Page 2430 of 2774 FirstFirst ... 1430193023302380242024282429243024312432244024802530 ... LastLast
Results 36,436 to 36,450 of 41608
  1. #36436
    13th December 2018 - 18:06
    youtube andreas länström
    sweden
    If it's a rule of thumb, I think 3-5* delay ie. double total, for the aux goes.
  2. #36437
    2nd May 2020 - 21:05
    Aprilia RS125
    Barcelona
    Thank you andreas. That is around 2 mm, then I still have a bit of margin.
  3. #36438
    28th August 2015 - 00:01
    1975 Hodaka Wombat
    Eugene, Oregon, USA
    That's no where as bad a mistake as filling the tank with gasoline only, no oil mix. That's really hard on an engine at 15,000 rpm or so when the piston seizes.
    Lohring Miller
    Living the dream........ quitting regular work for a life of following his passion. I take my hat off to everyone who has done that.
    Attachment 350460
  4. #36439
    6th February 2012 - 08:54
    1988 cagiva freccia
    france
    expand boosters to increase blowdown
    quick superimposition with photoshop of the pvp cylinder (Aprilia copy) portmap with that of the 122 cylinder the setting of the port heights is not respected.
    It gives you an idea for the shape of the ports.
Name:	rs125 vs PVP.jpg
  5. #36440
    Aprilia RS125
    Barcelona
    Merci philou!
    That will be a good inspiration. I am limited by a piston pin without plugs, but there is plenty of mm2 there.
  6. #36441
    1988 cagiva freccia
    france
    I did not raise the engine myself or create the engmod2t file. so to check on a cylinder in real life.
    data on transfers and TA values of the stock cylinder.
    a lot of work on the transfer ports. widen the B backwards and angle upwards for A and B
  7. #36442
    Aprilia RS125
    Barcelona
    Merci philou!
    My plan is to raise transfers 0.6 mm and I will try to do the angle upwards too. With the tools I have, I can widen the B transfer only a bit. Do you know if there is a benefit on widen C transfer too?
  8. #36443
    1988 cagiva freccia
    france
    the C is already too wide
    the B deserves to be widened to a close to the C
    on the file the B (12°) has an upward angle greater than the A (5°).
    it has to be the other way around.
    why do you say you don't have enough blowdown?
  9. #36444
    Aprilia RS125
    Barcelona
    Merci philou, I will not touch C then, and will work on B as much as I can. I need the blowdown for matching the transfer sta increase. I did some calculations with Janbros spreadsheet and that was output.
  10. #36445
    sweden
    Quote Originally Posted by Javier Ruda View Post
    Merci philou!
    You want to have as much area as possible. If the rings are to stay in the same location, naturally there is a potential benefit from widening the c an b port respectively.
  11. #36446
    1988 cagiva freccia
    france
    to choose in my opinion, it is better to work on the efficiency of scavening even if it means losing a bit of surface.
    enlarge the C even more, will decrease its effectiveness
  12. #36447
    19th June 2011 - 00:29
    the greater the angle of a port, the smaller it's effective flow area.
    so widening the C-port (for example 4mm) by the same amount as widening the sum of the B-ports (for example eacht B-port 2mm) generates less extra TA than widening the B's,
    and keep an eye an the angle of the scavenging column while changing the ports so that you do not end up with a crzay angle.
    and don't mkae the angle of the A's to big, as the higher if flow's , the easier it can flow straight out the exhaust.
  13. #36448
    sweden
    Obviously this is the case, but it didnt seem like he was about to change the ring-pegs locations.
  14. #36449
    4th May 2018 - 20:26
    Kreidler 1976 RS
    Netherlands
    I believe some numbers in your calculation are not right.
    Total Port Transfer area sum = 834.91 (not 940.14).
    Eff. dia area 852.13 = 32.94 (not 34.85).
    Eff. dia area 1019 = 36.02 (not 37.78).
    Eff. dia area 132.62 = 12.99 (not 17.16).
    In that case results as 10.500 rpm also can't be right, or am I wrong?
  15. #36450
    1988 cagiva freccia
    france
    unfortunately when there is an image, people don't read the text.
    it is a file found on the internet. I insist on checking on a real cylinder that the data is correct.
    http://adardaine.free.fr/file/Aprilia_RS125.zip
