool & see if I can persuade him to sell it now. Problem with the dentist tool is they have tiny bits & no torque. Great for correcting corners and defects, but not much else.
  3. #3558
    Rick52
    Rick52 rode the wheels of his new bike and won or placed all day in "A" grade.
Name:	Ricks Base Runs 005.jpg
    When the bike was run up on the dyno it was found to have 18-19 rwhp.
Name:	A0 Ricks and TZ Runs.jpg
    Comparison of Rick52's 18-19 rwhp with a Team ESE bike.
    Sunday showed how talented Rick realy is and if he ever builds up that GP125 engine he has in the ESE style and gets 27+ rwhp he will be very dangerous and the 4-Strokes could prety much kiss it goodby at Mt welly.
  4. #3559
    Sunday showed how talented Rick realy is and if he ever builds up that GP125 engine he has in the ESE style and gets 27+ rwhp he will be very dangerous.
    What was evident from the sidelines on Sunday was how much quicker Rick was entering the corners, every corner!
  5. #3560
    Rick52
    . . . peaking at 8700. so not a rev monster then. one might hazard a guess that its farmbike origins are still somewhat to the fore.
    'cmon Chris (RMS) run a riffler up there.
  6. #3561
    Fantastic work team ESE. Love watching the development.
    Time to (be the second to) crack that 30hp mark!
  7. #3562
    I am hoping to be the first, to post a dyno graph of 30+ rwhp from a bucket..........
  8. #3563
Name:	AA Glue is still there.jpg
    After 40+ dyno pulls at near 30hp the glue blocking the oiler holes is still there inside the piston..
  9. #3564
    Tried one of Chambers pipes that he designed using Blairs formulas and it made 29 rwhp so not bad for a pipe design from a spread sheet. The Spread Sheet can be downloaded from page 200, post 2988.
    The plan is to raise the transfers from opening 116 ATDC to 114 for a litte more Transfer Time-Area.
Name:	A1 Rasing  the transfers TeeZee.jpg
    The first step is to find 114 ATDC with a degree wheel.
Name:	A2 Rasing  the transfers TeeZee.jpg
    Then use Marking Blue and a Scriber to set the new Transfer Port height.
Name:	A3 Rasing  the transfers TeeZee.jpg
    Ports marked out. The cylinder has garks from my porting work and had done a turn on some road bike before being purchased on Trademe and it still makes good power, will rebore it when the experimenting is all done.
Name:	A 29hp Graph.jpg
    Its a gamble rasing the Transfers as that will reduce the Blow Down Time Area. But I am betting there is a little blow down to spare and its the short Transfer Time Area thats holding it back and a little more will phaten up the lower part of the blue lines Torque Curve and hopfully crack the majic 30 too.
  10. #3565
    24th July 2008 - 18:01
    Honda RS 125 1992
    Taupo
    Sunday showed how talented Rick realy is and if he ever builds up that GP125 engine he has in the ESE style and gets 27+ rwhp he will be very dangerous and the 4-Strokes could prety much kiss it goodby at Mt welly.[/QUOTE]
    Cheers fellas your making me blush The new bike is 30kg lighter and has more power much better brakes and handles like a dream !If I didn't get quicker with this bike I should be just watching the racing...I need to ride this bike better before getting more power I think ..Better ignition from a Cr85 next and a engine strip down re-build ...
  11. #3566
    Man after our battles at Taupo I was thinking it had more power than that. When you were coming out of the corners there was no way past. It just took off.
    Thats it I am officially on a diet bike to.
    Scuse me while I vomit.
  12. #3567
    [QUOTE=TZ350;1129985663]The plan is to raise the transfers from opening 116 ATDC to 114 for a litte more Transfer Time-Area.
    Its a gamble rasing the Transfers as that will reduce the Blow Down Time Area. /QUOTE]
    There's enough metal there to widen the main transfer ports toward the exhaust port - more time/area but same blowdown
  13. #3568
    Cool pic, got me thinking of this one...
    Thats some serious reed area!
  14. #3569
    Good tip, I will give that a go first, also I will elongate the Ex side port tracts like you suggested before, too.
  15. #3570
    Ive been dabbling with this engine for sometime now, when TZ350 started his RGV project we got together and started working with Wobbly to acheive a reliable and fast package. Some things are different between our camps, cohice of bottom end being the main difference. Ive gone with a RG125 its similar to an rg150 but not the same , I dont think they were imported to NZ but some electric bike guy sold it to me as he despised all things petrol.
    I would be a starter for a RG125 engine, any condition, if I could get one, so if someone has one they would sell please PM me.
There are currently 44 users browsing this thread. (1 members and 43 guests)
  1. Sketchy_Racer
