Page 2476 of 2776 FirstFirst ... 1476197623762426246624742475247624772478248625262576 ... LastLast
Results 37,126 to 37,140 of 41630
  1. #37126
    My suggestion is that Nitro is way, way more effective if used as am additive to a fuel system and engine tune that has been optimized for Methanol already.
    This primarily involves a big jump in compression and a pipe tuned to the much lower Exhaust gas temp/wave speed that will be created by a rich (+ 20 % over stochiometric ) fuel curve.
    The two are very much synergistic in action , whereas petrol/ Nitro is just a simplistic approach with nowhere near the possible capabilities.
    Its like sticking nitros in a stock Avenger Vs a stock Aventador.
  2. #37127
    13th December 2018 - 18:06
    youtube andreas länström
    sweden
    Anyone got an RZ350 cylinder lying about I could use to do some measuring for a project.
    Got a 1UA, not the 31K, been heavily modified, though some still there. Should find relevant measures here; https://www.rd350lc.net/
  3. #37128
    Quote Originally Posted by Hoebra View Post
    Ignition needs to be retarded, cause Nitromethan burns faster.
    I would say it´s the other way around, it burns REALLY slow, you need to advance a LOT.
    Nitro topfuel dragsters are having ignition point about 58-65degree before top dead center.
    And those are supercharged, hence a more compressed media, and a more compressed media burns faster than a less compressed media.
    Thus you need to advance ignition even more then they do.
    But!
    Consider they run ~97% nitro, so you might get away with ~25-35 degree before tdc.
    You might also want to try a surface discharge sparkplug(no groundstrap)
  4. #37129
    bell
Name:	bell nitro.PNG
    http://3cyl.com/mraxl/manuals/bell/p...raham-bell.pdf
    i remembered after reading that that the top fuel dragsters used propylene oxide also to speed up combustion.
    its apparently banned now, Cancer causing i think.
    All this talk of methanol does raise a thought can you make the stinger bleed venturi considerably smaller when running methanol or ethanol?
    something old something well new to me....
    https://www.thumpertalk.com/forums/t...-cylinderhead/
    Am i wrong or is this braided oil line?
    that said
    https://www.flexiducting.co.nz/produ...-exhaust-pipe/
    20mm up
  5. #37130
    No. The restrictor diameter depends on the power produced by the engine, not on the type of fuel. But why do you ask Husa? I am curious about your line of thought.
  6. #37131
    In the old days we were lead to believe the smaller the bleed the more hp, with a caveat of but go too small and you create too much heat.
    its likely a fallacy. I have always just run the recommended sizes. But never melted anything either
  7. #37132
    28th August 2015 - 00:01
    1975 Hodaka Wombat
    Eugene, Oregon, USA
    I believe the most highly developed nitro burning 2 strokes are model race engines. Today their popularity has declined against competition from industrial gasoline and electric power. To help preserve this history, I wrote a 6 part series. Readers will discover that I shamelessly stole material from members on this site as well as my friend, the late Jim Allen.
    Lohring Miller
Name:	The Nitro Engine.pdf
ID:	351397Click image for larger version.
Name:	The Nitro Engine part 2.pdf
ID:	351398Click image for larger version.
Name:	The Nitro Engine part 3.pdf
ID:	351396Click image for larger version.
Name:	The Nitro Engine - Part 4.pdf
ID:	351395Click image for larger version.
Name:	The Nitro Engine - Part 5.pdf
  8. #37133
    1975 Hodaka Wombat
    Eugene, Oregon, USA
Name:	The Nitro Engine Part 6a.pdf
ID:	351400Click image for larger version.
Name:	The Nitro Engine Part 6b.pdf
  9. #37134
    20th June 2020 - 07:10
    ETEC 800
    Minnesota, USA
    Attachment 351321
    Prepared and ready to test a batch of pipes I built at an eddy current engine dyno. All four sets of pipes have the same tuned length from piston to end of convergent cone and share the same dwell and convergent cones, thus all four also carry 66 % end of diffuser and 77 % end of dwell. Two sets have 33.5 % headers and two sets have 31.5 % headers. Two sets have two stage diffusers and two sets have three stage diffusers. I have added provisions for tophat nozzles to Optimize the bleed orfice. In hind sight there are things I would have done differently for this test, but I believe I will take home a lot of usable data.
