Something you dont see every day, a nitrous CR500. Because death cant come quick enough...... I guess😁.
A little update on my gearbox swap. I've been riding it for a bit this summer and it seems to work just fine. Better overlap so I could push the powerband a little higher and current top speed which I've only tried once is almost 170km/h, could probably push a little more but I'll stop there for now as I'm happy with it and it performs well on the small country roads I ride with it. It's fast enough to get dangerous.
So I cut the side of the engine case and widened it. Also had to widen the outer cover as well for the chain to clear the clutch cylinder and braced it to make it stiffer as it was flexing when clutching. The selector drum required most modification, had to resize one side, cut it in half and add a bit for the gear points or whatever you call it. It was a lot of fiddling back and forth but in the end it worked out pretty well. Had to correct some slight warping of the case as well after the welding.
If I may ask : why did you choose to weld, and not use a spacer plate for widening the cases ?
After using the FOS 2T power correction algorithm in my latest dyno tests , that gives much more realistic power numbers ( for example high mBar ambient air - I had an unbelievable 1040 the other day )
I have discovered that JIS D1001 correction gives almost identical results.
This might be useful on dyno software where the FOS code cant be inputted.
Ive got no idea what the correction data is for this , but it does seem to be much closer than any of the others commonly available.
2Stroke Stuffing and a new direction with a new centrifugal blower.
Man thats crap customer service from L&S , imagine the hundreds of their dynos that are 2T dedicated.
360 ready for a ride, finally.
TPI mk2, E85 fuel, reverse rotation crank, sliding gib throttle / valve timing, reverse cylinder, double counter rotating balance weights, autolube direct to the bigend via an airstream, electronic guillotine type powervalve, water cooled crankcase, toridal head with an 8mm spark plug.
It goes pretty good around the yard.
Remind me, what was the BMEP of the Aprilla RSA 125?
At around 53 or 54 the works Norton Manx had BMEP value of almost 14 bar or 200psi at 7000rpm
but to be fair they had nearly 4 times as long to fill the cylinder compared to to a 125 2T 14,000RPM
According to Frits for the Aprilia RSA125 the BMEP was 17 bar
http://www.pit-lane.biz/t117p820-gp1...-part-1-locked
We all learn.
In that Pit-Lane post of 2012 I wrote: "Transmission losses are in the region of 5% per transmission step." Nowadays I think it will be closer to 2,5% which implies that the crankshaft power, torque and BMEP of the RSA were a fraction lower. But at 15,75 it's still better than any other naturally-aspirated petrol-burning engine I've ever seen, including Formula 1.
There are currently 25 users browsing this thread. (1 members and 24 guests)
