Page 2425 of 2776 FirstFirst ... 1425192523252375241524232424242524262427243524752525 ... LastLast
Results 36,361 to 36,375 of 41626
  1. #36361
    4th December 2011 - 22:52
    Yamaha XJ750 1982
    South Africa
    Hi i am confused Nearly every case i have seen short of a 1960 old villers/ greeves is radius below the casedeck?
    Interesting - I saw the inner radius of the transfer port as the radius on the sleeve side of the port?
  2. #36362
    oh i get it (only after he actually looks at Frits pic again)
    Still fairly common
    cagiva
    YZR500
    NSR500
    Cant remember what this one was later oh KR3
    NSR or RS cant recalll
    when we were sharpening septums to razor shapeness that inner area got a radius as well
    Just like we were taught from looking at pictures in robinsons, book the sharp point kept them cool at Mach 3
    i cant remember where i seen it but there is an odd looking bump in the unmentionable RSW500.
  3. #36363
    Quote Originally Posted by tdc211 View Post
    Frits. How's that inner radius below the case deck work?
    New yz85 is like this. I didn't know what to think about it.
    I'm not sure I understand your question. Do you mean the radius indicated in the picture below?
Name:	edge radius arrow.jpg
  4. #36364
    Yes i think he means this bit Frits with the inner radus continues lower than the machined deck height of the cylinder. (Thanks for correcting me Neels)
    Now i am going to spend an hour looking for that the weird looking protrusion on a RSW500.
    okay 27 minutes
    Any ideas re the shapes of this
    It looks nothing like any of the other Aprila or Rotax tranfers in design
    it almost looks like a different guy did designed the inner side than the outer sider?
    Was it just as they tried to use the skinny 250 case?
  5. #36365
    13th August 2020 - 20:54
    Derbi DRD pro
    Finland
    While were at it, I’m curious about this double radius:
    What is the reason for “step” and radius change at case deck?
  6. #36366
    Now i am going to spend an hour looking for that the weird looking protrusion on a RSW500. okay 27 minutes
    It looks nothing like any of the other Aprilia or Rotax transfers in design. it almost looks like a different guy did designed the inner side than the outer side? Was it just as they tried to use the skinny 250 case?
    You're spot-on about a 'different guy' Husa.
    The RSW500 was the brainchild of Aprilia's then-technical director Jan Witteveen. It was an extremely-short stroke engine and Jan Thiel did not want anything to do with it.
  7. #36367
    Quote Originally Posted by sniemisto View Post
    This was a case of mutilating a new cylinder design because it had to fit old-type crankcases. You also see it quite a lot on aftermarket big-bore cylinders.
  8. #36368
    22nd September 2012 - 16:31
    1995 kx 125
    Piston at bdc. ktm cylinder next to it
ID:	350416   Click image for larger version.
  9. #36369
    14th April 2011 - 23:44
    2008 Yamaha fino
    Bangkok
    This is particularly bad...
    This is the main cause why big-bore cylinders usually give diappointing power....
    The transfers become too small!!
  10. #36370
    2008 Yamaha fino
    Bangkok
    This radius gave about 0.4HP more...
  11. #36371
    2008 Yamaha fino
    Bangkok
    okay 27 minutes
    This engine was a complete failure, best power was, of course, reached when it was finally enlarged to 500cc....
    I still don't understand why they needed 5 years to discover it....................
    It just shows how little they understood about engines!
  12. #36372
    2008 Yamaha fino
    Bangkok
    Enlarging a 250cc engine proved to be a totally wrong idea....
    Of course the short stroke engine was always short of power.
    And when it was finally enlarged to 500cc the gearbox broke....
    Small wonder, as it was basically made for a 125
    The 250cc tandem used already the 125 gearbox, sometimes broke..
    I still think a well-made 500/2 could have won!!!!
  13. #36373
    Cheers Frits and Jan
    https://www.honda.co.uk/engineroom/w...the-honda-nsr/
    I read this today on Hondas own page
    Now i never worked at HRC
    But i do know the RS500 never had two cranks or Disc valves.
ID:	350419Click image for larger version.
ID:	350420Click image for larger version.
    Nor did the Switch to unleaded make it needed to be switch back to 180 crank.
Name:	NSR 500 crank-sprocket (1).jpg
    One often over looked advantages of the 3 was it had a lot f room for wide swept transfers as well as full width cadges as did the Single cranked NSR500.
    Of course the Tandem and the cranked tandem Aprilia had this room as well.
ID:	350423Click image for larger version.
    I seems Honda has forgotten.
  14. #36374
    Always thought a 500VTwin would make a cracking roadbike in the 90s. . . . If only someone made one. . . .
  15. #36375
    It's here, just waiting on a suitable gearbox.
    Wayne Blackwood has an R1 gearbox lined up.
    A 700 twin, start looking for R1 gearboxes, if you want one.
There are currently 50 users browsing this thread. (0 members and 50 guests)
