Page 2446 of 2776 FirstFirst ... 1446194623462396243624442445244624472448245624962546 ... LastLast
Results 36,676 to 36,690 of 41630
  1. #36676
    The A port front wall is nowhere near angled back enough - it will short circuit badly with a good pipe.
    Also no hook on the B port rear wall - doesn't seem very clever at all to me.
  2. #36677
    24th January 2014 - 08:12
    1988, Yamaha RD350 YPVS
    Has anyone ever measured the pressure drop over the water circuit of a 125cc race engine? And also water flow would be interesting.
    Regards Tim
  3. #36678
    6th February 2012 - 08:54
    1988 cagiva freccia
    france
    it was indicated 50 liters per minute for the rsa.
    taking 1 litre/minute per cv seems relevant
    the improvement in performance and adjustments allowed by the cooling, must compensate for the losses caused by the turbine of the water pump.
    size the impeller and volute and a job.
  4. #36679
    it was indicated 50 liters per minute for the rsa.... Taking 1 litre/minute per cv seems relevant.
    I seem to remember it was 60 liters per minute for the RSA. 1 liter per minute per crankshaft hp is a good rule of thumb.
  5. #36680
    1988 cagiva freccia
    france
    following the ignition on ignition SEM rotax 123.
    the problem is that there are 2 magnets side by side passing in front of the internal sensor.
    with the oscilloscope, have noted the 2 top.
    ignitech sent me a specific configuration file.
    the point of advance becomes completely crazy from 4000 revolutions.
    with the oscilloscope, have noted that there are 2 sparks produced by the 2 magnets
  6. #36681
    9th December 2013 - 11:35
    1975 Kawasaki H2
    Wisconsin, USA
    What engine type will be donor for cylinders,pistons and conrods?
    850 Rotax Etec piston/small end assembly. I intend on making my own cylinders and rods.
    Paul Olesen
  7. #36682
    Quote Originally Posted by PVO View Post
    May i ask why your own rods?
  8. #36683
    8th November 2015 - 17:28
    1991 MZ 301
    Denmark
    Very,very interesting that 850 Etec thing
    What advantage do You expect going from stock inline to own V2?
    Do You have acces to parts for rough measurements or photos?
  9. #36684
    2nd May 2020 - 21:05
    Aprilia RS125
    Barcelona
    Hello wobbly, on the Rotax 122 I am widening the b-port to the rear. How should the b-port hook be like? Is it for no interfering c-port flow?
  10. #36685
    The B port hooks should intersect the centerline between 1/3 and 1/2 way from the boost port face to the bore center.
    With a radius in the corner around 1/2 the depth of the hook.
    Depends on how the other ports are arranged.
    If you take a cylinder with a hook and run a stream down the duct by holding it upside down under a water tap , you will see the exiting flow is rotated axially , this clears exhaust residuals
    from a large area in front of the boost port at BDC.
    The C port flow is angled steeply and is attached to the rear wall , thus its not simply a matter of the B port flow being directed away from this exiting column.
  11. #36686
    Aprilia RS125
    Barcelona
    Thank you wobbly! Very clear, I’ll do that hook. 👍
  12. #36687
    1988 cagiva freccia
    france
    piston with the ring lug at the rear.
    with the original piston, you will very quickly be limited
  13. #36688
    Aprilia RS125
    Barcelona
    Merci philou, I remember that. The issue is that I have an oversize piston (54.25 mm) and there is no 1-ring version available.
    But I already bought a standard size 2nd hand cylinder, so next time it will be 1-ring type.
  14. #36689
    1988 cagiva freccia
    france
    position of the ring pin in relation to the transfert port
  15. #36690
    Team ESE exploring the possibility of fitting a Suzuki GP125 rotary valve assembly to a Suzuki RG50.
    Also in the works is a small turbocharger with a much lighter bespoke 6061 aluminum exhaust turbine housing for turbocharging a 70cc two stroke. Aluminum should be Ok for the turbine housing as the exhaust gas is much cooler on a two stroke than a four stroke. We also want to make bespoke turbine housings so we can get the A/R ratio more suited to the capacity of the engine.
    A rotary valve converted RG50 with an over bored turbocharged 70cc water cooled cylinder. With the turbo we plan on a draw through carb, but I am also tempted to fuel inject it directly into the turbo intake or maybe just after the turbo on the discharge side.
Name:	RG50 Rotary Valve.jpg
