Page 2384 of 2774 FirstFirst ... 1384188422842334237423822383238423852386239424342484 ... LastLast
Results 35,746 to 35,760 of 41608
  1. #35746
    13th December 2018 - 18:06
    youtube andreas länström
    sweden
    Thanks Wobbly, I think it's a 120/70 right now. Less profile will help?
  2. #35747
    Stay at 120 but lower the section height , this keeps the grip , lowers the front and puts more weight transfer into the front tyre when turning in.
  3. #35748
    sweden
    Ok, I understand this will reduce the trail. It respond quickly but just needs a lot of counter steering or leaning out.
  4. #35749
  5. #35750
    sweden
    Thanks Husa.
  6. #35751
Name:	Blue WOT Red Part T.jpg
    Thanks to everyone for the helpful suggestions, they all made sense.
ID:	349430Click image for larger version.
    I have now modified the air correction and idle air on the carb with replaceable jets to make it easier to find the optimum air correction. I also now have a programmable digital ignition so I can bend the ignition curve for a bit of drive out of the corners and pipe heating for over rev.
    Once I get the ignition installed I will get it on the dyno to see what the effect is and if I can duplicate the Red line in the over rev area.
  7. #35752
    A combination of the power curves will be nice, the good bits of course.
  8. #35753
    Yes. Going to see what can be done. I am currently converting a Chinese magneto thing to a generator to power the programable ignition. Basically it will be just a push and go system. No battery just generator, voltage rectifier/regulator, capacitor and DC-CDI programable ignition that creates its own CDI charge from the 12V DC power supply.
    Making a decent ignition from a Chinese aftermarket thing:- https://www.kiwibiker.co.nz/forums/s...post1131033289
  9. #35754
    Hey all! Bought a chainsaw today. wanted double the price if I would get one with 3hp instead of 2hp. started it and did not feel so fun, maybe I can fix it a bit (did I sketch on an exhaust) ... Are there any here who have fumbled with chainsaws? Also had carburetor lying around. It's a 35cc.
ID:	349438   Click image for larger version.
Name:	Skärmavbild 2021-08-06 kl. 01.50.10.jpg
ID:	349439   Click image for larger version.
  10. #35755
    I'd tune it for max power ignoring the fact if what it has to interface into.
    I'm a bit stupid that way.
    Can you put a clutch on it to fan the revs up a bit?
  11. #35756
    2 Stroke Stuffing.
  12. #35757
    3rd February 2004 - 08:11
    Wallaceville, Upper hutt
    Something like this?
    (PostalDave on ADVrider)
  13. #35758
    28th August 2015 - 00:01
    1975 Hodaka Wombat
    Eugene, Oregon, USA
    We modified a 35 cc race engine to give almost 12 hp. We changed to a high rpm pipe and lost 2 hp but could run the engine to its mechanical limit around 23,000 rpm. See https://www.modelgasboats.com/magazi...-record-engine for the details of our testing and modifications.
    Lohring Miller
  14. #35759
    The stuff is not the most robust on the market so it will not be any 15000k, but what can you expect for 300 €. Exhaust, I think it should get at least. Was out and used it today and it is quite weak. Disassembled it when I was done outdoors. The port geometry and engine design are almost made to be able to adjust (or not) ..
    If I manage to squeeze out 3-4 hp, I am more than happy
ID:	349441   Click image for larger version.
ID:	349442   Click image for larger version.
  15. #35760
    Tighten up squish and raise compression, raise ports back up to where they were, a little more intake area... and that's it.
    A full expansion chamber you'll need to rev it more, and I don't think you'll have as widen of a powerband without a lot of pipe development. The stock cans on engines like this are really good for the powerband they need to run in.
