Page 2440 of 2773 FirstFirst ... 1440194023402390243024382439244024412442245024902540 ... LastLast
Results 36,586 to 36,600 of 41594
  1. #36586
    19th June 2011 - 00:29
    thank you Frits
  2. #36587
    23rd July 2017 - 21:59
    n/a
    canada
    Thank you Frits
  3. #36588
    2nd May 2020 - 21:05
    Aprilia RS125
    Barcelona
    Downloaded, thank you Frits!
  4. #36589
    12th October 2016 - 01:24
    1964 Vespa GS
    San Francisco
    huge thanks Frits
    Patrick Owens
    www.OopsClunkThud.com
  5. #36590
    Aprilia RS125
    Barcelona
    The lot runs on MS-DOS 6.2 or Windows 98 (I recommend Win98SE)
    Hello Frits, the View3d in MS-DOS is amazing, hats off!!!
  6. #36591
    Quote Originally Posted by Javier Ruda View Post
    Thank you Javier. I wrote the first version of View3D about ten years before today's standard, SolidWorks, was introduced .
  7. #36592
    Making noise on the dyno.
  8. #36593
    I'm just kinda getting the feeling a bidlot or athena barrel and some time on a dynojet would be a good starting point. From there he has a test engine he could put on his dyno and say 16hp equals. . . Adjust. Adjust. 16hp.
    Right.
  9. #36594
    Right.
    Didn't he initially have a Dyno built from an Electric motor fwith the wheel running directly of the stator?
    edit today 8.25 17/2./22
    Thanks!
    All I did was tear out the windigs.
    Attachment 316742
    Attachment 316743
    Attachment 316744
    2.17kgm2, the plan is to make a detachable flywheel for the axle, bumping it up to around 6-7kgm2 when needed.
    I share your concern. The bearings should be fine up to 4500rpm, more with limited lifespan(skf 6316,6319), the rotor at least 3000rpm continuous cause thats what the motor was spinning.
    70mph+ with my scooter on it, no vibration or other scary stuff.
    It'll be fine!(famous last words...)
    80mm shaft.
    Same Sketchy_Racer as on the Simple Dyno forum?
  10. #36595
    Right.
    Biggest problem he has is his stubborness och not listening.
    I have mentioned early in dyno build to put loadcell on the retarder.
    But,, he seems finally to have figured that out by him self now.
    And if doing that, and later setting up the loadcell as per instructions in his manual for yourdyno is a no brainer, a static pull will show correct power.
    A sweep through the rpm band needs him to know the inertia on his whole dyno system and place that data into program.
  11. #36596
    n/a
    canada
    I wonder if it's his goal to stretch the time rather than go straight to the point.
  12. #36597
    20th June 2020 - 07:10
    ETEC 800
    Minnesota, USA
    It is his income so I would say dangling the carrot is definitely in the cards, but at the end of the day he is still developing things that nobody else is.
  13. #36598
    Dyno Ramble
    The problem with the DynoJet baseline is that you are up against the ( in ) famous fudge factor built into the software.
    There have been various attempts at calculating this , but its still just an estimate.
    Doing proper calibration with a torque arm and known mass for the load cell is inherently super accurate , as is a stringline/dropping weight test with subsequent friction rundown, accurate for any inertia system.
    Seems to me there is a huge mismatch between the retarders " power " capability and the engine , plus not having ( or not using ) a baseline PID loop setup for the power supply , means once again our friend is off on another tangent
    that was never going to " work ".
    That retarders inherent inertia seems well excessive to give a realistic run time for even the most powerfull 50cc engine , but having said that , gearing correctly can solve that issue.
    I worked on the setup of a very expensive SuperFlow retarder control system for an Eddy Current dyno and it was a necessary "workaround " to use large switched resistor banks on the power supply, as it was technically impossible
    to accurately control the dyno at low power numbers with sufficient resolution when testing a single cylinder mule engine - and then also using the same system to control the power produced by the completed test engine.
    ie a delta factor of 4
    As always the Devil is in the detail.
  14. #36599
    FOS software download link, valid until February 17, 2022
    https://we.tl/t-A61fCirINx
    I wrote these programs...
    Frits, thank you for these gems.
    I suspect your memory of their details might be hazy, but I'm going to ask anyway: In the squish program, what is the "number of crankshaft degrees"? Is it the exhaust open duration, or the EO point?
    Or something else?
  15. #36600
    Reminds me very much of New Zealand Bucket racers. Great ideas, build a dyno in the garage to test things, clever engineering solutions and lots of enthusiasm. Many world beating ideas tried but not every idea worked out. I like watching him work.
