Page 2447 of 2774 FirstFirst ... 1447194723472397243724452446244724482449245724972547 ... LastLast
Results 36,691 to 36,705 of 41608
  1. #36691
    Nice collection of potential projects there Rob.
    Some (long) while ago I was looking at spare RG cases and thinking "hmm. V-Twin"
    Never happen now but,
  2. #36692
    Can you guys still find suitable 100 cc 2 stroke bikes to make buckets from? Any over here are rare and sort of valued and held onto by collector types. Maybe you can get them from SE Asian countries I guess.
    I often think that the bucket class could include 125 TAG kart engines. Using their clutch driving thru a jackshaft to attain the reduction required, meaning a single gear ratio. Could have them standard as per their karting homologation rules or also have a modified class as well.
    Anyways, just a thought from someone 5000 km away.
  3. #36693
    As an increasing old man exhausted from riding my Beta today I have to say racing looks increasing expensive and unappealing.
    I bought a $1300 RS125 with 2 years supply of tyres, sold the engine for $600, instant $500 chassis. Circa 1990.
    But I don't know what I'd do if I re entered as an old man trying to emulate my occasionally dominant position which is very unlikely given my trail ride skills I showed today. My 1978 MB100 was, ahh fuk it. There's probably a 150 that could. .
    Ok no fuk it I'd still wanker it. I just need to be 20 years younger.
  4. #36694
    9th December 2013 - 11:35
    1975 Kawasaki H2
    Wisconsin, USA
    May i ask why your own rods?
    Certainly, the main reason is because most snowmobile manufacturers don’t sell the rods individually or the rods they offer are too short. The 850 Etec produced by Rotax, for example, has a rod that would probably work well, however Rotax only sells complete crank assemblies. This is most likely due to the fact the rod is a two piece design that uses a fracturing process to split it. Couple this with the split cage needle bearing and improper assembly and you have a disaster on your hands if it isn't done right.
    The other obvious rod options are from Polaris and Arctic Cat. Bore and stroke on these engines are 85mm x 74mm and 85mm x 70mm respectively. My belief is these rods will be too short. I'm still hunting for donor rods but haven't found anything yet and will make one if I have to. I could also concede to having an over square engine but I really don't want to do that.
    Paul Olesen
  5. #36695
    1975 Kawasaki H2
    Wisconsin, USA
    Very,very interesting that 850 Etec thing
    What advantage do You expect going from stock inline to own V2?
    Do You have acces to parts for rough measurements or photos?
    There are a few big advantages in my application: near perfect primary engine balance, a much narrower package, and an expectation that I can make the V2 lighter than a parallel twin.
    I have familiarity and friends with all three major brands. The necessary donor parts will be procured as needed.
    Paul Olesen
  6. #36696
    8th November 2015 - 17:28
    1991 MZ 301
    Denmark
    Quote Originally Posted by PVO View Post
    I did a lot of crankshaft speculation for a low mass aircraft engine and a pressed up crank is not low mass.
    [URL="https://www.homebuiltairplanes.com/forums/threads/side-valved-two-strokes-for-angels.32119/"]
    If You are interested and give me some dimensions I will love to try some alternatives for mass calculation and I know how to balance a V2.
  7. #36697
    20th June 2020 - 07:10
    ETEC 800
    Minnesota, USA
    PVO it seems rods on large bore snowmobile applications are always too short. I think it is because the deck height has constraints to fit in todays tightly packaged chassis.
    I have not been following your planning closely, are you wishing to sleeve down the cylinders and increase stroke length to square? I could be wrong, but my gut instinct would tell me In order to achieve a 2:1 r/s ratio with the longer stroke the case volume would rise dramatically, unless you are planning to add to the topside of the cylinder which ends up being a lot of work.
    How long are the factory 850 rods?
  8. #36698
    Next step. Filling the area that the rotary valve is going to go with Knead It polymer repair compound.
    Will fill the rest of the case then mill a pocket for the rotary valve back plate.
  9. #36699
    Quote " Aluminum should be Ok for the turbine housing as the exhaust gas is much cooler on a two stroke than a four stroke " .
    Really TeeZee - I have done two project 2Ts that regularly saw 1280*F , and most all see 1200 all day ?
  10. #36700
    Interested in what your ignition and power source solution will be Rob.
  11. #36701
    Hot rods and others sell the bits you need
    Making rods as small runs is quite expensive.
    http://www.transcanimports.com/downl...ing%20Rods.pdf
    https://www.pro-x.com/prox-connectin...ensions-brand/
    https://www.wandamotor.com/connectin...2253_2540.html
    https://www.kimpex.com/en-ca/product...onnecting-rods
    https://www.mitaka.co.uk/MDP.htm
    http://catalog.vesrah.co.jp/list/product_parts.asp
    http://www.samarin.nl/webshop/index....ewCat&catId=32
    https://www.tkrj.co.jp/product/m-con...g-rod-kit.html
    https://www.twsgb.co.uk/hot-rods-con-rods-37-c.asp
    http://http://www.samarin.net/?productos
    http://www.pvlsverige.se/vrm/index/index22.html
    Polaris 700 and 900
    C-C 152.1 mm
    SE od 27mm
    BE od 40mm
    SE Width 20mm
    BE Width 20mm
    SE bearing 22 x 27 x 25 mm
  12. #36702
    My guess is that 1280*F was seen in the header near the cylinder. I was planning on following these layouts where the Turbo is attached at the stinger. If it is still to hot there I will attach the Turbo to the mid section, where I expect the exhaust gas is at its coolest.
ID:	350778Click image for larger version.
Name:	Am6 turbo 50.jpg
ID:	350779Click image for larger version.
  13. #36703
    At this point I am planning on a DC-CDI Ignitec and total loss 18V 5A/hr electric drill battery. I hate total loss because it so often catches you out with a flat battery but I can't really see what else is possible or practical. Maybe super magnets around the clutch hub. Pole piece with coil fastened outside with the poles reaching through slots in the clutch cover. I think I will start with total loss before this becomes a rainbow bike. You know, the pot of gold at the end of the rainbow. You just never seem to get there.
  14. #36704
    I once seen a mini ignition mag like a KTM 50 rotor mounted on the inside right next to the carb.
    it scared me. But your pilot might be braver than me.
Name:	Stator-ROTOR-KTM50-For-KTM-50-SX-50cc-Pro-Senior-Junior-SR-JR-SX50-KTM50-2001.jpg
    I have seen a few with triggers there
    or Points
    Not sure what Jan did with the Garelli twin Total loss?
    THe Exactweld 4 disc tandem Twin no idea how they did the ignition?
  15. #36705
    Yep, total loss systems for his Jamathi, Piovaticci, Bultaco, Minarelli and Garelli creations. Most of them carried the battery in the fuel tank.
    The Exactweld 4 disc tandem Twin no idea how they did the ignition?
    Total loss as well.
Name:	Exactweld 250-001.jpg
