Page 2481 of 2776 FirstFirst ... 1481198123812431247124792480248124822483249125312581 ... LastLast
Results 37,201 to 37,215 of 41632
  1. #37201
    A useful thing just turned up. Heat treating at home.
  2. #37202
    8th November 2015 - 17:28
    1991 MZ 301
    Denmark
    UK postal service dream of serving remote locations with drones that can move 100 kg 1000km.
    Their first versions are driven by Briggs and Stratton Vanguard twin 38 cui lawn mover engines and we all can think of better ways.
    UK Flying Post Angels will need plus 200 engines per year if these can be low mass,reliable and frugal.
    [URL="https://www.dieselprogress.com/news/Vanguard-powered-UAVs-bring-aid-from-above/8013169.article"]
    An inverted single cylinder two stroke direct drive with exhaust valves as a Honda Cub (More than 100 millions made)
    will be better for making 30 horsepower at 60 rps.
    76 mm bore and stroke 112mm.
    More words and maybe a working link can be seen here
    https://www.homebuiltairplanes.com/f...p.36052/page-5
    https://drive.google.com/drive/folde...XM_g0HQ9pOxbmv
    https://windracers.org/
  3. #37203
    1991 MZ 301
    Denmark
    Tuned exhaust for valved exhaust two stroke?
    A know it all ESE user can do valuable deeds for humanity etc.
    Tuned exhaust pipes as we know them does a good job of converting blowdown kinetic energy to suck and blow back.
    The blowback is not needed in this aero aplication as a MEP of 7.5 bar will do and exhaust closing timing is done by camshaft.
    How long aproximately shall pipe be?
Name:	MZ 008 1.JPG
    My beloved MZ301 had a pipe of ca 1.2m length and came on at cirka 50 rps (3000rpm)
  4. #37204
    13th December 2018 - 18:06
    youtube andreas länström
    sweden
    Seems like you are talking about a two stroke uniflow, to my knowledge the honda cub engine is not one of those. How long a diffuser only, pipe shold be? Of course all the usual input: rpm, ex open etc is required.
  5. #37205
    1991 MZ 301
    Denmark
    Different wording for another fellow scandinavian
    "with a cylinder head like a Honda Cub with two exhaust valves "
    I really have not the faintest idea of best timing and asume that a clever guy with a good programe can optimize timing and pipe simultaineously
    Input parameters are ca 76 mm bore,112mm stroke, 30 horsepower and 60 rps.
  6. #37206
    sweden
    Ok, I understand now. Someone probably could do that, just prepare for a less than significant increase in power, because the poppet valves don't give nearly as high wave amplitude as an ex port, and there is only the expansion wave doing work.
  7. #37207
    1991 MZ 301
    Denmark
    The holy and perfect Aprilia was once run without any pipe and inlet resonater etc by Jan Thiel and it gave an Mep of 6 bar.
    We need 7.5 and has much better trapping due to longstroke uniflow.
    Pipe are not asked to make miracles
  8. #37208
    sweden
    I like the altruistic agenda, and it doesn't seem unrealistic for it to work.
  9. #37209
    Haha, popet valves are for toilets.
  10. #37210
    1991 MZ 301
    Denmark
    Two counterrotating ,synchronized single cylinder engines give cargo and airframe an easy ride as torque reactions cancel.
    When one engine quits it is not a disaster,but slower mail.
  11. #37211
    4th September 2017 - 10:39
    Daelim besbi 2008
    España
    They are already working, and more than 100 Kg, I am not sure but I think I have seen some, since their fuselage is different from that of light aircraft (the double rudder is not usually common in common light aircraft)
    https://dronedj.com/2021/07/14/franc...ansport-drugs/
    https://english.elpais.com/spain/202...m-morocco.html
  12. #37212
    guys let me ask something about the divider between main exh and secondary on a cylinder with iron liner. 1mm wide should be fine i think but what about .75mm. the liner is thick so it should be strong enough just to keep the ring in the groove. it might wear down faster but i dont care
  13. #37213
    Depends how close to 70% the main port is.
    At this width the ring absolutely does bulge out into the port , and the bridges are heavily point loaded when pushing the ring back into the groove.
    Having an oil hole drilled thru the piston directly over the bridge will help , just as it does for T port bridge wear issues.
  14. #37214
    its slightly under 70% if i recall. i may put a bit of arc on the roof to be safe. when i was punching the new windows into the liner i fucked up and grinded the secondaries closer to the main than i wanted. to some what match the liner to the main its going to leave a thin divider of 1mm or so
  15. #37215
    20th June 2020 - 07:10
    ETEC 800
    Minnesota, USA
    I had issues with a 1-2mm wide iron bridge between aux and main before. This was an application where I had to make the aux tight to the main because of stud bore constraints. It overheated the bridge. I did not have oil holes drilled.
