Page 2437 of 2776 FirstFirst ... 1437193723372387242724352436243724382439244724872537 ... LastLast
Results 36,541 to 36,555 of 41632
  1. #36541
    6th February 2012 - 08:54
    1988 cagiva freccia
    france
    The plates in the crankcase are back in fashion.
    crankshaft rotates in the normal direction
ID:	350602Click image for larger version.
ID:	350603Click image for larger version.
ID:	350604Click image for larger version.
  2. #36542
    14th February 2018 - 11:53
    KTM
    NORWAY
    500 2 stroke 1990s
    Always thought a 500VTwin would make a cracking roadbike in the 90s. . . . If only someone made one. . . .
    https://en.wikipedia.org/wiki/Bimota_V_Due
  3. #36543
    Boxers Veterok 70 and Veterok 100
    348 cc 70 hp at 9000 rpm
    496 cc 100 hp at 9000 rpm
    Guseppe Rossi made a very nice engines, its like mix of Konig boxers with Jan's type cylinders and reed valve. Looks like was tested two types for 500 cc, with pairing crank chamber and separated for all four. Paired crank chambers version crankshaft with additional outside bearing to prevent deformation. They still produce 350 cc boxer with unit crank chamber, but on 250 cc base, so its over square bore/stroke like RD 350.
    Last year they won WC F 500 with Erko Abrams and F 125 with Sanna Aslav Kaasik.
    JPbiplane wasi nterested in making drones esp boxer ones and posted some stuff ages ago
    Any idea what engine is it and specs ~1940 production, used by German military.
    Scavenging through piston
    Attachment 346564
    Attachment 346565
    Attachment 346566
    Like Niels wrote, it seems to be a boxer with Schliha (spelling!) scavenging through the piston. And the shielded spark plug caps suggest aviation use.
    I wonder about the drone application though. Drones were mainly used for target shooting practice, but back then the German Wehrmacht and Luftwaffe had no shortage of real targets.
    Attachment 346578 Attachment 346577
  4. #36544
    2nd May 2020 - 21:05
    Aprilia RS125
    Barcelona
    Rotax 122 transfer roof angles
    You could drop the cylinder to get enough material above the A port for more axial angle , but then all the ports BDC edges will be low - and alot of extra grinding needed to restore the other ports.
    Better to epoxy the A roof with increasing thickness of fill as it goes around the outer radius - this will keep the timing as needed but give you a proven axial scavenging pattern.
    You dont need to go to Italy to see the Leaning Tower , we can all have one in our workshop.
    Hello wobbly, finally I found some time and disassembled the cylinder from the engine. I measured roof angles using soldering wire, trying to follow the flow direction. Both ports are 17.1º.
    Does anybody knows a suitable epoxy for A-port available in Europe?
  5. #36545
    1988 cagiva freccia
    france
    almost any epoxy is suitable.
    easily available in Europe. Loctite epoxymatic 3455
  6. #36546
    25th January 2019 - 01:33
    Southwest of Germany
    Quote Originally Posted by Javier Ruda View Post
    JB Weld, available at Ebay
  7. #36547
    1988 cagiva freccia
    france
    jbweld also works. have seen it often, because many photos of port transfers with epoxy on the internet are made by Americans.
    jbweld and available in any hardware store at home. the product is nothing special.
    cylinder is made with quiksteel.
    knows the preparation with the degreasing that makes the outfit
  8. #36548
    Other Loctite hi-temp https://www.ebay.co.uk/itm/194709724...UAAOSwGrhh1rLF
    And less viscosity for AL repair https://www.ebay.co.uk/itm/113124922...sAAOSwvApaQMyN
    I tried both.
    Yes Husa, remember this very interesting topic from Oddball pages two years ago. Maybe in theme, add picture from last weekend trip to Trakai city and was very surprised to "meet" this monument. Firefighter engine.
    Third picture again boxer for rc models.
ID:	350616   Click image for larger version.
Name:	Trakai 2022 01.jpg
ID:	350617   Click image for larger version.
Name:	RC boxer.jpg
  9. #36549
    Aprilia RS125
    Barcelona
    Thank you all for the answers
    What a nice forum this is!
    By the way, following my new hobby of bending soldering wire, I measured the transfer roof ports of Italkit cylinder for Rotax 122.
    They are complete flat!
    I guess this is a compromise with the overbore cylinder that they also sell, so that the transfer timings are not lowered on the overbore.
  10. #36550
    The plates in the crankcase are back in fashion. crankshaft rotates in the normal direction
    I would call it a piston stuffer rather than a crankcase plate. It's usually done in order to reduce the crankcase volume, but it can do some good just the same: it can guide the inlet flow to the transfers, and it creates some pumping of fresh mixture inside the piston, to the delight of the small end bearing and the piston crown temperature.
  11. #36551
    I tried both.
    We meet some guys in Siberia with a jet boat. An aluminium dingy with twin two cylinder twostroke engines, looked similar. We told them through our interpreter the jet boat was a NZ invention. No they insisted, Russian invention. The jet units looked very much like a copy of a Hamilton single stage jet.
    All they wanted to do was have a drink with us, Vodka.
    Haha, those were the days.
  12. #36552
    The Pulse 500Gp project wasnt a lease deal , it was a completely new bike built by the Roberts Team in England - sponsored by BSL and Hacket the bungy man.
    The SwissAuto engine had reworked all but copies of factory Honda RS125 cylinders and pipes , it made around 180 Hp , making it as good as anything on track at the time.
    Its crankshaft was hugely expensive to make in special materials to prevent failure of the integral pins conected to the common center wheel, and these proved
    reliable if religeously lifed and swaped out.
    But the engine was very compact and made for very good chassis dynamics.
    The question about a V vs a parallel twin has been very well researched by many , and the consensus now appears to fall in favour of the parallel version.
    This gives a completely symetric inlet and exhaust layout , whereas the V is always compromised in this regard - when packaged for racebike use.
    The KTM 250 GP engine was the best proponent of this approach , with 90* firing and a balance shaft.
    Dr Jeff is drawing a 500 version of this with the cylinders turned around and a balance shaft driving twin RV across the front , with gibs etc thus using all available current sota tech.
  13. #36553
    18th March 2004 - 17:38
    1971 suzuki T350R
    the best island
    Hoping
    This makes me hope some one can post some cutaway drawings or disassembly photos from a KTM 250 GP engine or Dr Jeff could show some basic pictures of Dr Jeff,s project.
    . . . That shit's Nasty.
  14. #36554
    ktm photos in an album
    https://www.kiwibiker.co.nz/forums/a...p?albumid=4857
    from what a few have said it was basically a parallel twin with a copy of works NSR cylinders and pipes
    it did have a fuel injector to prevent seizing on overrun
  15. #36555
    1988 cagiva freccia
    france
    on the Swissauto where was the balance shaft located ?
There are currently 33 users browsing this thread. (1 members and 32 guests)
  1. crbbt
