Page 2417 of 2776 FirstFirst ... 1417191723172367240724152416241724182419242724672517 ... LastLast
Results 36,241 to 36,255 of 41630
  1. #36241
    20th June 2020 - 07:10
    ETEC 800
    Minnesota, USA
    The foredom motor just dangles above me. It is the hollow shaft in the hand piece that snaps where it sharply transitions to the tiny threaded end with no radius that screws into the gear in the grinders head. Partially my fault for getting wedged up in stupid places. Still, I do not care for the way that the hollow shaft was made.
  2. #36242
    24th January 2014 - 08:12
    1988, Yamaha RD350 YPVS
    I had pretty much everything available in Europe...
    Proxxon, Dremel, Foredom, JoKe....
    Joke: not enough RPM
    Foredome: the flexible shaft was not really flexible, the chuck was fitted with a cone and dropped from that connection ever 15 minutes.
    Dremel and Proxxon: good rpm, but not enough torque.
    Today, I am using this motor
    https://www.zujeddeloh.de/produkte/g...00--_3103.html
    (the shaft snaps right away... This sucks)
    this handpiece for rough work
    https://www.zujeddeloh.de/produkte/g...ng--_1470.html
    an ebay find handpiece with 2.35 & 3.00mm chucks for fine work.
    and for the fine in cylinder stuff a kavo 195 90° handpiece.
  3. #36243
    https://youtu.be/977BWjCMC8E
    https://youtu.be/mS0cyt7F9js
    https://youtu.be/CLn4tsz8M1s
    Flettners flying Gibs in action:- As I understand it, these are "Fly by Wire" activated and they are part of the face of the rotary valve cover and basically open/close the normally fixed aperture in a rotary valve cover. The idle circuit is a very small reed valve about the size of your thumb nail. The idle reed valve is adjusted by a screw that limits how much it can open.
  4. #36244
    8th December 2014 - 14:39
    1980 Suzuki Gs1100E
    SWPA
    Condyn
    When you say the motor just dangles above you how do you have it anchored or held above you. Is it just hanging on one of their holders or hanging by a nail or eye screw or wire?
    I've had 3 of these handpieces and have never had any trouble. I bought my first one in 1972-3. I believe back then it was called a #57 handpiece. But I could be wrong. The one I have now was bought in 1993-4. In fact the one I have now is labeled ARTCO M-1036. Since then they have changed their numbers to 1039. I guess it's possible they cheapened up some of the components but the parts sheet for the 1039 is still the same as for the 1036 on ARTCO web page.
    I have an old C.C. Specialty catalog (2009) and the parts sheet shows 2 shafts, one is a outer shaft called the 'Round Drive Shaft' and the inner shaft is called the 'Keyway Shaft'. Now I received this catalog in 2009 and the prices were Round Drive Shaft= $29.25, and the Keyway Shaft= $17.35. But like I said it's 10 years old. I don't know how much ARTCO wants but you could call.
  5. #36245
Name:	Fixed vis Programable.jpg
    Fixed verses Programable ignition. The Red line is a fixed timing KX80 ignition on my RG50. The Blue line is an optimized Ignitec programable ignition.
  6. #36246
    6th February 2012 - 08:54
    1988 cagiva freccia
    france
    do all ignitech p2 race have input for the deto sensor? or is it an option to add?
    I use the Czech deto count recommended by wobbly
    I can't find the information in the documentation
  7. #36247
    It has an optional output on det counter from memory. Then you input that to ignitech and reduce ignition several degrees. Um, what's it called again? Bugger sorry too long ago.
  8. #36248
    Yes the Czech deto module can output 0-5V for data logging and or drop an output to ground ,this wire is input to any Ignitech that when grounded
    it will pull out any amount of programmed static advance ( say 3* ).
    Only issue is you then have no record of it happening as the Ignition response is so fast you miss seeing the deto red light , but if you have it ,you will see close to 5V on the deto data stream.
    Working backward you can then find the TPS and rpm where det was being corrected , and change the advance curve to eliminate the feedback control.
    I asked Ignitech years ago to incorporate an auto curve correction , but for some reason they refuse to talk to me - even though I sold literally hundreds of the things and became an international
    " help desk " for free. They still owe me 4 ignitions returned for repair over 3 years ago - and guess who had to replace the customers product . I refuse to even look at one now - Ignorant fucks.
  9. #36249
    Does anyone think they have the best design
    https://m.youtube.com/watch?v=G8L9_XO3iCw
  10. #36250
    4th May 2018 - 20:26
    Kreidler 1976 RS
    Netherlands
    fixed against prgrammable
    May be the fixed one was not set at the right time.
    At max power both should have the same pre ignition !
    At lower speed the power is the same, which should be different in favor of the Ignitech progr.
    This suggests that the fixed ignition was too late.
  11. #36251
    Fixed in this case is not straight line so we have our definition aligned. Fixed TZ here means fixed curve, so could be retarding like heck after 11 or 12,000 for example which is fine a dirtbike perhaps but not on road race engines.
  12. #36252
    I am using the Czech deto device on my RS250.
    But I rather test this little bugger here: http://www.bylund-automotive.com/edu...ock/index.html
    Has anyone played with it before?
    @Muhr:
    The bellmouth test is interesting - unfortunately, they mixed tuned inlet length variation and bellmouth variation. Which causes a shift in rpm range. To get the result which bellmouth is best, you need to vary the inlet length to reach the same rpm peak (since the tube end of a bellmouth is not easy to define).
  13. #36253
    Goes on its first trail ride tomorrow, should be interesting.
    Laptop all charged up. Ive mixed up 20L of E85, optimistic?
    https://youtube.com/shorts/rxc1OFcQgPM?feature=share
  14. #36254
    Tim , I have tested several LSU detectors , and have a 14 Point 7 one on my dyno that outputs Lambda and or 0-5V for logging and an on screen red warning.
    The el cheapo Czech unit does a few things way better than anything else.
    Its super simple to quickly rev your engine against some load - in gear brake on , load up with the clutch , and adjust the sensitivity to get all but the last led to light up.
    Then on track the last red deto light is guaranteed to be a "real " harmful deto level.
    Also the optional grounding output works perfectly with det retard on an Ignitech , and the 0-5v is simple to data log.
    But , one thing to note ,only proper Lambda units like a 14 Point 7 or a Innovate LS2 do the required pre heating cycle on the Bosch 4.9 prior to applying power to the sensor.
    As the unit you have shown is Arduino based then an led array and pre heat will all be possible - if the developer or someone else is competent enough to do the electronics and code.
  15. #36255
    1988 cagiva freccia
    france
    thanks wobbly for the connection indications
There are currently 92 users browsing this thread. (2 members and 90 guests)
  1. jonny quest
