Page 2472 of 2773 FirstFirst ... 1472197223722422246224702471247224732474248225222572 ... LastLast
Results 37,066 to 37,080 of 41594
  1. #37066
    Surely most engines have chamfers that vary from Conservative to pretty aggressive?
  2. #37067
    F5 - Just like completely unnecessary chamfers on transfer ports , they reduce power.
    Jans idea of putting a proper flow enhancing radius on the Exhaust ports timing edge was a piece of unadulterated genius.
  3. #37068
    24th January 2014 - 08:12
    1988, Yamaha RD350 YPVS
    RGV 250 / RS250 crank
    I have made a 54/107mm crank for the RGV250 / Aprilia RS250
    The first one from the pictures was made by myself, with a primatist conrod. The next charge will be totally made by primatist. When we tested that on track, we will order some more. PM me if you are interested.
  4. #37069
    8th July 2013 - 11:01
    2001, Aprilia, RS250
    Oz
    2 centre bearings, no centre seal?
  5. #37070
    23rd March 2015 - 21:24
    Conti RX356 V3
    While on the subject of EngMod files - does anyone have an input file for the Bidalot RF50WR cyl?
  6. #37071
    2 SKF bearings with seal covers & special grease filling. They are used in snowmobiles in the same application.
    The seal covers work like a charm regarding sealing. Probably as airtight as a labyrinth seal...
  7. #37072
    It's friday june 3 in Thailand
Name:	Happy Birthday Jan Thiel 3.jpg
  8. #37073
    26th April 2013 - 21:55
    BMW R1200R 2009
    Proficiat met je verjaardag, Jan.
    Happy birthday !
  9. #37074
    6th November 2020 - 06:51
    Yamaha rd 350 125.Aprilia 125.kawa Ar.
    Jerez
    Feliz cumpleaños MR Thiel.Muchos recordamos su gran trabajo con Ricardo Tormo,Bultaco y Derbi.Le deseo mucha salud.
Name:	Mi tesoro..jpg
    The one who wears it understands it.
  10. #37075
    Nearly every Tubo pipe was 800 from the piston , and the duct roof was at 196* duration, the port radius started at 202* but using a 0.7mm x 5mm wide dead stopper blade bent at 45* = 1mm actual
    height difference , it measured 198.
    This is why when you do a STA analysis on the RSA it appears to have insufficient Blowdown , but the clever port radius increased the duct Cd so well that in reality the Blowdown flow
    matched the Transfer power capability perfectly. Makes it hard for a single dimensional sim to replicate this correctly unless the radius effect on flow is factored into the code.
    Thanks Wob
    Just doing some tests now with r1 cylinder and programmable ignition. we'll see what length we end up with.
  11. #37076
    2Stroke Stuffing. 2 x rotary valves in carbon fiber. https://youtu.be/eA62z-ib4VM
    DIY Industrial grade CNC machine. https://youtu.be/cqYJS27aC4w
  12. #37077
    3rd February 2004 - 08:11
    Wallaceville, Upper hutt
    that CNC machine - just WOW!
    (PostalDave on ADVrider)
  13. #37078
    4th September 2017 - 10:39
    Daelim besbi 2008
    España
    I always thought that Alex's project was the most appropriate for it to be twin-cylinder, since from the first video I saw how he wasted twice as much fuel.
    I am not the only one, the creator of the Bimota V2 500 engine, he has just been granted a patent in this regard "2022-04-20"
  14. #37079
    Daelim besbi 2008
    España
  15. #37080
    Doesn't seemed to have learned anything from the abject failure the VDue was with direct cylinder injection.
    His design destroyed Bimota , who is paying for this.
