Page 2455 of 2773 FirstFirst ... 1455195523552405244524532454245524562457246525052555 ... LastLast
Results 36,811 to 36,825 of 41588
  1. #36811
    23rd July 2017 - 21:59
    n/a
    canada
    With a VeeForce your idea looks perfect , if you wanted to try biasing the flow you could make the top hollowed out area deeper and or even higher.
    Unless you can get varying petal thickness for this model its a bit harder to change the flow regime thru the tips.
    We use different thickness petals and much different petal backups top and bottom.
    After literally hundreds of dyno runs this was worth average 1.5 Hp in 50 over stock which was a pretty trick setup to start with.
    ok thank you
  2. #36812
Name:	239 RV .jpeg
ID:	350909I agree with you! at 239 * it looks like this when I tried.
    Yep, that is the RV blade shape I would expect to see at 239 deg inlet port duration.
    Our Suzuki ones were about 210 deg duration.
  3. #36813
    Easy for you TeeZee , put in 140/90 into EngMod and work back till you loose power.
    140/85 turns out to be the best. I tried all sorts of combinations from 155 to 130 combined with 65 to 95. 140/85 is it.
  4. #36814
    Im glad you came up with what I would have thought was perfectly reasonable.
    Does that give you a Inlet STA that matches the Blowdown and Transfers.
  5. #36815
    Yes .........
Name:	Rotary Valve RG50.jpg
  6. #36816
    It happens that if you make the disc straight on the opening side (if it is meant to be turned that way) it will be exactly 239 °. but as said, it may well be my mistake
Name:	Skärmavbild 2022-04-11 kl. 06.59.09.png
  7. #36817
    The black and white one might be an early Debri prototype?
ID:	350912Click image for larger version.
    No where as cool as the RSW shapes
    but i guess the RSA was ofsett.
  8. #36818
    Nothing to do with Derbi or Aprilia. It is the BBFT engine by Alfio Tosi.
  9. #36819
    Cheers ....
    it was saved under RSA with "moteur" in some froggy looking dialect.
    Any idea what language this is
    moteur%20rsa
    Google is a baren wasteland under Alfio Tosi?
    care to fill in the gaps
    Anyway here are some other pics of the more intersting discs
ID:	350918Name:  10357255_858059584223159_4478045915218867697_n.jpg
Size:  12.6 KBClick image for larger version.
ID:	350920Name:  10431342_1451431861784928_5372939619105475665_o.jpg
  10. #36820
    13th December 2018 - 18:06
    youtube andreas länström
    sweden
    What is the black magic involved in shaping the disc's edges. When it would be more precise and area-efficient to have them rounded as in the drawing?
Name:	Rotary valve.png
  11. #36821
    20th June 2020 - 07:10
    ETEC 800
    Minnesota, USA
    I have been advised that the rounded corners will “ flutter “ and dig into the rotary housing on the case. Not sure if that was good advice or not.
  12. #36822
    26th April 2013 - 21:55
    BMW R1200R 2009
    In what year was that, Frits ?
  13. #36823
    I spent months at ZipKart testing the new Rotax 256 for Hines 250 Superkart World Champ winning engine. With every disc shape known to man. Convex and concave radi on the closing edges , angled back , angled forward timing edges , everything.
    At the same timings of 140/88 nothing made any more power anywhere.
    The forward angle on the closing side was adopted as the outer leading edge gave support to the disc and reduced the bad wear occurring on the case face , due to the inlet column inertia pushing hard
    on the disc as it closed. Even with trick coatings applied this problem never really went away.
  14. #36824
    sweden
    No free lunch again
  15. #36825
    13th March 2015 - 07:20
    1987 SUZUKI 500RG
    France
    Rotary valve
    Hello,
    In order to avoid wear on the edge on the closing side of the crankcase, all our valves are designed with a "beak" on the outside diameter, which considerably improves the guiding of the valve when closing the hole.
    Still in the spirit of completely removing this commitment, we have:
    - Machined on both sides in contact with the valve, with APRILIA "style" grooves.
    - Has a chemical nickel coating deposited, with quenching.
    - Considerably lighten the hub and its nut, in steel.
    - Use much stiffer carbon valves.
    The problem is gone now.
Name:	Moyeux de valve.jpg
ID:	350930Click image for larger version.
Name:	vérification diagramme 142-86.jpg
ID:	350931Click image for larger version.
Name:	montage valves tr2012.jpg
ID:	350932Click image for larger version.
    Francis.
There are currently 133 users browsing this thread. (1 members and 132 guests)
  1. Viking