    Now I just hope the 75 % exhaust chordal width keeps the ring in. I have had great results with such wide ports in the past, however this was the last time I will ever send a cylinder to millennium. Royal disaster of a chamfer job, completely changing the geometry, even after I left them several notes with my instructions.
    Well the eddy current engine dyno day went very well in my opinion. An honest 10% increase in power from last year. The engine is maxed out on every facet besides lowering the intake port another 2 degrees. The (considered to be unsafe) 75.5% exhaust port held the ring without incident, and the ring end gap that rides right on the chamfer of the B ports survived. (Maybe it was a blessing that millenium chamfered my transfers after all)
    Best of all, Engmod2t and my dyno results are all within .75 Hp for most of the curve with very small discrepancies that are probably a byproduct of small modeling errors. I had to do some tweaking to the temperature files from the default values, but after the first pipe was ran in the sim, the other 3 followed the trend and were an accurate representation of the dyno testing.
    We did multiple dyno runs on each pipe to verify consistency. Since this is for short duration drag racing each pipe also received what we called a cold test and a hot test. We placed a K type thermocouple in the center section of each pipe so we could heat the pipes to a consistent starting temperature before the controlled auto-run was started.
    Something that I noticed that I do not fully understand. The pipes made more hp throughout the graph on the cold start test, however the entire curve shifted to the right when performing a hot test pipe. The hot start pipes also smoothed out the curve much better.
    Here is my question. And I ask this cautiously because I now know that I am out to lunch on my pipe designs from where the end power goal is. The peak rpm is 3-400 rpm lower than expected, and what the engine wants.
    -I have been been under the impression for a while now that the hotter a pipe is the shorter it thinks it is, makes sense the power moved to the right on the hot start pipes. Why is power down with the hot pipe then? Confused I am.
  10. #37135
    4th December 2011 - 22:52
    Yamaha XJ750 1982
    South Africa
    Very often it is not the hotter pipe but the hotter exhaust port wall that heats up the short circuited / over scavenged gas that is plugged back into the cylinder by the plugging pulse, this has a lower density and thus less mass in the cylinder at export closure.
  11. #37136
    ETEC 800
    Minnesota, USA
    Thank you, that is enough to put my wandering mind at ease.
  12. #37137
    To verify if your engine is running out of breath at higher rpm or if you are seeing the effect of the then fully warmed up engine, you can build a shorter version of that same pipe and do another cold and hot dyno pull. You should be able to model the temperature effect in EngMod, too if you play around with the temperatures a bit. On air cooled engines, the temperature and thus power differences between a cold and a hot engine are much bigger than on watercooled engines. Do you happen to have a thermocouple or an infrared gauge to measure the crankcase temperature?
  13. #37138
    ETEC 800
    Minnesota, USA
    Thank you for the reply. I do not believe the engine is running out of breath just based on comparable setups that I am familiar with. I do not currently have any crankcase temperature monitoring, but I do have a spare thermocouple that I could fix to the case.
  14. #37139
    Frits is right again. The nozzle size is dependent on the engine power , with one caveat.
    A bigger nozzle reduces the pipe pressure and thus the operating efficiency.
    This works in your favor lower in the powerband , as the return wave coming back too early has a reduced amplitude , thus it doesn't fuckup the power so badly.
    But of course no free lunch , in that what you gain down low you loose up top.
    Re the pipe temp and power loss - if the hotter pipe moves the power to the right ( as it should ) but you are seeing a loss at the higher rpm, then that means one of two things.
    There is an element of the tune that is not suited to the higher rpm , or the pipe is wrong for the new higher rpm ( or both ).
    EngMod is superb at sorting this stuff out.
    Maybe you need to settle on a strict test procedure that will then be taken to the strip , such that the beginning pipe/case temp is always the same.
    I did this years ago when designing pipes for Yamaha KT100 , the case temp was always started at the same level , and the final egt was always adjusted to match after every dyno run.
    Case and head temp are critical on an aircooled and can really lead you off on useless tangents if the process of testing isnt rigorous.
  15. #37140
    ETEC 800
    Minnesota, USA
    Thanks Wobbly. Done deal. I’ll get something consistent figured out. Admittedly, we pulled the under plug thermocouples off after the first pipe so although the pipe starting temps were consistently tested throughout the dyno runs, the cylinders/heads were a “go feel them” thing, which is obviously not super accurate.
There are currently 64 users browsing this thread. (1 members and 63 guests)
  1. Storbeck
