Page 2436 of 2774 FirstFirst ... 1436193623362386242624342435243624372438244624862536 ... LastLast
Results 36,526 to 36,540 of 41606
  1. #36526
    Niels, maybe another risk of unit crankcase chamber, could be detonation in overcharged one cylinder, at certain different condition.
    For NS 500 3V engine, because of the higher temperature, center lower cylinder compression was reduced in comparison to vertical side cylinders.
    Just remember 1991 Hans Becker modified TZ 250 DP4 engine with Hans Hummel big bore cylinders. Huge over-square 67,5 mm bore and std 50,7 mm stroke. 363 cc -91,2 hp at 10668 rpm, 20 hp over std 250 cc
    Later 54.5 mm stroke crank was used with slightly smaller pistons, 375 cc.
    Big surprise that this kit still available
    http://www.geckomotorcycles.co.uk/ma...-bore-kit.html
  2. #36527
    Reminds me of a Martin Jetpack V4 crankshaft
  3. #36528
    oddly i cant remember posting this stuff at all wtf
    https://www.kiwibiker.co.nz/forums/s...post1131038334
    No but on the link above the cylinders in the background of the link above look to be CP industries liger
    Attachment 329705
    http://www.cpindinc.com/pub/view_pro...=3101-9779-144
    ie same crowd that does the big bore banshees as well as CR500's
    Also the cases apear to have a awesome finish esp the one in the background
    looks to me like diecast.
    Attachment 329715
    I also note the piston ring crase seal
    Attachment 329706
    Here is the staff for ifitech
    http://iffitech.com/#staff-module
    They even have one of charlies angels.
    hes the guy that did this, it looks as if its been rebranded.
    http://www.stuff.co.nz/motoring/5614635
    http://iffitech.com/wp-content/uploa...Lawson-Web.pdf
    Maybe rob should call in and visit them for a look.
    Here is a Konig cranks
ID:	350569Click image for larger version.
Name:	10 September 2011.jpg
    as well as the modern better made ones
ID:	350565Click image for larger version.
ID:	350566Click image for larger version.
  4. #36529
    8th November 2015 - 17:28
    1991 MZ 301
    Denmark
    It has been argued that having a two cylinder boxer two stroke will beunstable in amount of air fuel mixture distribution from an undivided crankchamber.
    The Koenig won a lot of races ,was basiclly two independent air/fuel wise boxers with two cylinders each served from an undivided crank case.
    Is that fact or fiction?
    A picture of the rotary valve face will b very nice if someone has one.Please?
    I got a monster McCullough 4 cylinder two stroke drone engine from our Navy once and I seem to remember that it was two crankchambers feed from reed valves from one common carb?
  5. #36530
    13th December 2018 - 18:06
    youtube andreas länström
    sweden
    Well it wasn't so informative.
  6. #36531
    Hi here. its shut though LOL
    here are some others but the one Andreas has found is the best
ID:	350592Click image for larger version.
ID:	350571Click image for larger version.
ID:	350574Click image for larger version.
ID:	350575Click image for larger version.
  7. #36532
    Another unit crank chamber type, copy of Konig, that was made in small series. Both with the same 54 mm stroke, but 45,3 mm bore for 348 cc. Runs on Methanol
    Veterok-70 348 cc 70 hp at 9000 rpm
    Veterok-100 496 cc 100 hp at 9000 rpm
  8. #36533
    i cant recall who did this one.
    Frits will though. it was out of some sidecar
    okay
    here are some pictures of the Stredor, a work of art made by Egbert STREuer and Rinus DORgelo. This machine was on display at the Speedshow in Cafe Hofsteenge in Grolloo
    https://www.flickr.com/photos/teamhe...57594456814612
ID:	350584Click image for larger version.
ID:	350587Click image for larger version.
    plus some others one reed aparently based on the yz250
    no idea of the internal layout
    The other I would like to replicate (as for no other reason it looks frigging cool)
    I can't remember what it was called but i think it was three leter E..
  9. #36534
    1991 MZ 301
    Denmark
    here are some others but the one Adereas has found is the best
    Thank You for pictures.
    All are common chamber for two opposed boxer cylinders (Me think)
    Seem to remember that exhaust pipes was not very prominent and certainely not as big as present ones.
  10. #36535
    1991 MZ 301
    Denmark
    Thank You for picture.Do You have a picture showing Exhaust arrangement?
    It is I think again common crankchamber Boxer
  11. #36536
    1991 MZ 301
    Denmark
    okay
    Thank You for lovely pictures of mechanical nigthmares.
    Most certainely divided/rotary sealed individual crankchambers and intended for 4 full blown resonance exhaust pipes.
  12. #36537
    1991 MZ 301
    Denmark
    Boxers can have common or sealed individual crankcase chambers.
    For direct exhaust they can be common
    http://miniairboatassoc.com/forum/sh...1-Drone-Engine
    The disappointment Andreas swedish friend had (letter 36519)was most likely trying undivided crankchambers with modern resonnance exhausts.
    Modern military drone two stroke boxers do not have tuned exhausts .
  13. #36538
    This is the only other picture that I have of this engine.
    Add other outboard racing engine picture from sixties. This is the development of soviet 1962 single-cylinder racing engine "Hurricane-175", developed on the basis of the Zimmermann disc intake engine design, a sample of which was handed over to soviet racers by its designer Daniel Zimmerman.
    175 cc 60,5 x 60,5 mm bore/stroke
    27 hp on pump fuel
    Carb 30mm
    Ex 189
    Intake 198 opened 52 after BDC
    Trans two mains-132 C-129
    Exhaust stainless 0,5 mm
ID:	350593   Click image for larger version.
Name:	Daniel Zimmerman copy 175 cc.jpg
  14. #36539
    1991 MZ 301
    Denmark
    27 hp on pump fuel
    Carb 30mm
    Ex 189
    Lovely and shows that Boxer exhaust pipes were not tuned by modern standard.
    Do You know power and rpm of Boxer?
  15. #36540
    Boxers Veterok 70 and Veterok 100
    Guseppe Rossi made a very nice engines, its like mix of Konig boxers with Jan's type cylinders and reed valve. Looks like was tested two types for 500 cc, with pairing crank chamber and separated for all four. Paired crank chambers version crankshaft with additional outside bearing to prevent deformation. They still produce 350 cc boxer with unit crank chamber, but on 250 cc base, so its over square bore/stroke like RD 350.
    Last year they won WC F 500 with Erko Abrams and F 125 with Sanna Aslav Kaasik.
Name:	500cc separated.jpg
ID:	350596   Click image for larger version.
Name:	500cc paired crank chamber.jpg
ID:	350597   Click image for larger version.
Name:	500 cc paired.jpg
ID:	350598   Click image for larger version.
ID:	350599   Click image for larger version.
ID:	350600   Click image for larger version.
There are currently 58 users browsing this thread. (0 members and 58 guests)
