Page 2463 of 2773 FirstFirst ... 1463196323632413245324612462246324642465247325132563 ... LastLast
Results 36,931 to 36,945 of 41592
  1. #36931
    Having an extended length of carb bell mouth hugely affects the intake tuned wave response. You are way better to have a simple airbox with a forward facing intake that has the enclosures flat face no less than 20mm
    from the carb bell end. This you can model in EngMod easily.
    I have tested the effects on Hines World Champ winning 250 Superkart , when the engine was on the right and thus the carbs all but touched the seats flat side .
    And at 20mm away it has no effect on the carbs fuel standoff and thus power , at full noise.
  2. #36932
    Could not help but not include such an option!
Name:	Skärmavbild 2022-05-05 kl. 17.16.46.png
ID:	351037   Click image for larger version.
Name:	Skärmavbild 2022-05-05 kl. 17.25.14.png
ID:	351036   test insug v2.pdf
  3. #36933
    Has to have some benefit if you put it in the kitty litter too. Bolted to sidecover holes could have crash resistance plus the inlet out of the dirt. .
  4. #36934
    3rd February 2004 - 08:11
    Wallaceville, Upper hutt
    The carb shield on Harry Klemms 350 Bighorn (R/V) racebike
Name:	38 carb.jpeg
    (PostalDave on ADVrider)
  5. #36935
    In EngMod you can vary the volume and the intake tube length/intrusion/size to explore Helmholtz effects.
  6. #36936
Name:	RG50 Piston.jpg
    After a lot of dyno time and a days abuse at Hampton Downs the piston looks remarkably good. None of the deto damage or seizure marks that I was expecting.
Name:	RG50 80% Ex Port.jpg
    At 80% bore width, the exhaust port looks Ok too.
Name:	RG50 Ring Ends Snagging.jpg
    A fly in the ointment looks to be that the ring ends are gouging the cylinder as the exhaust port top edge pushes them back into the grove.
    What I need is a single ring piston with the ring gap at 6 o clock. The piston I am using now has two rings with the gaps at 5 and 7 o clock.
Name:	RG50 Case Reed Valve.jpg
    When I got the rotary valve going I just plugged the carb inlet rubber and transferred the original cylinder complete over from the piston port case reed engine.
    Now in the interests of science I am going to remove the reed block and block up the inlet tract and inlet port with epoxy. It will be interesting to see what the extra case volume does.
  7. #36937
Name:	Screenshot (695).jpg
    20:1 compression ratio and supercharged, what could go wrong? nothing apparently. https://youtu.be/lyDOWiSprtE
  8. #36938
    6th October 2015 - 13:42
    2001 kx250
    USA
    eek C Port
    TZ, from the pictures posted, how is the Intake Side / C Port being feed? I’m sure to be missing something as it appears to only use the A/B transfers.
  9. #36939
    20th June 2020 - 07:10
    ETEC 800
    Minnesota, USA
    Tz, I am in the same boat as you. I use a 75% chordal exhaust port, and only have trauma on the rear wall at ring end gap at timing edge height. Oddly, I have found that switching to the cheaper cast version piston which also uses an L-ring, has almost entirely eliminated this issue.
  10. #36940
    Have a look at an 80s RM or PE engine, it will become clear.
  11. #36941
    2001 kx250
    USA
    F5, I’ve had the early RM’s & PE’s and fairly familiar with the Piston Port / Case Reed design, but I thought he was running a Rotary with Carb mounted at the Disc, is it a dual carb setup?
  12. #36942
    13th December 2018 - 18:06
    youtube andreas länström
    sweden
    80% exhaust width, it will come at a cost. I had it working with a L-ring ( if this, or ring material helped, not known). Just changing the ring gap location , I don't think will do much, furthermore it will present a big risk of ring/cylinder havoc, as the C port divider, I think, is too small to support the gap.
    The induction system on these suzukis I'm convinced is very good, the only drawback being that wonky C-port feed from the B-ducts. So if the rotary thing is permanent, then it would be a good idea to give it a proper C-duct.
  13. #36943
    Reread the very post you quoted for TZ350.
  14. #36944
    2001 kx250
    USA
    Thanks for clarifying as this answered my question.
  15. #36945
    Speaking for Rob, I think an important Part of the experiment was a direct comparison with the same barrel. Interesting swap of induction.
There are currently 57 users browsing this thread. (1 members and 56 guests)
  1. Gradella23
