Page 2401 of 2774 FirstFirst ... 1401190123012351239123992400240124022403241124512501 ... LastLast
Results 36,001 to 36,015 of 41606
  1. #36001
    Kentastic had designed something very similar ( in aluminium ) for KZ2 some time ago , sadly having a business that makes money is strangely more important.
    Ahah WWW, would you be referring to that piston design which was/is novel, lighter, stronger and more durable?
    Unfortunately though, nothing strange going on here.
  2. #36002
    Quote Originally Posted by Suzuki nut View Post
    Do you have any photos of the Suzuki RK67? I am after a photo of the underside, which shows all the cooling fins
Name:	rk67 engine 1.jpg
ID:	349908 Click image for larger version.
Name:	rk67 engine left 1.jpg
    Underside-pics are rather rare; this is the best I can do.
  3. #36003
    I have been thinking a bit about making a piston in Inconel or some other high nickel alloy. fumbled a bit in the computer but feeling that succeeding in doing something that could be good is a challenge ... will be a little easier to find benefits if the piston gets bigger (or at least bigger than 50cc that I looking at)
    Attached Thumbnails Attached Thumbnails Kolv 50cc v1.pdf   Click image for larger version.
Name:	Skärmavbild 2021-10-27 kl. 23.55.25.png
ID:	349916   Click image for larger version.
Name:	Skärmavbild 2021-10-27 kl. 23.55.38.png
ID:	349917   Click image for larger version.
Name:	Skärmavbild 2021-10-27 kl. 23.52.07.png
  4. #36004
    Muhr , I think one important element of a " better " piston design is hinted at in the lovely 4T pics , and from what I can remember about new Ken's proposal is that
    the pin boss in the piston only needs support at its ends , not along its length ( not even with the small triangle as you have shown ). Having one end supported by the skirt , and the other
    end held by a thin flat support directly up to the dome does double duty. This can be extended in a bigger piston, in that the pin does not need to go anywhere near as wide as the skirt , but can be supported
    again at each end with a thin flat support up to the dome.
  5. #36005
    I'll ask the CNC nicely if it might unprint a piston from this steel bar for me. Actually a composite, not the complete piston.
    48mm dia.
  6. #36006
    As with just about everything, it turns out it isn't unique. That good man Frits posted a pic of a design that was very similar. It's somewhere here within ESE. Happy searching.
  7. #36007
    Sorry no
    1 a 3/4 at best
    Hugh Anderson had one here for a while
    Elsberg has pics of the 3 underside and others.
    http://www.elsberg-tuning.dk/suzuki.html
    looking at a picture i found it looks like the Jaoanese publication the racer may have done a story on it with drawings
    https://www.youtube.com/watch?v=79xuDS9l8vI
    protar have kits as well it seems
    it looks like the Lexmond Museum has one in the NetherlandS?
    is this you
    https://www.youtube.com/channel/UC1f...4W13sxnzfWBKtA
  8. #36008
    . . . 48mm dia.
    flash new FZR250 pistons?
  9. #36009
    Here you go, Ken & Muhr. A high pin, because most of the piston mass is between the pin bosses and the crown, and a high pin makes for a lighter construction.
    Direct support from the crown center to a short pin and direct heat paths from the crown center to the bearing areas of the skirt.
Name:	FOS piston54.png
  10. #36010
    Yes my attempt is certainly no masterpiece, had a hard time not getting any ovality under heat and load.
    with a lot of testing, you should get closer to 0.01 piston clearance, and then have to preheat the engine before starting. Which would be pretty racing.
    With 5-10% of the thermal conductivity and almost a third of the expansion, you can probably encounter several interesting consequences
  11. #36011
    Maybe even this helps to keep the engine operating temperature some degrees lower, without the risk of piston seize.
    Before this year testing with directly through transfers intake configuration, on Honda RS 125 cylinder, I am worried about higher expansion 2618 alloy special piston in comparison with Honda RS origin.
    But the biggest surprise was opposite results. 2618 alloy piston with inner walls, surprisingly worked from 38C to 44C temperature without signs of seize. Then first ride with std intake configuration and original Honda RS piston at this temperature, ended with slightly jammed piston ring on EX side. This repeated more or less every time with Honda pistons until I covered part of radiator with tape and operating temperature rises to 50C - 58C.
ID:	349927   Click image for larger version.
  12. #36012
    13th December 2018 - 18:06
    youtube andreas länström
    sweden
    Katinas, what an intriguing piece. How does that transfer-shortcircuit-passage work, looks as if it's covered by the skirt at bdc?
  13. #36013
    Try as they might, these misguided 4 stroke guys have gone to a lot of trouble to try to emulate Fletto's sliding gibs. Must say this one's quite clever though.
    https://www.roadandtrack.com/new-car...ZUjLt8FOv0E50Y
  14. #36014
    A 4% increase in power? Wow that's a game changer. Probably get that much variation between production engines.
  15. #36015
    Andreas, actually this is two intake passages opens and closes at the same time with A and B that works like intake ports too (intake duration through this six ports 206 degrees)
    This passages compensate intake restrictions of A, that was partly covered by the piston skirt due to overlap of two exhaust port configuration of the Honda RS cylinder and not needed for narrow one exhaust port type.
    This passages only works with intake through transfers configuration, but useless or destructive for normal intake/scavenging type.
Name:	Intake through A restrictions.jpg
ID:	349934   Click image for larger version.
