Page 2492 of 2776 FirstFirst ... 1492199223922442248224902491249224932494250225422592 ... LastLast
Results 37,366 to 37,380 of 41626
  1. #37366
    Quote Originally Posted by Javier Ruda View Post
    I did a search for recommended piston to wall clearance on rotax 125 cylinders:
    1995 moto Aprilia RS125
    0.020-0.035mm
    2000 kart Rotax FR 125 Max
    0.025-0.050 mm
    2001 kart Rotax 125 Max Evo
    0.04-0.05 mm
    2021 kart Rotax 125 Max DD2 Evo
    0.05 mm
    There is one detail missing in those recommendations: the number of seizures.
    Aprilia must have made a fortune selling cylinders and pistons in 1995....
  2. #37367
    20th June 2020 - 07:10
    ETEC 800
    Minnesota, USA
    With a 69.5mm bore and forged wiseizcos I use .0055”. This is because when the engine dyno operator gets out of a pull they sometimes stick if any tighter. Before we dyno tested everything, there was no issues at the track with tighter clearance.
  3. #37368
    2nd May 2020 - 21:05
    Aprilia RS125
    Barcelona
    Indeed, these Aprilia numbers are way off compared to the others.
  4. #37369
    7th March 2018 - 05:39
    Kart
    Europe
    I have the info that with that tight piston clearance (2/100mm) they had to heat up first the coolant liquid and the entire engine before they could even start the engine.
    Hope my info is correct.
  5. #37370
    Condyn the only time I have seen anything like 0.0055" used ( 0.1375mm ) is in hotrod jetskis , due to the very cold waterjacket temps used.
    The fix is to use restrictor pills in the water dump tubes from the cylinder , or a thermostat to keep the water temp at a reasonably sane level.
    If any race engine locks up when backing off a load , then that instantly red flags the tube/needle is way lean on less than WOT.
    The Wossners in 72mm size for a CPI 485 Banshee I have built probably 20 of these, and they run forever at the factory recommended 0.06mm ( 0.0024" ).
  6. #37371
    14th April 2011 - 23:44
    2008 Yamaha fino
    Bangkok
    Aprilia made a fortune on selling pistons every year....
    Piston clearance should be 0.04mm they said.
    Out of curiosity I tested bigger clearances:
    0.05mm gave MORE power.
    And 0.06mm gave the same power as 0.04!
    There were 'heavy' and 'light' pistons.
    With the heavy ones you could do all practice sessions AND the race without power loss
    The light ones had to be changed every day, they deformed and caused power loss...
    I never understood the 'advantage' of the lighter pistons.
    Except that more money was made on them.....
    On the dyno I always used the heavy ones, without any problem!!!
    Up to 30 power curves with the same piston, without any power loss!
    About 80% profit was made on the pistons....
  7. #37372
    2008 Yamaha fino
    Bangkok
    The wossner is forged and the vertex is cast, thats probably a bigger difference than the "pockets", which I don't think do anything for performance.
    The 'pockets' are mostly negative for power.
    Cast pistons give slightly more power in my experience!
  8. #37373
    Aprilia RS125
    Barcelona
    Thank you Jan! Then cast and 0.05 mm is the good try, and no pockets as andreas and wobbly said.
    I have one more doubt, maybe silly. The cylinder is not new, so a bit ovalised, 0.006 mm. Does this make a difference?
  9. #37374
    I diamond hone when I see 0.005mm , its always on the thrust face and each side on the bridges.
    But the KZ engines run 0.07mm clearance to start with to reduce run in time ( thus extending crank life ) and there is no difference in power I can see between 0.07 and 0.09.
    You can do it a couple of times and fit a new piston, then go up to the next size from 53,93 to 53 ,94.
    If you dont hone it , then you see brown blowby just below the ring very quickly even with a new piston fitted.
    Edit = 0.005 correction.
  10. #37375
    Aprilia RS125
    Barcelona
    I diamond hone when I see 0.0005mm
    Thank you wobbly! By the way, very impressed from that measurement.
  11. #37376
    Sorry one to many 0s - 0.005
  12. #37377
    ETEC 800
    Minnesota, USA
    Re- wobbly on the clearance.
    I will take a closer look at the needle/tube, however this issue has only happened on the dyno and never at the track thus far with slightly tighter bores. Also I have never noticed anything that stands out on my data logger on shutdown.
    We race in temperatures sometimes cresting -30c so I am sure that is why the manufacturer specs such a loose clearance. .004-.006” or .1-.15 mm is very common to see recommended in the snow application. Some oem cast pistons are specified a tighter clearance than that, however not very common. By no means am I saying the common practices that we have been using for decades are correct, they may very well be folklore. The risk, or imaginary risk of seizing at the track is just too great to tighten the clearance, especially after the dyno experiences.
  13. #37378
    Yea I get it now - in the snow you have the same issue as the jetski"s except its the ambient air freezing everything.
  14. #37379
    The 360 is up and running again with a new autolube system. Seems also the disc had shifted again, this is why it started to behave odd on the dyno, also becoming difficult to start. Disc drive system was only ever clamped in place but now is pinned. Sounds better, starts easier and apears to hold tune now. Pictured a squirrel fan for extra cooling, zippy tied on.
    Maybe now some results to 'take home'.
ID:	351754   Click image for larger version.
ID:	351755   Click image for larger version.
ID:	351756   Click image for larger version.
  15. #37380
    Quote Originally Posted by oldguy View Post
    Building a BRC YZM500 2 stroke
    Riley Will....
    Congrad's thats a quality piece of kit i had seen some of the stuff a while back but a Balance shaft and modern chassis and Decomp pv and case reed.
There are currently 11 users browsing this thread. (1 members and 10 guests)
  1. 2T4TSim
