Page 2469 of 2773 FirstFirst ... 1469196923692419245924672468246924702471247925192569 ... LastLast
Results 37,021 to 37,035 of 41594
  1. #37021
    TZ, you need this, throw that shit carburetor away.
    https://youtube.com/shorts/rxc1OFcQgPM?feature=share
  2. #37022
    21st August 2014 - 13:28
    2001, Honda, RS125
    Melbourne, Australia
    almost wouldn't need an inlet valve with that set up
  3. #37023
    4th September 2017 - 10:39
    Daelim besbi 2008
    España
    This is the last time I suggest it, I will not talk about this again, nor will I bother you with this issue.
    I will never develop it, because I do not have the means to do so, the most is what I have done "CAD 3D"
    And adding to the effect of having very high exhaust duration you can cut the skirts short such that the port is open a few mm when the piston is at TDC.
    Wreaks havoc with the jetting , but in the project i tried that we were using big pumper carbs.
    Very easy to adjust the fuel curve as was needed - but I doubt a normal carb could be made to work.
    This setup on a " stock " 950 SeaDoo .
    And also as I said, I think it had a shared pipe with a y- section to the cylinders, so there is no need to have ducts from one cylinder to the other. If your idea works with separate pipes, I don't know.
    This setup on a " stock " 950 SeaDoo gave an added 8 Hp in about 80 , so 10% - enough for the title at Havasu.
    On a 1180 twin race motor the bump was 15 Hp in 120 so a little less.
    The 10% increase in power is clearly insufficient to "motivate, encourage" to use this system and try to improve it.
  4. #37024
    Attachment 351160
    Tupper Ware lunch box. All in one, carb cover and catch tank.
    Second try at protecting the carb from wind blowing across the bell mouth and upsetting the mixture.
    Nice�� A little dragy but what does it matter.
Name:	Skärmavbild 2022-05-27 kl. 18.34.29.png
ID:	351175   Click image for larger version.
Name:	Skärmavbild 2022-05-27 kl. 18.27.39.png
  5. #37025
    Ceci , the problem you are up against is that 180* firing parallel twins with a single pipe are a weird anomaly used in restricted classes of Jetskis and Snowmobiles for packaging/ space/cost reasons only.
    Nothing to do with efficiency or power.
    The bottom line is that twin pipes make way, way more power and do that with alot less Exhaust port timing needed for the Y and single pipe setup.
    They also allow a parallel twin to be run in the " big bang " 90* firing configuration , albeit then needing a balance shaft.
    The cut piston skirt idea I developed just as a cheat of the rules to win a world title , it worked , but I can see no other reason to be looking into it as an on going project with some worthwhile end goal.
    Those cut pistons also had a ceramic coating ( illegal as well ) equal to 50% of the inner dome area , and once they had been run hard , they colored up in the middle thus camouflaging the coatings existence.
    That idea of ceramic coating just the pistons combustion chamber area ( and the chamber itself ) , but not the squishband , does have an application in any 2T race engine , as it reduces the thermal load on the piston - and
    the heat rejected into the water cooling system.
    Take that idea and you can use it anywhere , as its a guaranteed way of being able to run leaner and make more power.
  6. #37026
    Yes, I love what you have done with the rotary valve sliding gibs for throttle control.
    Maybe when I build the next engine. A 69cc turbocharged rotary valve setup. I could copy your sliding gib idea and fuel inject it through the turbo intake.
  7. #37027
    Ok, finaly RSW cylinders. You will need to contact Glenn if you are interested.
ID:	351179   Click image for larger version.
  8. #37028
    Sadly Neil , I cant believe someone got you to copy the oldest and least powerful Aprilia cylinder ever made - before Jan made it work properly.
  9. #37029
    Sooo... I guess thats a no then
  10. #37030
    The patterns for anything later were not available for those Wob (at a price i could afford anyway.)
  11. #37031
    I didnt make these patterns, they have been made by a professional, proper. Above my pay rate.
  12. #37032
    At about 200 hours at my hourly pay rate.....
Name:	resin 6 (1).JPG
ID:	351186Click image for larger version.
ID:	351187Click image for larger version.
ID:	351188Click image for larger version.
ID:	351189Click image for larger version.
ID:	351190Click image for larger version.
  13. #37033
    18th March 2013 - 04:44
    75 RD250b, 76 250C , 78 250E
    Poland
    Wobbly could port them before plating? They are from before 1994? https://twitter.com/NeilHodgson100/s...23207133102081 Today from Mugello. Sadly he only made one lap.
  14. #37034
    I don't want to be judgmental about how deep your pockets are Husa, but casting cylinders using those ancient RSW patterns makes me think of taking up smoking because you found a pack of cigarettes.
  15. #37035
    Daelim besbi 2008
    España
    the cut piston skirt idea i developed just as a cheat of the rules to win a world title , it worked , but i can see no other reason to be looking into it as an on going project with some worthwhile end goal.
    ok "touché"
