Page 2429 of 2775 FirstFirst ... 1429192923292379241924272428242924302431243924792529 ... LastLast
Results 36,421 to 36,435 of 41617
  1. #36421
    There are people in this world that uses an Excel spreadsheet and acoustic theory to create what they claim is a simulator that calculates what your exhaust pipe should look like.
    They publish this mostly on Farcebook so I thought it would be a good idea to add another installment on gasdynamics.
    Please give comments so I can improve this.
    I am terribly sorry to have to say this, Neels, but your dissertation CAN'T be improved .
    Well okay, one minor misspelling: "Typical pressure pulses in an engine has amplitudes..." should read '..HAVE amplitudes...".
    Did you have one particular Fakebook contributor in mind (Michael Forrest) or are you dedicating your treatise to all the Dunning-Kruger cases over there?
    https://en.wikipedia.org/wiki/Dunning%E2%80%93Kruger_effect
    Neels, would you kindly allow me to share your Gasdynamics 101 ?
  2. #36422
    4th December 2011 - 22:52
    Yamaha XJ750 1982
    South Africa
    Frits, please feel free to share wherever you like.
    I might later fix the grammar error but not now.
    And yes, you know exactly who it is aimed at.
  3. #36423
    20th June 2020 - 07:10
    ETEC 800
    Minnesota, USA
    I have never seen somebody promote propaganda quite like “ he who must not be named “
  4. #36424
    6th February 2012 - 08:54
    1988 cagiva freccia
    france
    Facebook the worst time waster. everyone is an engineer, doctor, economist, tuning engine
    the easier access to knowledge, the more people seek and choose the easiest even if it is false. which increases the spread of stupidity.
  5. #36425
    12th October 2016 - 01:24
    1964 Vespa GS
    San Francisco
    Other than the impracticality of packaging, is there any reason the intake can't be placed on the exhaust side of the cylinder?
    The thought came while working on the base of the transfer ports and I just kept looking at all that unused real estate below the exhaust.
Name:	Screen Shot 2022-01-21 at 10.40.47 .png
    Patrick Owens
    www.OopsClunkThud.com
  6. #36426
    ETEC 800
    Minnesota, USA
    Arctic Cat ( Suzuki ) engines have case reeds on the exhaust side. They tilt way back in the chassis, giving them the nickname “ laydown “ engines.
  7. #36427
    It's not your parallel-twin (it's the Dutch Rimar 600V2) but it might give you some pipe-fitting ideas.
    Attachment 350439 Attachment 350440 Attachment 350441 Attachment 350442
    Pretty sure fletner did a tornado chamber for one of the creations already
    plus with 700cc he can give away a few HP
    Whilst not as Shinny but very petite Mr Mike Green's earlier chamber. off the web
ID:	350445Click image for larger version.
ID:	350446Click image for larger version.
ID:	350447Click image for larger version.
    Scooters also use some lever tricks for packaging
  8. #36428
    24th January 2014 - 08:12
    1988, Yamaha RD350 YPVS
    On behalf of the gearbox for the 700cc: It seems it was done before.
    https://grabcad.com/library/gearbox-...lled-on-kart-1
    Regarding the piping in a 700cc twin: you can always go the 2in1 way. Otherwise making the pipes thinner should not kill all the power if done proper.
    And regarding packaging in the most complex ways, have a look at the vespa scene:
    https://falk-r.de/
    http://pipedesign.de/home.html
  9. #36429
    I have managed this reverse pipe ok. Single cylinder 360cc, YZ 250X gearbox. Just double it up.
ID:	350452   Click image for larger version.
  10. #36430
    https://www.cycleworld.com/2016/02/2...orld-classics/
    Powering the Tul-Aris is a highly modified Polaris snowmobile engine. The two-stroke Twin has been enlarged to 780cc with hop-up components intended for snowmobile competition, though the straight-shot expansion chambers actually allow it to make more power than in a sled–165 crankshaft horsepower. The engine breathes through twin carburetors and reed valves at the front.
ID:	350454Click image for larger version.
    And smart enough to mount the water pump real low.
  11. #36431
    Living the dream........ quitting regular work for a life of following his passion. I take my hat off to everyone who has done that.
  12. #36432
    So I guess we make the 700 twin fit an R1 chassis, as we have one.
    Im not a fan of bolting everything to the engine, as a stressed member.
    Or for my own road bike, make my own frame, twin shock, more room for stuff to fit.
  13. #36433
    Down the page from Tim's link to the Rotax gearbox
    was this pic of a pair of pipes neatly arranged on the side of the machine.
    Obviously, for a motorcycle, you would need to put a saddle on top,
    Cheers, Daryl.
  14. #36434
    13th December 2018 - 18:06
    youtube andreas lδnstrφm
    sweden
    Those are all good ideas, be interesting to follow either one.
  15. #36435
    2nd May 2020 - 21:05
    Aprilia RS125
    Barcelona
    There are people in this world that uses an Excel spreadsheet and acoustic theory to create what they claim is a simulator that calculates what your exhaust pipe should look like. They publish this mostly on Farcebook so I thought it would be a good idea to add another installment on gasdynamics. Please give comments so I can improve this.
    Attachment 350438
    Thank you Neels for sharing this knowledge, so far my understanding was “sound waves type” .
    Now I am modifying a Rotax 122 cylinder, and I need to increase blowdown sta. For not increasing exhaust timing, my intention was to make the auxiliary ducts taller, but after reading the gas dynamics article now I think there is possibility of contributing to a shock wave that looses energy as heat.
    For increasing peak power, Is there a rule of thumb for auxiliary vs. main exhaust port timing?
