Page 2456 of 2776 FirstFirst ... 1456195623562406244624542455245624572458246625062556 ... LastLast
Results 36,826 to 36,840 of 41630
  1. #36826
    Quote Originally Posted by fpayart View Post
    Hello,
    In order to avoid wear on the edge on the closing side of the crankcase, all our valves are designed with a "beak" on the outside diameter, which considerably improves the guiding of the valve when closing the hole.
    Still in the spirit of completely removing this commitment, we have:
    - Machined on both sides in contact with the valve, with APRILIA "style" grooves.
    - Has a chemical nickel coating deposited, with quenching.
    - Considerably lighten the hub and its nut, in steel.
    - Use much stiffer carbon valves.
    The problem is gone now.
    Francis.
    Thanks for the helpful info Francis
    I am working on a small 50cc, where I had the rotor cover cast, which was perhaps not so smart. Feels much easier to make disks for surface treatment (then you also get rid of the division between block halves). I bought materials for rotary valve a while ago, and then got the idea to make the cover in forged carbon fiber. So I bought material and we'll see how it goes.
  2. #36827
    13th March 2015 - 07:20
    1987 SUZUKI 500RG
    France
    Carbon valve
    Pay attention to the quality of the carbon fiber to manufacture the valve.
    This result is obtained by assembling several layers with very fine mesh Rowing.
    The final thickness is about 1mmClick image for larger version.
Name:	Détail fibre.jpg
  3. #36828
    Can it handle E85?
  4. #36829
    Thanks for Posting Francis, i love your work, long may it continue.
  5. #36830
    1987 SUZUKI 500RG
    France
    Can it handle E85?
    I have never tried but the resin used is epoxy ???
  6. #36831
    Knows very little about what is good but the one I bought is made of: 2 Layers of XPREG XC130 210g 1 Layer of XPREG XC130 450g
  7. #36832
    15th May 2017 - 14:26
    2002 Aprlia RS125
    Anyone got or know where a little Myford lathe is in NZ. Would like something for my son to learn on.
  8. #36833
    V force say their reeds will fail on E85.
    Thats why I use a steel disc valve. Would be nice to have a carbon disc that is ethanol compliant.
  9. #36834
    Myford might be a little expensive these days, a Chinese lathe might be a cheaper option to learn on.
  10. #36835
    Found this when I searched before ..
    ”we wouldn’t suggest Epoxy Resins for lining a fuel tank. In general, epoxies have good resistance to petrol and many of the chemicals and additives found within pump fuel however the ethanol in fuel is known to cause problems over time and so specialist tank lining resins (often novalac vinylester based) should be used instead. One such product is GTS 1750 which is sold by Caswell Europe.”
    https://www.masterbond.com/propertie...s-and-coatings
  11. #36836
Name:	RV Suzuki RG50.jpg
    Ok. Got the rotary valve Suzuki RG50 running tonight.
    Blue line is the original piston port/reed setup. Red line is the exact same cylinder on the rotary valve bottom end, no other changes to ignition or jetting at this point.
    I only managed one run before the ignition trigger fell off. Sort that tomorrow night.
Name:	Blue Original Red RV.jpg
    The RV seems to rev way past the old piston port setup. Looks like the RV setup needs different jetting and maybe timing compared to the old piston port/reed engine.
    Looking forward to doing some tuning tomorrow night. Very excited now that it actually runs.
  12. #36837
    Looking good Rob. Clearly jetting well off so excited to see what you end up with.
  13. #36838
    6th February 2012 - 08:54
    1988 cagiva freccia
    france
    Can it handle E85?
    vinylster resin for e85
  14. #36839
    As strong as epoxie?
  15. #36840
    I need some help with finding a High-Load & High-Rigidity 16x22x12 radial needle roller bearing cage assembly for the RG50.
    As I am looking to push piston speed and rpm up I am not expecting my standard crank to last very long.
    Most bearings are the old "W" cage design. I am looking for something better.
    Any pointers to a proven good quality 16x22x12 big end bearing would be very welcome. Something that the Free Tec 50 developers have found to be reliable at 16,000 rpm.
There are currently 93 users browsing this thread. (2 members and 91 guests)
  1. jonny quest
