Page 2439 of 2774 FirstFirst ... 1439193923392389242924372438243924402441244924892539 ... LastLast
Results 36,571 to 36,585 of 41608
  1. #36571
    20th June 2020 - 07:10
    ETEC 800
    Minnesota, USA
    I have to ask, and maybe I missed something, what is Dr. Jeff’s engine going in? The LSR bike? Is he casting his own cylinders this round?
    Very impressive work to all parties involved.
  2. #36572
    Im trying to get my hands on a bare Pulse 500GP chassis I know is here in NZ , but Jeff has another couple of ideas.
  3. #36573
    is it the one on ebay that was presented as a Yamaha TZ?
    externally it looks like a 4DP of TZ
    Attachment 350633
    that expalins why it looks so odd in the PV
    i know at least one of the later Cagivas were Bridged ex port like a Honda so it makes sense that there would be Yamaha ones they copied off?
    it was years ago i thought that was the one that was propertied to Be Kit or NSR but so many pictures do many years by the code it looks like it was off EBay
    I think from the store that sells a lot of RS and TZ stuff whose name i cant recall.
    edit
    oh i just seen wobs post i have photos all mixed up.
    Husa , the left sectioned cylinder is an RS but im sure no one can decipher the codes of factory kit units.
    The right pic is a 4DP TZ
  4. #36574
    21st March 2014 - 22:00
    Hanau, Germany
    Great story and what a wind blew you into Siberia!!!
    I found some other pictures of this engine. Again this 72 mm piston that was used everywhere in Russian engines, motorcycle, tractor starter engines, stationary engines, but actually base is from old DKW engine.
    One amazing thing that could be usable for racing from all this stuff, is tractor starter engine dry clutch plates, material is very similar to what was used for racing dry clutches.
    Husa, philou, yes this is TZ 250 cylinder. In Husa second picture is actually 1991 3YL cylinder with usual A, B main transfers, but C was divided in two.
    DP4 cylinder used from 1992 and B was divided in two, but C narrower and one. Other identification code Y-1 and Y-2 shows port dimensions, Y-2 more tuned with wider transfers (add picture of two for comparison).
    From my knowledge the Y-1 stands for "cylinder number 1 (left hand side)" and Y-2 stands for "cylinder number 2 (right hand side)" for the Yamaha V engines, the suffix behind 4DP e.g. 01 stands for the different versions / port setups during the whole years the 4DP / 4TW was sold...
  5. #36575
    6th February 2012 - 08:54
    1988 cagiva freccia
    france
    does anyone have any pictures of the inside of the flowbench superflow SF60 or even better, a copy of the manual?
    impossible to find it.
  6. #36576
    8th December 2014 - 14:39
    1980 Suzuki Gs1100E
    SWPA
    SuperFlow Manual
    I have a copy of the SF110/120 manual, if that will help.
  7. #36577
    23rd July 2017 - 21:59
    n/a
    canada
    I'm sure I have a hard copy of the manual at home. I will check when I return later.
  8. #36578
    n/a
    canada
    Philou give me your e-mail adress .
  9. #36579
    Interesting, because I have three DP4 cylinders with same suffix 00, but two cylinders marked Y-1 and one, with wider transfers, marked Y-2.
    Add picture with temperature distribution from plug.
Name:	Plug temperature.jpg
  10. #36580
    n/a
    canada
    Quote Originally Posted by porttiming124 View Post
    I sent you a scan of the manual.
    Hope it can help you.
    Patrice.
  11. #36581
    1988 cagiva freccia
    france
    yes well received. thanks again.
    husa a photo for your album
  12. #36582
    Beautiful a 750 one is it?
    I think there is a NR album? no there wasnt' but there is now.
    i have some stuff to add to it later
    I have some stuff on the original and the 750 Malc Campbell rode in one of the Swan series about 89?
    edit 87
    plus on the oval piston twin turbo 250 they made up for Freddy
    if i still smoked it would make a neat ashtray
  13. #36583
    3rd February 2004 - 08:11
    Wallaceville, Upper hutt
    Thats a long crankpin. What went in between? Any pics of the crankshaft?
    Edit: belay that, found a pic of the crankshaft - a Main bearing goes in there
    (PostalDave on ADVrider)
  14. #36584
    or later
ID:	350674 Click image for larger version.
ID:	350675 Click image for larger version.
ID:	350676 Click image for larger version.
    clik on them three times
    https://magazine.cycleworld.com/arti.../inside-the-nr
  15. #36585
    FOS software download link, valid until February 17, 2022
    https://we.tl/t-A61fCirINx
    I wrote these programs in the course of over five decades for my own personal use and I never bothered to make them user-friendly, so you may have to do some experimenting on your own, as I will not have time to answer questions.
    The lot runs on MS-DOS 6.2 or Windows 98 (I recommend Win98SE) so either dig up an old computer or use an emulator. On my Win10-laptop I use VMWare Player.
    I advise against DOSBox 0.74 because that is essentially a stripped-down version of MS-DOS 5; it will run some of the programs, but not all of them.
