Page 2394 of 2774 FirstFirst ... 1394189422942344238423922393239423952396240424442494 ... LastLast
Results 35,896 to 35,910 of 41608
  1. #35896
    Just buy straight ethanol and mix your own.That way you get just what you want.
  2. #35897
    Flettners MK2 360 TPI.
  3. #35898
    2Stroke Stuffing's latest adventure.
    Its great to see people getting their projects running.
  4. #35899
    Muhr , all the weld jigs I have seen or used , have the axis vertical with 3 sprung loaded pincer legs fixed to the 3 jaws.
    That way by adjusting the 3 jaw diameter any pipe section can be gripped . Having the weld run horizontally past you gives a much better view of the seam approching the arc.
    Muhr, I saw this on the fakebook a few years back. Always wanted to cut a hole in my bench and run the three jaw manually with a foot wheel with some drag on it. (I gas weld so no tied up foot)
    Thank you! I had hoped to be able to make something that can withstand when it is loaded at an angle when it begins to twist. I'll try to do something as below.
Name:	Skärmavbild 2021-09-25 kl. 21.14.55.png
  5. #35900
    Took the 360 out for a tuning run yesterday, didnt go as planned, charging system stopped working bugger it.
    It had moments of brilliance.
  6. #35901
    Flettner. The 360 Lives .......
  7. #35902
    How a two stroke sleeve valve engine works.
    Flettners two stroke sleeve valve engine running.
ID:	349723Click image for larger version.
ID:	349720Click image for larger version.
ID:	349721Click image for larger version.
  8. #35903
    Anyone know of where a TZ250 H J may be hiding here in Aotearoastan.
    There was one in the Morley Engineering Superkart , and another that came out of Gingers kart and went into a YamaGamma built by John Reid.
    Cheers
  9. #35904
    Cheers
    pretty sure that was john reids old yamagamma chassis that wa sold a few weeks ago wasnt it.
    looked like a TZ rad and a Dymag rear and.
  10. #35905
    Yep trying to find the engine for that chassis.
  11. #35906
    Have you tried the Wiltons
    if its around i would say they might know where it was.
    Ps Did it was with that 16 front wheel?
  12. #35907
    3rd May 2017 - 04:03
    1997 Yamaha rd 350
    Russia
    Speeduino compatible Fuel injection and digital ignition boards
    Our very small 50x50mm open source boards (Speeduino compatible can be programmed) are manually soldered and ready for testing. Pressure, air temperature sensor and non-contact magnetic position of the throttle valve are on the board, but it is possible to connect external ones. Both inductive and Hall crankshaft and camshaft sensors are supported. A bit more extended version will have CAN support + temperature control under spark plug and exhaust gases.
  13. #35908
    10th December 2016 - 13:02
    Yamaha
    Eskdale
    Well done
  14. #35909
    2Stroke Tuning. When things go wrong .......
    2Stroke Tuning supercharged 50 is running better now ........
  15. #35910
    Hill climbing with a H2 750 Kawasaki, great sound of a 2Stroke ripping it up.
