Page 2464 of 2776 FirstFirst ... 1464196423642414245424622463246424652466247425142564 ... LastLast
Results 36,946 to 36,960 of 41632
  1. #36946
    Yea but all it confirmed was that the original crap reed assisted piston port was exactly that , crap , and that an EngMod optimized RV was exactly as it should be - far superior.
    But as Rob said earlier on , all it needs now is an optimized pipe and then the real capabilities will be realized.
  2. #36947
    I am not totally sure but Honda were running case reed on the works CR's in thee mid 70's Marty Smith Era.
    Suzuki went with their system as likely the best driveability compromise whilst avoiding whoever's patents had the Case reed.
    Anyone know who had the case reed patent?
    i remember old 50's two strokes with carbs feeding crankcase and mayb chainsaws i think some scooters, but on performance bikes?
    I just dug up the honda one and i was Suzuki style.
Name:	1974 Honda RC125.jpg
    Last edited by husaberg; 8th May 2022 at 18:07. Reason: added honda one it wa SUzi lkie
  3. #36948
    13th December 2018 - 18:06
    youtube andreas länström
    sweden
    I'm not saying it works as well as a rotary valve, it's a remarkable project from Rob, but look at the picture- it's completely standard, How can it be compared to a purpous built RV.
  4. #36949
    24th November 2011 - 23:24
    Enfield GP5, Alpha Centuri, TZ
    UK
    I am most likely wrong but doesn't the the lectron atomise the fuel better?
    I've also wondered if we were to grind the flat into a keihin's needle (and prevent the needle from rotating)
    Would it preform similarly
    Ron Gardner who made the first carb that I know of with a flat on needle, which Lectron and other's copied, started in 1947 exactly that way with a standard carb. In his case it was an AMAL carb with a round needle and flat on . Yes the flat on the needle does atomise the fuel better as it forms a spray bar, and yes you do have to prevent the needle rotation.
    I have a brace of Gardner's on my TZ and got down on a dyno to A/F ratios of 15:1 with no sign of det before I chickened out.
  5. #36950
    Just when I thought I was starting to understand two-strokes...
  6. #36951
    Quote Originally Posted by Strokerhaus View Post
    Here with a regular needle (round) note that the exhaust temp and lambda are on the same graph, see left / right
  7. #36952
    It was 1974 those were different times.....So i am told.
    They had Fuel injection at that time as well on some of the Honda MX bikes
    Found some pics
ID:	351049Click image for larger version.
Name:	RC 125 t.JPG
Name:	19765 RC125.JPG
ID:	351052Click image for larger version.
Name:	1974 RC125 v.JPG
  8. #36953
    He might be onto something Frits - I will have a go at putting the rear cone at the front of the pipe.
  9. #36954
    The article says they're "unique" i vote for them to stay that way.
  10. #36955
    80% exhaust width, it will come at a cost. I had it working with a L-ring ( if this, or ring material helped, not known). Just changing the ring gap location , I don't think will do much, furthermore it will present a big risk of ring/cylinder havoc, as the C port divider, I think, is too small to support the gap.
    The induction system on these suzukis I'm convinced is very good, the only drawback being that wonky C-port feed from the B-ducts. So if the rotary thing is permanent, then it would be a good idea to give it a proper C-duct.
    You can run just fine with ring gap location 6 o´clock, straight above a unbridged c-port, nemas problemas.
  11. #36956
    sweden
    It doesn't look very unbridged.
  12. #36957
    5th January 2013 - 13:23
    89 KX500
    USA
    The technical writing found in the dirt bike comic books rivals the quality of the information found on Fakebook.
  13. #36958
Name:	RG50 Case Reed Valve.jpg
    Reed block fills up quite a bit of the crankcase.
    For more crankcase volume I removed the reed block and filled up the inlet tract.
Name:	RG50 No Reed Block.jpg
    Blue line is with reed block in place, Red line is extra crankcase volume with the reed block removed. No other changes at all.
    I have some 10mm longer rods coming, it will be interesting to see if even more crankcase volume helps.
    I probably can only get away with this on my rotary valve engine.
  14. #36959
    Yes,, and IF you can run it with no bridge, you can certanly run it with a small bridge also.
  15. #36960
    Injectionguys!
    I have had a though for a longer while.
    I know when you got injection the demands of a carburetor disappears.(having to big causes function of carb to be disturbed)
    The atomisation of fuel is held by the injectors and fuelpressure etc etc.
    And, a supercharged 4stroke with throttleblade on atmospheric side cannot be to big.
    So my thought:
    REALLY oversize the reedcase(or slide if possible) and then run a huge inlettract, say 50mm on a 125cc engine, this to make sure there are no restrictions for air to travel into crankcase, well as little as a reed engine can provide that is
    Anyone thought the same?
