Page 249 of 2776 FirstFirst ... 1491992392472482492502512592993497491249 ... LastLast
Results 3,721 to 3,735 of 41626
  1. #3721
    re the water injection (Ill dig out the article for you) Honda also stated they could achieve the same results from other methods such as ignition, powerjet etc, so there was no point in pursuing. Think it was Doohan bike they tried it on, he came back saying dont bother.
  2. #3722
    Your photo gives away that your injecting something direct into the cases, do tell.
Name:	A2-Crank Clearance.jpg
    No, not injecting, that is/was the take off for a pumper carb,
    I used the pump part to scavenge the plenum. I will keep the fitting there just in case I try a full blown pumper slide carb from a kart in the future.
Name:	Plenum and clear cover 008.jpg
    The clear cover was suggested to me by someone so I could see what was going on and Yow Ling suggested trying the straight shot carb idea just to see if that helped reduce fuel/oil drop out and/or increase power.
Name:	New Project 11-03-2010.jpg
    I had been working on the plenum idea with its 32mm throat as a way of getting around the restriction of the 24mm carb rule. But 24mm has proved to be not as restrictive as people, myself included, thought it was.
    The plenum may still have other uses, I think it or a variant might be usefull in broadining the power spread. As I have figured out a way to make a variable inlet throat that can be changed from 22mm to 34mm with the IgniTech's power valve controler. It may also be possible to extend the idea to variying the closing point of the rotary valve.
Name:	AA-TeeZees GP Cylinder.jpg
    I will come back to it after I have finished playing with the 30rwhp side port barrel. At the moment its a peaky beast, I hope to get it useable with a bit more development.
  3. #3723
    currently the insert is in blank form, but that's the next step.
    Attachment 234617
    We will be needing to do something like this too.
    Did you make the insert or is it something that can be bought semi finished and you machine it to suit.
  4. #3724
    31st July 2005 - 11:15
    a shed full of crazy shit
    Off the shelve (blank), I'll send you the details. I was/am going to use it to make a copy then there will be no argument between after-market and raceparts...
  5. #3725
    Dont waste your time and energy re water.
    Honda did it with full PWM solenoid control - it bumped up the bottom end really well, but the water mist in the pipe kept it cool for so long down the straights that the engine never really recovered in time to get the top end back.
    Another expensive blind alley.
    Yes, it may prove to be a blind alley, but I have all the parts and have had my heart set on trying it for so long that I just have too.
    The issue with the motor staying cool and not recovering the top end could be a blessing in disguise. As it could be an easy way of making a top end motor suitable for Mt Welly where its more about drive out of the corners than top end.
    Or thumb on the button for water and drivability up the infield hill at Taupo and then across the top with no button to let it dry out in time for the faster bits out the back and the front straight.
    The plan is to do several all out runs on the dyno without water and several with to find the base lines and changeover point.
    Then a few runs on the dyno with it changing over should tell us all we need to know.
  6. #3726
    so this is what we started with, standard TZR head complete with crappy noise reducing squish (apparently), welding this was never really going to work out well:
    Attachment 234615
    Weird, never seen anything like that.
    But I don't buy it. There is no explosion to create noise, the noise is the gas entering or exiting the engine. When squish is occurring the combustion chamber is isolated from the ports. How can this reduce noise?
  7. #3727
    Had a great day Sunday, riding a borrowd RG50. Those F5's are so much fun I have been inspired to get back into working on my own 50.
    This attempt at improving my 50 has nothing to do with the fact that Will beat me in every race Sunday.
    Reduced the angle of the case reed, cutaway the spigot and flowed the reed into the transfer ducts.
Name:	A New RG50 Cly 007.jpg
ID:	235039   Click image for larger version.
Name:	A New RG50 Cly 001.jpg
ID:	235040   Click image for larger version.
Name:	A New RG50 Cly 006.jpg
  8. #3728
    I've gone flatter than that, look at an RG250 or RM.
    Why have you flowed from the base of the reedblock into the transfer?
    Tip. RG engines are canted forward in their chassis. Make sure you take account for this when working out what angle your carb will end up at unless using something like a NS400 super steep downdraft. I prefer to spot on a flat plate & bolt aspigot, like a GP125 one if 24mm carb, or there is a bigger one (maybe X7??) that will take a 28. Isn't much fun when the carb falls off a simple tube type.
  9. #3729
    20th October 2010 - 20:59
    Rg50 Fxr's150
    Borrowed Bike
    Thanks for lending me one of your bikes on Sunday. Well impressed with the fat power spread. Keep up the good work.
    Dazz
  10. #3730
    Thanks for the tips on the reed and carb.
ID:	235049 Click image for larger version.
    The porting from the case reed to the transfers was an attempt to emulate these inlet side ports that go from inside the inlet to the transfer.
  11. #3731
    4th February 2005 - 07:32
    Rattlecan blue
    Getting a loaner ride on Cullys' last month has me looking for one as well.
    Then I borrowed it again Sunday and broke it, now I need one instead of wanting as I hate wrecking other peoples toys.
  12. #3732
    Hmm, those barrels on the right seem familiar from somewhere (CPI like on my 500) (edit, not they're not, think they are Cub CPI rather than Cheetah, see pic). But obviously the reed blocks are somewhat different to the suzi setup.
  13. #3733
    Gigglebutton running 3rd on his F5 RG50 in F4 and going for the Doctor trying to beat all the FXR150's.
    http://www.youtube.com/watch?v=v1pT-Tt_yMs
    And finishing with the classic Deck-Inspection.
  14. #3734
    24th July 2008 - 18:01
    Honda RS 125 1992
    Taupo
    Thats what I did !! Great pass from Conner...
  15. #3735
    Crank re-balanced for 50% and machined for more clearance and subsequently increased crankcase volume, there are no other changes to the engine.
Name:	A1-Crank Clearance.jpg
    Ran the small crank that has the 2mm (1mm is Std) clearance everywhere between the crank and cases, on the dyno tonight.
Name:	A Small Crank.jpg
    Old crank, blue line, new big clearance crank red line, poped a head gasket on the 3rd run.
    Not looking promising at this stage, a few horses awol but at least the vibration has pretty much gone.
    Ran out of time to fix it and play with the ignition and jetting, tommorow night hopefully.
