Page 2497 of 2774 FirstFirst ... 1497199723972447248724952496249724982499250725472597 ... LastLast
Results 37,441 to 37,455 of 41610
  1. #37441
    13th December 2018 - 18:06
    youtube andreas länström
    sweden
    Andreas test it like this save you lot of work you can make changes quicker
    I don't really follow how you mean?
  2. #37442
    He means i believe as a straightish pipe hanging out and then make snake like when you are happy.
  3. #37443
    3rd August 2012 - 02:39
    yzf 250
    holland
    Yes
  4. #37444
    sweden
    Ok, I see. It isn't going on a dyno, and elongate/shorten belly/header is not so hard.
  5. #37445
    yzf 250
    holland
    Oke Andreas
Name:	husqvarna 125 test.jpg
  6. #37446
    Once again Frits is on the money.
    My empirically derived idea of exhaust duct exit reduction to 75% of the effective Exhaust Port area works very well as a guide to the size to be looking for.
    Frits has always maintained the exit area should be tied to the Blowdown capability.
    Here we have a case of the Blowdown , that is optimized to achieve a relatively modest 13 Bar bmep , achieves Mach 0.8 at the pinch point with a 71% area reduction.
    Smaller looses power as does a larger exit diameter.
    It seems the only way to optimize this factor is by tracking the Mach number to achieve 0.8.
Name:	Kawa Ex Mach.JPG
ID:	351876   Click image for larger version.
Name:	Kawa Ex Geometry.JPG
  7. #37447
    24th January 2014 - 08:12
    1988, Yamaha RD350 YPVS
    Hi Wob,
    bore is apparently 59mm, may you tell us the stroke?
    Regards
    Tim
  8. #37448
    23rd July 2017 - 21:59
    n/a
    canada
    Hi Wob,
    Regards
    Tim
    Tim here is a small calculation to find the bore .
    51.8/71.9*100 = 72 mm
  9. #37449
    Yep , she's a big bore dragster.
    72 B X 63 S - Rod 130 = 256,5cc
    So the power is limited by the huge oversquare ratio compromising STA but also it can't be rev'd hard due to the heavy piston even though the stroke should easily go to 11000.
  10. #37450
    Quote Originally Posted by porttiming124 View Post
    Ouch. Wrong window. I did the very same calculation with the Effective Port Diameter
    I would agree: the exhaust window area is right on the money.
    Regarding the 75% rule in general, I tend to disagree:
    The Flange will be allright when:
    Flange-Area = .75 x BigEnoughExhaustWindow-Area
    but the Flange will be too small when:
    Flange-Area = .75 x NotEnoughExhaustWindow-Area
    In that case, using a Flange-Area that is too big (>75%) can compensate for an exhaust port that does not supply enough area for the desired power.
  11. #37451
    Now I disagree , as the proven 75% exit area works perfectly on a TM or an Aprilia , if you then have an Exhaust port that makes sub optimal power by not having sufficient Blowdown area -
    then as the above example shows , a smaller exit % of 71% in this case works way better.
    That is , as Frits has said , the exit area is a function of the Blowdown capability , and that is what sets the bmep achievable - low bmep = low exit flow = smaller area needed to hit 0.8 Mach.
  12. #37452
    sweden
    Kawasaki Mach4 for sure.
  13. #37453
    yzf 250
    holland
    Did you test the pipe Andrea
  14. #37454
    sweden
    Not tested, it wasn't finished before I opted for thicker walls.
  15. #37455
    20th June 2020 - 07:10
    ETEC 800
    Minnesota, USA
    Apologies in advance for questioning a very old, tried and trued idea.
    With the concept of weight savings set aside, what is the purpose of the piston cutouts under the wrist pin? I understand they keep the transfer entrys un shrouded. I have read in this forum that the amount of mixture to enter the scavenging column does not exceed what is stored in the transfer passages. It is my interpretation that that also means there is no direct communication needed to the crankcase at BDC.
    The reason I ask this question is because due to the piston cutaways when the piston is at TDC, there is a direct link from the intake port to the transfer windows in the cylinder. (on all engines I work with)
    Would this not cause a turbulent reverse flow backwards down the transfer duct before the descending piston opens the transfer windows?
